i'm starting my build for my jdm zc dohc motor.. i was wanting to know if anyone knew where i could get the boost stuff for it?? (pisions, rods, ect) and dose anyone know the number i can pull out of that motor?
I♥my ruckus
~Lagg Squad~
<turbo negros>
I put the sexy in dyslexia.
R.I.P steven bond....
hey man.. whats up.. member me with the four door gsr.. Seth.. PM me.. later
Guys: No Shirt, No Service
Gals: No Shirt, No Charge
I have 2 fully built ZC motors already!! PM if you intrested!
d16 pistons rods and everything works....im building a 400whp zc now as we speak for my girl.
this was gunna be the build in my 4dr but i went with a Z6 instead... but yeah you can just get pistons and rods made for any model d16 engine.... the same goes for the Turbo manifold... the sleeves on those are actually slightly thicker than the SOHC's, I've seen several ppl post the block and run over 15 psi without cracking the sleeves... not saying you should ... but, with proper tuning it can be done... the only downside for me was that they come with composite headgaskets and with the boost i was planning on running i would've rather had a multi-layered steel one... cometic offers one, but it's for a 76mm bore... but you could have them make you one for stock bore or bore the cylinders... also, webcamshafts, gude, and i think exospeed offer cams for the ZC... G/L with the buildOriginally Posted by Gr33n_EK9
we plan on run 20-25psi on the stock sleeves. It's been done many times and it's about to be done again.Originally Posted by SiRed94
x2 I got one sitting in my garage...Originally Posted by Whiteboy™
Post up on updates and when its dones!!Originally Posted by Gr33n_EK9
But i bet there not 2 fully sleeved blocks,like the ones i have?Originally Posted by JDM onlyy
i had a jdm dohc zc too, at 7 psi it dynoed at 207 whp
I LIVE MY LIFE A LICENSE SUSPENSION AT A TIME AND FOR THOSE SIX MONTHS OR MORE, I STILL DRIVE.
haha hell yeah... i was surprised at how damn thick the sleeves were when i popped mine open...Originally Posted by Gr33n_EK9
what about stock??? how much boost can i push and what number will i get out of it?
I♥my ruckus
~Lagg Squad~
<turbo negros>
**** no, but I got the Dual cam one...you have the SOHC ones. I want that one you got but can't afford it...Originally Posted by B18c1Turboed
Oh well, one day....![]()
If you are going to do the DOHC ZC the first change I would make would be the headgasket and head studs. The OEM composite (paper thin) gasket is really garbage. I would use the D16A1 HKS beaded headgasket and a set of ARPs. If you can still fid the Dodge Neon SRT 4 ARP bolts then grab a set (it is the same as the DOHC ZC)Originally Posted by callmetree19
The exhaust manifold itself is the exact same as the SOHC. We build them on a regular basis. The rods are the same as the SOHC D16s as well. The pistons are the same size but will yield an even lower C/R in the DOHC than what they are listed at. To get a properly specd piston for the DOHC ZC you may want to try a set of RollerWaves from Endyne. you can use others but you will have to calculate the C/R...actually bump up the C/R numer for a SOHC ZC to get a correct C/R for the DOHC.
Power, the DOHC ZC makes very good powerand even better torque with boost.(owned one myself, built a few for customers)
Hmmmmm.. i have the dohc ones also?Originally Posted by JDM onlyy
