ok so i want to get a Lightning and sell my car... not sure what to ask price wise yet... i have a lot into the car but everything on the car is basically new. things that have to come up before i sell the car is going to be tint paint and car alarm. other than that everything is there. im tossing in a camber kit as well... what do you think i can get for the car??
Oh its a DB8
1998+ Front and Rear bumper (OEM) black housing headlights, OEM ITR spoiler, ABS ITR front lip, OEM style ITR side skirts and Rear valances. 96+ side mirrors (OEM) shaved side moldings. OEM avs
Amber turn signals
NEW Champ white paint job
Interior mods
Gauges
Autometer (Boost, oil pressure, a/f ratio, temp, volt)
Shift light
OEM ITR shift boot
ITR clock block off
ITR Air bag delete
1998 leather wrapped steering wheel
Skunk 2 shift knob
Motor
(head)
Recently replaced valves and valve springs
Mild port job. Head was milled.
(bottom end)
CP Forged pistons 9.0
Eagle forged H-beam rods
Block guard
GSR girdle
Balanced GSR crank
Ignition
Summit racing (msd box)
MSD external coil
MSD 8.5mm wires
MSD cap and rotor button
NGK 3330 plugs
New Duralast Gold battery
New starter and timing belt
Fuel/ management
Hondata s200 with boost data logging etc. all options are unlocked
Aem 3 bar map sensor
Aeromotive FPR
AEM high volume fuel rail
RC 750cc Injectors (saturated)
Walboro 255LPH fuel pump
New fuel filter
B&M Fuel pressure guage
Steel braided lines and Earls fittings
Transmission
GSR with Factory ITR Limited Slip Differential
Fidenza 7LB aluminum Flywheel
Competition stage 4 clutch
Carbon Coated syncros and gear housing
LS 5th gear with the correct intermediate and main shafts (no half assing)
Suspension
KYB shocks
GSR strut bar
Traction bars
Upper and lower rear anti-sway bars
No name coilovers
Stereo
Alpine CDA-9856
Alpine Type-S Front and rear
Kenwood KAC-8103D Mono Amp
10 inch Alpine Type R subwoofer
Turbo set up
Garrett T3/T4 (GT 3271 60 trim .63(compressor side)
MSP custom exhaust manifold
Tial 38mm wastegate
Greddy Prospec B II boost controller
BBK single stage intake manifold (bored 70mm to75mm)
73mm Throttle body (power)
3 inch intercooler piping
Greddy RS adjustable BOV
24x12x3 inch front mount intercooler
3 inch exhaust (with deleted cat)
New steel braided feed and drain lines new flange and pan gaskets
Magnaflow muffler
Cooling
Header tape wrapped intercooler piping.
Failsafe 180 degree thermostat
Aluminumd Dual Core radiator
Torque high flow slim fan
New water pump
FNR10- 5 5spoke wheels
BFGoodrich G-Force street tires
New ceramic duralast gold front and rear pads
New front and rear duralast gold rotors
Extras HID 10000K low beams, yellow high beams, 5% tint, angel light (not hooked up)
Has a Viper XV791 Alarm (Remote Start not hooked up)
All parts are new or less than 1000 miles. Yes 1000 miles. This car has been in the shop for a good bit of the work. I have numerous receipts for the parts and some of the labor.
Goods- everything is new and runs great
Bad- driver’s seat has a rip a few little nicks and nacs
Still have power steering ac and all the options of a GSR and leather interior
