Results 1 to 13 of 13
Thread: building a ls vtec block
    BOOSTED GSR/HYBRID
    ON THE TRACK
    Default building a ls vtec block
    if i buy forged rods and pistons for my ls vtec thats already boosted at 8 psi can i just put them in or do i have to get balanced?
    Boost Junky Jordanmd88's Avatar
    Na dont worry about it, all you need to worry about is bearing "crush" and ring gap your ready to roll.....
    georgia
    wouldnt he need to get the block honed? or atleast checked??
    yes i am....
    pilotin' the pussy
    Roswell
    Quote Originally Posted by bodydropped
    yes if he changed the size. He would also need to get the ECU re-flashed, or the gains would be minimal.
    Some people like cucombers better pickled.
    professional student
    block should be honed and possibly bored depending upon if the walls are scarred up...i would NEVER install new pistons/rods without at least having the block honed
    am i the only one here who hones thier own blocks... It's not rocket science
    georgia
    Quote Originally Posted by Jordanmd88
    ive never done it myself,what do you use? and how would i make sure i did it right if i tryed it. would i need to measure the bores with one of those cylinder bore dial thingies?
    yes i am....
    superduper LLLLLLLLL
    i'd get it balanced.. lol
    you need to buy a 81mm Bottle Brush hone.. you can only get them from a few places... about 45 shipped.. Puts a better than factory cross hatch in the cyl... soak the cyl in Trans fluid and the hone.. and then just go up and down the cyl till you see the nice and smooth cross hatch pattern...
    then you measure with a dial bore gauge and see if it's stil within spec... it most always is since your just polishing the bore ...Just never use a Stone hone say from craftsman, shitty hone and it will take metal off of your cyl wall
    if you want to trust a 45 dollar part to hone your own cylinders be my guest..... id wanna see it to believe it.....
    Northwest Georgia
    you dont have to balance it but please hone it for the sake of your rings. Hone job should be less than 45$.
    BOOSTED GSR/HYBRID
    ON THE TRACK
    im going to get done right thanx for the info.
    To 942JZGTE 93H22ACX's Avatar
    i'd balance it and hone it if you want it done right. a few grams at 7500-9500rpm is alot of weight IMO
    94 Supra= 500rwhp
