Results 1 to 19 of 19
Thread: Light weight UnderDrive Pulley.
    Southside Ridin HATCH
    Default Light weight UnderDrive Pulley.
    I've been told to get an underdrive pulley by some of my homeboys, but on the other hand some say no.... what do u guys think? should I get one or no?
    Acworth
    and get a huge wing!
    Acworth
    what else is done to the car?
    header,exhaust,cai,I manifold, throttle body. light flywheel.!
    Acworth
    if you are running an audio system you will drain your battery. if you aremgoing all motor then it can help a little
    Drain the battery? HOw?
    Acworth
    it UNDERDRIVES your other components like the alternator- thus draining your battery if you are running a large audio setup. If you don't have subs or any big draw of power then you are ok.
    Id read up a bit more them make your decision
    well i got a system soo i guess fuck it for now.
    BUNG
    Jan 2003
    Newnan,Ga, USA
    Assuming a system will drain a battery, if the car is running a Underdrive pulley might be jumping the gun. What kind of amperage is the system running? It is quite possible to safely run a system on an Underdriven alternator, there are too many unknown factors to accurately answer the question.
    In terms of performance, the gains are minimal anyway. I agree with JDMjames, read up some more and decide if its really worth the money to begin with.
    Single... but looking.
    02 WRX patrick4588's Avatar
    warner robins
    could always get the underdrive pulleys and just wire up a spare battery in the trunk for your system...
    You could also run it with Optima battery. I've done it before, worked just fine. I had UR crank pulley, power steering pulley and alternator pulley.
    D300s + MB-D10 |D90 + MB-D80 | 35mm f1.8G | 50mm f1.4D | 85mm f1.4D | 18-200mm VRII | 80-200mm f2.8D 2 rings| Tokina 100mm f2.8 Macro | Tokina 11-16 f2.8 | Kenko 2x TC | SU-800 | 2 x SB-R200 | SB-600 | SB-900 | Cybersync
    BUNG
    Jan 2003
    Newnan,Ga, USA
    Extra battery's mean extra weight. Adding that much weight takes from whatever performance the pulley added. I understand the motor has less mass to move, and the benefits in throttle response, quickness of revs, but ultimately i think the original posters intentions are to have a faster car...
    Ultimately read up, maybe even find another modification inthe same price range and run with that. Save up and gets a cam(s) IMO...
    Do you have a stock motor?
    Nissan Enthusiast
    Loganville
    Quote Originally Posted by deady
    Quote Originally Posted by Black4DrEK
    If he was worried about weight, he wouldn't have put a system in.
    99 Infinti G20t w/ Primera Parts and a few other small things
    BUNG
    Jan 2003
    Newnan,Ga, USA
    i thought about that while posting, and knew it would be brought up. Without further information this thread should be over.
    None the less, an extra battery ( depending on the system ) could weigh every bit as much as the system itself. Regardless, we're comparing the car how it sits now, to how it would after the pulley install...
    Nov 2003
    Quote Originally Posted by xbn83
    the alternator pulley is smaller to compensate for any loss of the other pulley
    Mountain man green91's Avatar
    Dahlonega, Ga
    if youve got a b16 ive got a lightweight pulley ill trade even for a stocker
    YEAH! bRiAnMcIvIcS's Avatar
    Douglasville
    If you wanna gain an extra 5hp go for it. But you should lose the system if you are worried about speed.
    everywhere & nowhere
    I love the internet. Tons of BS information. Here is the bottom line. Now - if you have a HUGE, and I mean HUGE audio system then it's possible that it will cause a strain on the alternator WHEN the system is really pounding. HOWEVER, modern alternators have this thing called a voltage regulator built in that compensates for this. How do I know? B/c I ran Air Ride on a stock CB7 w/ not 1, but TWO 3/4 horse VIAIR compressors and when they kicked on, literally in less than a second the regualtor did what it was supposed to do and bumped up the amps. With that said, I will tell you this.... MAKE THE CHOICE between speed or audio. I am a musician, so I always have a system that imaged and staged correctly, but you can get that w/ replacing the door speakers and having an amped deck. Awesome sound, w/ none of the weight of heavy ass subs.
    Now - those are the FACTS - here is some OPINION. Lightened pullies > underdrive pullies. Weigh your underdrive pully against the weight of your stock pulley - u might be in for a surprise.
    If you have your heart set on audio, then call this guy - he is the END ALL to alternator issues and can beef up your stock unit. Good luck:
    www.mralternator.com
    /thread
    Where Am I
