Thread: 93 Ex with 96-00 JDM vtec motor HELP!!
    Senior Member DustnU's Avatar
    I'm on a boat!!
    Default OBD1 to OBD2 HELP!
    I have a 93 Ex coupe that I'm putting a 96-00 JDM D16 vtec motor and trans in. I know the dizzy wires are different and some sensors, can I just use z6 dizzy and the p28??? What other little things do I need to change?? Thanks in advance IA.
    Work in progressneed slicks!
    Lindale aka B.F.E!!
    you can use the z6 dizzy and p28 as long as u stick w the obd 1 harness...but you also have to change the injectors as the 96-2000 are obd2a and injectors have different plugs...
    Only thing you have to change is
    dizzy
    ecu
    fuel injectors
