Results 1 to 27 of 27
Thread: Horrible engine noise
    2.3 Evo 8
    Guest
    Default Horrible engine noise
    My friend picked up this mustang with a $30,000 system in it and it has horrible engine noise when you turn on the radio.
    Who should he take it too to fix this problem?
    Southside of The Jungle
    What does the engine noise sound like? Systems drag alot of juice which could be causing engine noise
    02 WRX patrick4588's Avatar
    warner robins
    having improper settings on your head unit can cause some noise.
    GCO Member
    NRA Member
    warner robins
    so will having a bad ground on the head unit or amp. running cheap rca cables or having them close to the power wire will cause noise. there are lots of variables to check. if you dont want to do it yourself, just take it to any audio shop
    GCO Member
    NRA Member
    Hiram, GA
    WHAT?!?!?!?
    Could be a bad ground on any of several components. Some type of ground loop can also cause it. Cheap RCA's too close to a main power wire can cause noise.
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    $30,000 system... i would think with that kind of investment it would be installed and set up properly to avoid any interference.
    Who knows?
    no accord
    alpharetta
    traffic jams inn buford, they built the car
    RESIZE PIC PLEASE
    warner robins
    last car i had to fix with static was because of improper settings on the amp. they had the gain on the components turned up waaaay to high and you could hear static with the volume all the way off. backed the gain off and retuned it, works perfect now. this was with the car off as well.
    GCO Member
    NRA Member
    no accord
    alpharetta
    engine noise can be alot of things not always the install, sometimes it is a bad RCA, could be a bad ground, a bad radio. we had a car that came in and had horrible engine noise and we did everything, but it didnt go away until we changed the pioneer radio and put a panasonic in, no more noise, not to say panasonic is better because i have had engine noise with a panasonic aswell. a quick fix would be to put ground loop isolators, but i do not reccomend that for the mustang because it has soo many amps and thats a lot of isolators...
    RESIZE PIC PLEASE
    totaled xb SuperBox's Avatar
    I used to work at Traffic jams and the common thing that I ran in to with fords was the factory ground was not good to start with. We started to run a ground 4g to og wire from the neg terminal from battery to the chasis. Also. ford uses a lower voltage signal for the amp turn on wire, so you have to put a resistor in line to do away with pops. Recheck your grounds. That is where I would start.
    RIP Val
    no accord
    alpharetta
    on that mustang wires were ran from the door straight to the amps, the factory amp was taken out because it was not running anything
    RESIZE PIC PLEASE
    Duluth, G-nett
    make sure that the rca wires are not ran together with the power cable. i always run the power wire on one side of the car and the rca on the other. grounding is the main culprit on engine noise.
    no accord
    alpharetta
    their is a seperate battery in the trunk that runs the amp's, not ran with the rca's
    RESIZE PIC PLEASE
    Hiram, GA
    Quote Originally Posted by sina518
    I have a strange feeling that tracking down that noise is going to be a cast iron bich.
    if it has a pioneer deck in it..start there..if not ,get rid of the bull**** amps,and if that dont work burn it to the ground..
    just ****in around..here ya go
    Level 1: Check out the Amplifier(s)
    After you have determined that there is noise in the system, determine
    if the amplifier is causing the noise. To do this, mute the signal at
    the inputs to the amp by using shorting plugs. If there is no noise,
    then the amp is fine, and you can proceed to level 2. However, if
    there is noise, then use a test speaker at the amp's output. If this
    stops the noise, then the problem is originating in the speaker wiring,
    or the passive crossovers. Check to make sure that none of these are
    shorting with the body of the car, and start again at level 1. If
    noise is still present when using the test speaker, then there may be a
    problem with the power supply on the amp. Try connecting an isolated
    power supply - if this does not get rid of the noise, then there is
    something seriously wrong with the amp, and it should be replaced. If
    the noise goes away, then there may be a problem with power supply
    filtering or isolation. This can be fixed by changing the amp's ground
    point or by adding external supply filtering.
    Level 2: Reduce the System
    The amps have been determined to be noise free. If you have any
    processors between the head unit and the amps, disconnect them and
    connect the head unit directly to the amp. If this gets rid of the
    noise, then one (or more) of the processors must be at fault, so
    proceed to level 5. Otherwise, try running the signal cables over a
    number of different routes. If you are able to find one that does not
    produce any noise, permanently route the cables in the same manner, and
    proceed to level 5. If not, then you must isolate the head unit from
    the car's chassis (except for its ground!) - don't forget to disconnect
    the antenna, since it is also grounded to the car. If isolating
    the head unit does not solve the problem, the move the grounding point
    of the head unit. Hopefully the noise will be gone, and you can
    install the head unit with a quiet ground and proceed to level 5,
    otherwise go on to level 3.
    Level 3: Move the Head Unit
    The amplifiers are fine, but moving both the ground for the head unit
    and the signal cables does not solve the noise problem. Take the unit
    completely out of the dash, and put it on either the seat or carpet,
    and run new signal cables to the input of the amp. If this solves the
    problem, re-install the head unit, one step at a time and skip to level
    5. But if the noise persists, then move the head unit as close to the
    amp as possible and use the shortest possible signal cables. This will
    verify that the original signal cables are not causing the problem -
    assuming the noise is gone, reinstall the head unit one step at a time
    and go to level 5. Otherwise, there may be a problem with the power
    filtering for the head unit. As with the amps, power the head unit
    with an isolated power supply (again making sure that the head unit
    isn't touching the car's chassis at all). If the noise goes away, you
    can add power supply filtering or an isolated power supply; go to
    level 2. But if the isolated power supply does not solve the problem,
    then you can either replace the head unit and go to level 2, or check
    the car's electrical system in level 4.
    Level 4: Testing the Car
    There does not seem to be a problem with either the head unit or the
    amplifier, and the car's charging system is suspect. To see if this is
    the case, we can use a system in a car that is already known to be
    "quiet." Bring both cars together as if you were going to jump one,
    and use jumper cables to connect the two batteries. Start the engine
    of the car with the noise problem, and listen to the "quiet" car's
    system. If the noise does not go away, there is a SERIOUS problem with
    your car's electrical system (possibly a bad alternator). Have a
    qualified mechanic check the charging system out. If there is no noise
    in the "quiet" car, then the "noisy" car's charging system is
    definitely quiet, so continue with level 5.
    Level 5: Adding Signal Processors
    We have proven that the amplifiers are good, the head unit is good, and
    the car's electrical system is good. Now we need to reconnect each
    signal processor. Repeat this level for each signal processor used in
    your system; if you have added all of your signal processors, and
    there is no longer any noise, CONGRATULATIONS! You've removed the
    noise from your system! Connect the signal processor. If there
    isn't any noise, then go on to the next signal processor. Otherwise,
    try re-routing the signal cables. If this cures the problem, then route
    them permanently over the quiet path, and install the next processor.
    If not, then isolate the processor from the car's chassis except for a
    single grounding point. If this works, then permanently isolate the
    processor, and move on to the next processor. If isolation does not
    help, then advance to level 6.
    Level 6: Processor Isolation Tests
    Now, noise enters the system when one particular processor is
    installed, but regrounding it does not help. Move the processor very
    close to the amp, and check for noise again. If there isn't any, then
    re-install the processor, carefully routing the cables to ensure no
    noise, and continue at level 5 with the next processor. Otherwise, use
    an isolated power supply to power the processor, making sure that no
    part of the processor is touching the car's chassis. If this solves
    the problem, then consider permanently installing an isolated power
    supply or possibly a 1:1 transformer, and go to level 5 with the next
    processor. Otherwise, separate the processor and isolated power supply
    from the car by many feet and re- test. If there is still noise, then
    there is a serious problem with the processor's design. Get a
    different processor, and continue at level 5 with it. If separating
    the power supply and processor from the car does solve the noise
    problem, then either the processor is damaged, or your tests were
    inaccurate. Repeat level 5.
    The poorest rich guy myyellowspec's Avatar
    Dallas, Ga
    Wow ^^^ very nice. A if I spent $30,000 on a system my car would fly and it certainly would not have engine noise. If this is a real question you should tell your friend to kill himself for wasting so much money for a poorly installed system.
    89 EE Wagon
    2.3 Evo 8
    Guest
    Thanks BAD@PPLE.
    Quote Originally Posted by myyellowspec
    He didn't waste anything. He bought the car with the system already installed moron.
    no accord
    alpharetta
    If this is the Mustang that was done by/R2B2/Traffic jams the system was never completed. the lady couldnt pay her balance off their for it never got finished
    RESIZE PIC PLEASE
    2.3 Evo 8
    Guest
    Everything is being finished now. Do you recall what was lacking "system wise" that needed to be finished for the stereo.
    We can take it to PM's if you like.
    no accord
    alpharetta
    honestly dont remember i just know it wasnt complet because she wanted the car at daytona spring break nationals and everything got rushed and by the time she got back and put it back in the shop for it to be complete she didnt have money to pay it off so it sat there
    RESIZE PIC PLEASE
    Dallas, Ga
    So the entire car was $30,000? Or did your "friend" get like 15 tv's in their bumper and a wheatgrass juicer in the trunk lolol. "You've got to pimp my riiiidde" hahahahahaha.
    89 EE Wagon
    no accord
    alpharetta
    the whole car was rebuilt from the ground up the only thing stock is the shell and the frame
    RESIZE PIC PLEASE
    still a mustang
    no accord
    alpharetta
    ^^^^ i agree, but for the price it got sold for cant really complain
    RESIZE PIC PLEASE
    well considering im not privied to that info i wouldnt know
    2.3 Evo 8
    Guest
    Crack rock prices.
