Results 1 to 40 of 71
Thread: mr.vteckidd what do u think
    Default mr.vteckidd what do u think
    ok im gonna do my b16 swap in about a month and i want to boost it. but i would like to boost it without bottom end work and head work right now. how much boost is safe with you tuning it and how much power can be made safely. thanx and what do u think about ssac for a low boost project like this. i will eventually do botom end work and head work but that will be in about 9-10 months lmk what u think.
    DC5-R
    Gwinett
    7-8 psi should be ok
    yeah thats what i figured on boost but i wanna know what kinda of power i can make with a good tune
    All bark, no bite.
    The weakest point in your setup will be that SSAC kit.
    Main Stream can fab, tune, and install a very reliable turbo kit for you for about as much as you'll spend replacing parts on your SSAC kit.
    Speaking from experience here... do it once, do it right.
    Edit: But you should be able to do 250whp all day long on stock block. I've seen people push the envelope at 300whp, but don't expect it to last if you beat on your car a lot.
    yeah i was thinkin about it i may as well get a good kit from them since i do plan on doin botom end work and head work in the future thanx iloveboost when u gonna take that teg to the track i want to see some 1/4 mile #s
    All bark, no bite.
    I'm hoping soon. Need to find some slicks first.
    yeah thats what i was hoping to here i want about 250 but i want it to be reliable and i dont dump the clutch at 6000 at every stop sign and my shit gets oil change at every 1500- 2000 miles so i take care of it thanks
    All bark, no bite.
    If nothing else, at least replace the SSAC manifold.
    summit u know where it is and theres a set on drag wheels on here for sale too hurry up i wanna see it
    yeah i havent got the kit yet i will prolly just save that money and get mainstream to build me a kit
    All bark, no bite.
    Quote Originally Posted by jdmcrx12
    You'll be a lot happier if you go that route. That way, when you build the bottom end, all you've gotta do is turn up the boost and not replace your turbo kit, haha.
    yeah i will end upo doin that but it will take me longer to get it done but it will be worth the wait and one day i hope to be pushing #s like u
    how much does mainstreams turbo kits start at installed
    check these slicks out they would work the wheels look good too
    http://forums.importatlanta.com/showthread.php?t=67183
    my .02
    for a cheap boost project SSAC is fine, just be prepared to fix it if it breaks. If your prepared for that, then go for it.
    B16s dont last past 230whp. They have small ringlands and are very PRONE to BREAKING. EVERY B16 that we do with a turbo lasts 6months, then they come back with cracked ringlands. Its just a problem the b16 pistons have. nothing you can do about it.
    will it last if i put low compression pistons and good rods in it or do the after market pistons have the small ring gland too should i just ride my b16 and when i boost it get a ls blosk and do ls/vtec i would rather stick with the b 16 if possible
    and i think i woul;d rather get one of yalls kits than take a chance on fuckin somthin up bad
    the only way to solve the "ringland problem" is :
    Cheap way:
    Put GSR pistons in it, they can hold 300whp, lowers compression to 9:1
    Expensive way:
    Buy JE,CP, Wiseco Pistons an Eagle rods
    Rods an pistons run $800, Machine work about $300
    WEST_SIDE
    Quote Originally Posted by Mr. Vteckidd
    Cheap way:
    Expensive way:
    if you gonna go the expensive way might as well resleeve it . since its going to be apart . save extra cash make it last
    also depends im pretty sure your gonna get boost happy safer int he long run
    yeah i would rather go the exspensive way but the sleeving is outa my price range but in a year or so i may get it sleeved but i might go ahead and do botom end work and shit then boost it thanks for the opinions
    if you dont plan on making over 500whp, you dont need sleeves
    yeah i dont plan on makin over 500 whp i want around 450 whp if i put low comp pistons in it and rods how much do yalls turbo kits run lmk thanks
    WEST_SIDE
    LOL .i tought your goal was around 600WHP like another member on here .. .my misunderstanding .
    ARP HEAD STUDS AND THICKER HEAD GASKET. HKS HEADGASKET DROPS UR COMPRESSION TO AROUND 8.6 WITH STOCK B16 PISTONS. INLINE PRO SELLS A 2 MIL HEAD GASKET THAT DROP UR COMPRESSION TO LIKE 9.0 RUNNING 15 POUNDS ON STOCK MTR AND UPGRADED FUEL SYSTEM A HATCH MADE 326 TO THE WHEELS.
    I HAD THE HKS HEAD GASKET A SPIKED 16 POUNDS A FEW TIMES AND WHEN I TOOK IT APART THE PISTONS WERE FINE. MINE BLEW UP BC OF OIL PUMP FAILURE (SPENT BEARINGS AND SMOKED BC OIL CHANGES ARE WAY OVER RATED)
    haha oil changes over rated damn the thick head gasket deal sounds nice but i would rather be safe and run like 10 lbs like that. but i dont know i think im gonna ride the stock motor, no boost for a while, then go get a turbo kit made by msp. and run like 6 lbs for a while then do the botom end work and head work. but when the time come ill let every one know how it goes.
    thanks everyone
    thanks everyone
    GOOD IDEA. 5 POUNDS WITH THAT DAMN HKS HEAD GASKET FELT LIKE A STOCK B16. LOL!!! I SAY U SHOULD BOOST IT, BLOW IT UP, BUILD IT AND REALLY BOOST IT. THAT WAY U CAN LIVE ON THE EDGE/CARELESS IF IT BLOWS UP BC UR GONNA BUILD IT NE WAY. LIKE THIS AT 15 PSI ON STOCK B16: OOOOOOHHHH SSSSHHHHHII *BOOM!!* DAMN.
    All bark, no bite.
    You've got a B16 head. You won't need headwork for 450whp.
    Just focus on the turbo kit and getting some forged internals.
    yeah i wish i could afford 600 hp but i want need cams springs nothin for 450 whp
    yeah i would like too have 600 but 450 is more than enough for a street/strip car and its more in my range but it will still be a while before i get that much
    IF U MAKE 450 WHP, 600 IS ONLY A BOTTLE, A FEW NIK NAKS AND A BUTTON AWAY. LOL!!!!
    WEST_SIDE
    sounds good keep us updated
    yeah i will and im not sprayin on top of a turbo i dont care what ne one says i anit gonna do it
    WEST_SIDE
    i luv the bottle, still bottle feed
    DNT BE A SISSY, CMON. OK JUST ONE TIME WITH A 50 SHOT?
    DC5-R
    Gwinett
    you say that now, but if you ever got on the bottle, I bet you won't leave it
    Quote Originally Posted by krucial7integra
    I LEFT IT. I ADMITT I ALMOST SHAT MYSELF EVERTIME I SQUEEZED IT BUT IT WAS FUN. ILL DO IT AGAIN THOUGH, JUST NOT WITH A STOCK MTR.
    IA's Transformer God obd1kenobi's Avatar
    29th Chamber
    Hey Hey Squeeze it Nigga!
    GeckoSquad / Skull Platoon
    yeah ur right thats why im not gonna try it cause i dont wanna blow that shit up
    UNLIKE ME, GET URS TUNED. I THREW THE KIT ON MY CAR IN LIKE 2 HRS WITH THE HELP OF A FRIEND. HE WAS WROKING IN THE BACK AND I WAS WORKING IN THE FRONT. SPUR OF THE MOMENT SHIT USUALLY END UP BRAKING, GUESS I GOT LUCKY.
    DC5-R
    Gwinett
    ^^ it was worth a shot though
