Results 1 to 12 of 12
Thread: ls turbo?
    Enterprise AL,
    Default ls turbo?
    ok so im going to run a built b18b1 block with crower stage 2 turbo cams at 12 psi what power do i need 2 be looking for also what pistons and compression 2 use? its a t4 63wheel trim
    Certified Gearhead miro_gt's Avatar
    you could be looking anywhere from 0 whp (blown engine) to like 500+ whp with gt42 and 15:1 comp pistons running on methanol, and possibly adding NOS to the setup.
    or the other way around would be to tell what turbo you're using, or to tell what whp you want...
    either that ^ or there are some new turbo cams that come at 12 psi that I know nothing about
    Enterprise AL,
    Yep....I got nothin Pickleteg's Avatar
    Clarksville, TN
    How much power are you looking for.......12psi is not power level...
    95 Teg SE Synapse A/C ramhorn kit, 276whp, 210wtq
    09 Si Sedan...some bolts ons....
    Woodstock
    What is built? I have a b18b1 with forged pistons and rods, but not sleeved. On the stock LS head and a t3/t4 I am around 240ish @ 11 PSI. Mine needs a aftermarket MAP sensor so I can up the boost.
    Enterprise AL,
    i want around 300 whl let me know what ya think
    sleeve me please?
    monroe
    Quote Originally Posted by Slomaro Z28 View Post
    you serious hmm doesnt make since to me i was running 8 lb. on a gsr forged internal and made 289 with vtec off and 307 with vtec on then came the 3 bar map sensor and that was fun for a while but not reliable?
    sleeve me please?
    monroe
    is what you need to do is save your money use all name brand parts so you dont F*** it up PUT A GSR HEAD ON IT SO YOU HAVE VTEC AND THAT HEAD IS LESS PRONE FOR DETONATION AND RAISES THE COMP .2 I NO THATS A LOT RIGHT forged rods and pistons at 9.5:1 about a 60 trim turbo garrett turbonetics or precision with a cheap ebay intercooler and piping setup whatev bov you want name brand tial 38 mm wastegate and a log manifold and sell all your leftovers then all you need is a 3 bar map sensor and you can get almost to 500hp as long as you have the right clutch and everything else is right but relistically low 4's at 18 lb
    Woodstock
    Quote Originally Posted by jap_racer1 View Post
    You had a better flowing head
    sleeve me please?
    monroe
    true true your right?
    Quote Originally Posted by rsxdc52002 View Post
    now we're getting somewhere
    thought I dont know what T4 turbine you're using, with about stock compression pistons your power goal is fine for a reliable setup, as long as you're using parts that dont break easy.
    P.S.
    log manifold is the dumbest manifold ever created. Look elsewhere
    Yeedeedee le se NovaScotia's Avatar
    12psi on a built motor is a waste of everyones time and your money. for 300 wheel youre looking at 1.2-1.5bar. thats on a 6067 or equivalent
