Results 1 to 15 of 15
Thread: WTB: OBD2 99-00 Si dizzy
    Got Rice? 93dituneex's Avatar
    Newnan, Ga
    Default WTB: OBD2 99-00 Si dizzy
    Need an obd2 99-00 si dizzy A.S.A.P. so if anybody has one let me know and we'll work a deal.....
    ....:1993 Electric Pearl Blue Civic:....
    93 Civic EX R.I.P. 05/16/06
    Newnan, Ga
    ttt somebody
    Newnan, Ga
    up
    BIKINI BOTTOM
    cant use a obd1 dizzy and repin it?
    SNITCHES! HAHAHAHHAHAHAHHZHAHSDLKSJFSAGgDS
    Newnan, Ga
    nah i dont think so cause i'm pretty sure one has teo plugs and other has one i do believe, but i could be wrong
    BIKINI BOTTOM
    OBD2 got 2 plugs right?
    OBD1 is the same thing but in one plug, you pull 2 wires out and connect it. thada
    Newnan, Ga
    thanks man
    Newnan, Ga
    nobody has a 99-00 si dizzy or alt?
    Newnan, Ga
    come on yall, somebody gotta have one i can get....
    Master of the G2 Integra cardesignz's Avatar
    Cumming/Alpharetta, GA
    I have a 2001 CRV dizzy - from my B20Z swap that I will not be needing as I am staying OBD1. I don't know if the VTEC and NonVTEC are different or not, but it is OBD2 and B series.
    Newnan, Ga
    hmmm....not sure, if it will work how much u want for it?
    I can do $100. I haven't had time to find out whether the VTEC and non are any different. I'll probably look it up later on and let you know if you don't find out first - I've got to fo fix my parent's Accord right now.
    From what I got searching, it won't just bolt up, but can work with modification. It is the bolt holes that are not the same due to the VTEC solenoid. It is possible to cut off the part that gets in the way of the solenoid and all, but it sounds like you end up with the dizzy being held on by one bolt, so you probably don't want to do that. If you have a bad SI dizzy, it might be possible to just swap the internals (probably fairly simple), but you probably don't want to do that either. Good luck on the search - if you get in a bind and want to do some modifications/swapping internal dizzy parts, let me know.
    Newnan, Ga
    thanks man, my buddy was telling my something about the using non vtec ones and i'mma see what he says and get back to ya thanks again
