Results 1 to 7 of 7
Thread: ef or da mounts
    in dabuilding
    Default ef or da mounts
    i need mounts to put a b in my ef ive heard stock da mounts will work if u have these hook me up im low on money but i need these ASAP!!! pm me
    in dabuilding
    3 hours and nothing???? huh.....
    Default mounts
    i have the driver and passenger side mounts for a b series swap and also an avid shift linkage for swap into ef.
    Rome,Ga
    ive got the driverside mount but only the part that goes to the block its aftermarket i will take 10 bucks for it. its red
    Southside of The Jungle
    Dont waste your time just buy avid mounts for like 170$ other than that if you use Da mounts you will have to drill out tranny side mount that mounts to frame and move it forward.Which is the old school way before they created the correct mounts.Its up to you if you trust your welding ability But I advise you to just spend a few bucks and do it right.
    i have some crx b series mounts, idk if they are the same as ef/da...all of them are poly. $50
    Mr. G-Spot S13_Chody's Avatar
    da rear tranny mount and da shift lingages call me 404 915 1951 $40 for both
