Results 1 to 6 of 6
Thread: IS300 PFS Stage II Turbo Kit
    Default IS300 PFS Stage II Turbo Kit
    PFS Stage II kit minus the HG and Tec3. Asking $4500 obo. Located about 55 minutes outside of Atlanta.
    Information on PFS Stage II kit:
    PFS divided pulse cast-steel exhaust manifold, 45mm SS TurboSmart wastegate, Turbo Smart Blow off valve, 60-1 Hi Fi series turbocharger, 3" mandrel bent SS downpipe back to the rear axle, 3" High flow catalytic converter, Custom Cool Charge air intake systen with K&N Hi Flow filter, PFS high volume fuel pump upgrade · Custom Electromotive TEC³ engine management system. · PFS Electronics Interface Module · Silicone hoses, clamps, heat shields, and all additional components required for a successful installation.
    The Stage II kit includes all of the above components as well as a 3mm metal head gasket, Turbosmart boost controller, large front mount intercooler with 2.5" stainless steel piping kit and larger fuel injectors. This lowers the static compression ratio to a boost-friendly 8.6:1 for more horsepower output on pump gas. Typical installations result in over 400 RWHP at 15 psi of boost.
    TTT
    San Antonio, TX
    no links
    post the info here or it will be deleted
    twoONEoh
    Updated, sorry about that.
    Stop Messing with my ISH
    kennesaw
    location?
    -zen motors-
    at the shop
    he lives about 40 minutes north of kennesaw
