Results 1 to 30 of 30
Thread: 1991 MR-2 with 2GR-FE Lexus V6 swap
    Oct 2010
    North AL
    Default 1991 MR-2 with 2GR-FE Lexus V6 swap
    Here's a chance to own a rare 2GR-FE V6 swapped 1991 MR2 turbo. This is the most sought-after engine swap to date. This swap was performed less than 2 years ago and has had zero problems including a few road trips. This is a proven car and very reliable and there are only a dozen or so of these swaps in the country now. There was no expense spared in building this car. Wiring was professionally done and looks factory. At car shows people think the engine is stock and just keep walking.
    The car has been garage kept since I bought it. The steering is tight. The Engine is 100% stock so the motor is very reliable. The interior is nice overall. It has cloth seats which are slightly worn (driver side more than passenger), but for the right deal, I can include some brand new Corbeau FX1 Pros with mounts. The paint isn’t perfect but looks great from 5Ft. It could use some wet sanding/buffing. The front bumper has some paint chips on the bottom driver corner and its missing the front lip. If you are looking for a mint condition Body Mr2 this isn’t perfect but looks great! No rust problems. In addition to the performance, I have averaged 23mpg with mixed city/hwy driving.
    PRICE: $9500 without extras.
    1991 Toyota MR2 3.5L V6 2GR FE - Clear AL Title in my name
    Chassis
    SW22 (Turbo/Sunroof)
    143Kmiles on chassis
    Sunroof (RARE)
    Paint CODE B21 Blue + Blue Ice pearl in clear coat.
    Engine
    -3.5L 2GR FE V6 (Around 280HP 260TQ at the wheels)
    -40,000 Miles (5,000 miles since the swap)
    -Donor car was a 2007 Lexus Es350
    -Weapon R Intake Pipe with Large Filter with Rain/Heat Shield
    -Only Used Mobil 1 Extended life Oil Filter and Extended life Full Synthetic Oil
    -TSB for all metal oil line done
    -OBDII Hook up for reader in Cabin behind driver’s seat
    -Drive by wire Denso Pedal
    -Wiring professionally done BY MR220V (mr2oc.com)!
    -ECU MOUNTED IN REAR TRUNK (2006 RAV4 SPORT)
    Air Conditioning
    -2007 ES350 Compressor 40K miles
    -New OEM Dehydrator
    -R134A
    (Everything is there the Compressor Cycles but only blows ever so slightly cool a professional A/C person should be able to make it work)
    Transmission
    -95 LSD E153 Transmission Only 5,000 miles on it. Bought brand new from dealer
    -Half shaft/stub Shaft from 95 only 5k miles Was bought brand new from dealer
    -Axles were upgraded with the ATS CHROMOLY AXLE UPGRADE KIT
    -Solid urethane Engine mounts
    -Red line MT-90 GEAR OIL
    Clutch
    -ACT 6 Puck Sprung racing clutch Torque Capacity: 499 ft/lbs / Load Increase: 32%
    -Fidanza Lightweight Aluminum Flywheel
    -Stainless steel clutch line
    -Only 5k miles
    Fuel System
    -Walbro 255 fuel pump
    -Aeromotive fuel pressure regulator with gauge
    -From new fuel filter to tank return all stainless braided fuel line and AN fittings
    -Only 5k miles all parts
    Exhaust System
    -Custom Shorty headers (GOUKY)
    -Dual exhaust with Magnaflow X pipe with flat black high temp paint.
    -Very quiet at idle and at highway speeds but does scream a little WOT.
    Suspension
    -Megan racing full coilovers
    -Energy Suspension Red urethane bushings All joints
    -Moog outer tie rod ends
    -New oem front inner tie rod ends
    -New oem rear tie rod ends
    -Roughly 5k Miles All parts
    Brakes
    -ABS Stock system
    -Rotora front and rear drilled and slotted rotors
    -Rebuilt oem calipers front and rear
    -Axis brake pads
    -Earls stainless steel brake lines
    -New OEM e-brake cables
    -Only 5k Miles
    Wheels/Tires
    -JDM Rays Engineering Payton Place Real 2 Piece Aluminum Rims. Zero curb marks!
    -Front 17 x 8 +38
    -Rear 17 x 9.5 +38
    -Tires Nitto 555
    -Front 225/40/17
    -Bridgestone Potenza
    -Rear 255/40/17
    Stereo
    -Pioneer head unit
    -New pioneer speakers
    Miscellaneous
    -Recalibrated tachometer
    -New rear wheel bearings.
    -New window moldings
    -95 front bumper
    -Clear corner lights
    -95 Taillights
    -New oem radiator
    -New Front Fender Linings
    -Brass Bushing Shifer Kit and shifter Cable end Kit
    -1 year old Battery
    Extras (depending on offer)
    -2 Red Corbeau FX1 Pro seats with rails (no harnesses)
    -Full set of 2005 Mustang GT wheels with Hoosier 245/45/17 slicks
    -Full set of VOLK GTSP 17 x 8, 17x 9 +45 with tires 5x 114.3
    -Full set of BNIB 94+ taillights with center panel and reverse lights
    -New set of OEM Toyota floor mats.
    -Interested in trades, especially trades plush cash. Looking for a four door car at the moment.
    Contact
    Text and email are preferred. If the add is up I still have it. I also have more pictures of the car for those of you seriously interested.
    Two five six six nine eight zero four four five.
    cmwicks@ gmail
    Most recent picture with the Volks and new ride height.
    I will sell the Volks separately. - $850 with tires... VOLK GTSP 17 x 8, 17x 9 +45 with tires 5x 114.3
    Corbeau Seats
    Jun 2009
    Little car big balls...how in the world did you cram that thing in there lol
    Oct 2010
    North AL
    Quote Originally Posted by Princedak View Post
    Its actually not that bad. There is as much room if not more around this engine than a 3sgte. The engine can be dropped and re installed in a day easily.
    Macon, GA
    that looks like a tight squeeze... nice looking car though! glws.... probably going to want a few more pics though
    Oct 2010
    North AL
    Quote Originally Posted by CptWitwiki View Post
    If you are interested in the car, contact me and Id be happy to send all that I have as well as take some more detailed ones.
    Thanks,
    Chandler
    you dont see that every day, i see you kinda know toyotas!!
    glws
    Wow! The 2gr is a STRONG engine in a big sedan, i can only imagine how much well this car pulls especially with a 5spd.
    GLWS!
    Oct 2010
    North AL
    GLWS!
    Its very impressive. Makes plenty of torque and the vvti takes care of the top end. Its been 12.8s in the 1/4 on street tires.
    Oct 2010
    North AL
    Bump for new pics.
    Photobucket is here: 2grfe MR2 pictures by wickscm - Photobucket
    mr2 problem twincannon26's Avatar
    douglasville
    very nice car!! impressive to say the least. good luck with your sale.
    86 MR2 4age, 86 MR2 20V, 84 MR2 3lc RHD, 01 MR2 Spyder, 92 SE V6 5spd Camry.
    so maybe i have an mr2 problem.....
    no chance in wanting my 1993 Toyota Starlet GT Turbo TRD.. RHD and 100% Legit and legal in the US.
    IA Member 5thgenlevi's Avatar
    Apr 2010
    Augusta, GA
    Dude.....this ^ get this. Holy shit
    i can ad cash if you feel it is needed after looking at the car. i think it would be close to a straight up swap.
    Oct 2010
    North AL
    Nice looking Starlet. Thanks for the offer.
    Oct 2010
    North AL
    Here are a few pictures of the exhaust. I had a hard time trying to make duals fit so I used a buddys Busher racing 3" can. Its all stainless. Sounds nasty WOT. Also dropped about 30lbs with the new system
    Part of the old
    Oct 2010
    North AL
    Drove it to work today. This thing is a blast to drive. Makes my gto feel a little barge-like.
    Oct 2010
    North AL
    Bump for new wheels and wheel stud install!
    Not gonna lie, i want this car LOL.
    Oct 2010
    North AL
    Oct 2010
    North AL
    Got the 93 lip painted and installed last night. Ill get some more pictures of the car cleaned up this weekend, but I know some of you asked for pics of the lip.
    And one of the paint chipping :'( I have a pint of paint to go with the car but I dont plan on doing any paint work before the sale.
    Oct 2010
    North AL
    Few more I took at work last night. It rained the day before so its a little dirty. They are a little blurry. I think the phone camera lens was dirty.
    Oct 2010
    North AL
    bump for turkey week!
    Diggin' this car!
    Senior Member SHHHH's Avatar
    Aug 2009
    New York Upstate/ Newnan,GA
    Neat little car
    2013 GT500
    1989 Mustang 5.0
    Oct 2010
    North AL
    Thanks guys. I like driving it a lot. Ready to start on some other stuff though.
    Apr 2010
    Augusta, GA
    thank god you changed the exhaust from that horrible center exit.
    Oct 2010
    North AL
    I agree it was terrible.
    Just put a new ACT 6 puck clutch in as well as full fluid change.
    Oct 2010
    North AL
    New clutch, fluid change, and poly motor mounts. Lots of interest but no transaction yet.
    Trade kswap ek hatch
    Oct 2010
    North AL
    Sold
