Results 1 to 3 of 3
Thread: D16z6 - 50 trim t3/t4 - Built bottom end - Pump Gas Dyno Tune
    Moderator Spent's Avatar
    Mar 2010
    Greenville, SC
    Default D16z6 - 50 trim t3/t4 - Built bottom end - Pump Gas Dyno Tune
    Chad brought us his Civic for a head gasket installation and retune. He had purchased the car already built and running, but noticed that it was running lean in higher RPM. A compression test showed that Compression Numbers were less than optimal, so we removed the head and found 2 cracked sleeves, and 3 broken pistons. We sourced Chad a new block, installed a block guard, new pistons and rods, and reinstalled the engine.
    Here is the setup:
    Stock D16Z6 head
    D16Z6 Block
    Precision .60/.63 t3/t4 SC50 trim turbo
    Eagle Rods
    10:1 CP Pistons
    Supertech Block Guard
    Skunk2 Intake Manifold
    60mm throttle body
    RC 750cc injectors
    Jackson Racing cam gear
    GO-AUTOWORKS Manifold
    Tuned on Crome Gold
    Here is the chart at 14-15 psi. The car had made more power before, but Chad decided to turn the boost down for longevity.
    ECU chipping services & one stop tuning for: Crome Gold, S300, K-Pro, Flashpro, AEM EMS, AEM F/IC, Haltech, Motec, PowerFC L & D-Jetro, Nistune, Utec, Unichip, Cobb AccessPORT, SCT, DiabloSport, HP Tuners, Tweecer, Big Stuff, FAST, Map-ECU,TurboEdit, C.A.T.S, Megasquirt, Microtech, DSM Link, CPE Standback, SAFC, VAFC, NEO
    Hubert Murias
    [email protected]
    864-699-9436
    Twan Jdm94Coupe's Avatar
    Fairburn
    nice torque! u seem like a good guy, i wish u were in ga...... good luck w/ your business
    Mar 2010
    Greenville, SC
    Thank you kindly.
    Hubert Murias
    [email protected]
    864-699-9436
