IA members save $50 on turbo applications. Must provide Member name if calling and mention the discount.
Tuning rates are flat and are not affected by how much time your setup requires.
Import Tuning Rates
Crome Gold, Hondata S300, NisTune, UTEC, Megasquirt, Microtech, Map ECU, SMT, Unichip, DSM Link, Cobb Accesspor, CPE Standback
- $350 Flat Rate - NA with bolt-ons (Aftermarket MAF Sensor add $100)
- $450 Flat Rate - Turbo / Supercharged / nitrous injected
Hondata K-Pro, FlashPro
- $375 Flat Rate - NA with bolt-ons
- $475 Flat Rate - Turbo / Supercharged / nitrous injected
AEM EMS, PowerFC (L & D-jetro),Haltech, Motec
- $449 Flat Rate - NA with bolt-ons
- $549 Flat Rate - Turbo / Supercharged / nitrous injected
- Chip OBD1 Honda, Nistune, DSM ECU: $50
- Vtec Conversion: $30
Domestc Tuning Rates
Dyno-tune rates for Tweecer / Big Stuff / FAST / C.A.T.S / Haltech / Motec/ AEM EMS/ MAP-ECU/ Megasquirt ECU's:
- $500 Flat Rate - NA with bolt-ons
- $550 Flat Rate - factory supercharged / nitrous injected / cam'd
- $600 Flat Rate - aftermarket supercharged/turbocharged vehicles
Dyno-tune rates if you already have an SCT X2, X3, or Livewire flasher or for tuning on C.A.T.S, HP Tuners:
- $550 Flat Rate - NA with bolt-ons
- $600 Flat Rate - nitrous injected / cam'd
- $650 Flat Rate - supercharged/turbocharged vehicles
Dyno-tune rates with SCT Flasher purchased at time of dyno-tune session:
- $850 Flat Rate - NA with bolt-ons
- $900 Flat Rate - factory supercharged / nitrous injected / cam'd
- $950 Flat Rate - aftermarket supercharged/turbocharged vehicles
- Add $200 for SCT Livewire flasher
Dyno-tune rates with E-manage or Unichip
- $350 Flat Rate - Aftermarket Map/MAF Sensor add $100
- Chip OBD1 Ford & GM Ecu's: $60
European Tuning Rates
UTEC, SMT, Unichip
- $400 Flat Rate - NA with bolt-ons (Aftermarket Map/MAF Sensor add $100)
- $500 Flat Rate - Turbo / Supercharged / nitrous injected
AEM EMS, Moristech, Megasquirt, Haltech, Motec, Electromotive, Autronic, Xtreme Management System
- $500 Flat Rate - NA with bolt-ons (Aftermarket Map/MAF Sensor add $100)
- $600 Flat Rate - Turbo / Supercharged / nitrous injected
