Thread: 07 Gt500
    IA Member Boost67p's Avatar
    Default 07 Gt500
    450 stock hp SVT. I don't like the interior but the engine bay is sweet.
    2007 Gt500
    S281 soul's Avatar
    Gtown
    pure sex
    Its just a bodykit
    Body
    Construction Unitized welded steel body, aluminum hood
    Engine
    Type V-8
    Manufacturing location Romeo, Michigan
    Configuration Iron Block and Aluminum Heads
    Intake manifold Cast-aluminum with screw-type supercharger and air-to-water intercooler
    Exhaust manifold Cast iron
    Crankshaft Forged steel
    Throttle body Dual 55 mm, electronic
    Valvetrain DOHC, 4 valves per cylinder
    Valve diameter Intake: 37.0 mm
    Exhaust: 32.0 mm
    Pistons Forged aluminum
    Connecting rods Cracked forged steel I-beams
    Ignition Coil-on-plug
    Bore x stroke 3.552 x 4.165 in. / 90.22 x 105.8 mm
    Displacement 330 cu. in. / 5,409 cc
    Horsepower More than 450
    Torque 450 lb.-ft
    Drivetrain
    Layout Rear-wheel drive
    Transmission
    Standard (Type) T-56 6-speed manual
    Gear ratios
    1st 2.97
    2nd 1.78
    3rd 1.3
    4th 1.0
    5th .80
    6th .63
    Final drive 3.31
    Suspension
    Front Reverse-L independent MacPherson strut, 34-mm tubular stabilizer bar
    Rear Three-link solid axle with coil springs, Panhard rod, 24-mm solid stabilizer bar
    Brakes
    Type Four wheel power disc
    Front Brembo 14-inch vented and cross-drilled disc, four-piston aluminum calipers
    Rear Brembo 13-inch vented and cross-drilled disc, two-piston calipers
    Wheels and Tires
    P255/45R19 tires and 19 x 9.5-in machined aluminum wheels
    Exterior
    Wheelbase 107.1 in.
    Overall length 188 in.
    Overall width 73.9 in.
    Overall height 55.7 in.
    Track width, front/rear 61.9 in. / 62.5 in.
    Ground clearance 5.71 in.
    Interior
    Seating capacity 4 passenger
    Headroom
    Front row 38.8 in.
    Second Row 36.3 in.
    Legroom
    Front row 42.7 in.
    Second row 30.3 in.
    Shoulder room
    Front row 55.4 in.
    Second Row 45.0 in.
    Hip room
    Front row 53.6 in.
    Second row 45.2 in.
    Cargo Volume 9.7 cu. ft
    In the Fucking A
    Default mmmm
    I like it, I may just have to have one.
    Matt
    A day late, a buck short BufordŽ's Avatar
    Apr 2003
    Starin' at the world through my rear-view.
    I'm in love with the gauge cluster. Looks almost like an older VW gauge cluster though.
    My 2001 Acura 3.2CL Type-S
    Val for president!
    Yes, I would have voted for her.
    In loving memory of Valerie Antranikian.
