Results 1 to 40 of 48
Thread: Some pics of my Talon build...
    DOTCOM SpeedDreamz's Avatar
    alabama
    Default Some pics of my Talon build...
    Here are a few pics of my AWD Talon build. Thanks for looking. Its a 2L 4g63 with a 42r.
    Attached Thumbnails Attached Thumbnails -1c-jpg   -2c-jpg   -001c-jpg   -003c-jpg   -005c-jpg
    Mobile Electronics and Performance
    Tuscaloosa, Alabama
    In-ground Dynojet
    your moms house
    god damn turbo is HUGE
    FUCK B&D COMMUNICATIONS!
    alabama
    more pics
    Attached Thumbnails Attached Thumbnails -006c-jpg   -007c-jpg   -008c-jpg   -009c-jpg   -01c-jpg
    Tuscaloosa, Alabama
    In-ground Dynojet
    alabama
    and some more....
    Attached Thumbnails Attached Thumbnails -chute-mount-006-1-jpg   -dscn0861-jpg   -dscn1377-1-jpg   -dscn1190-jpg
    Tuscaloosa, Alabama
    In-ground Dynojet
    Savannah
    Default nice
    looks like alot of hard work and money has gone into this one! Nice build and keep us posted with pics, numbers, and video when you get it done!
    Yeah man. Fr33way's Avatar
    North OTP
    Shiiit dude.
    I really like the Autometers in the stock location, looks great.
    What are the axles rated to?
    Wanna-be-OG
    Newnan
    gawt damn i miss my gsx
    alabama
    Quote Originally Posted by Fr33way
    Shiiit dude.
    They are the strongest axles that DSS makes along with the aluminum driveshaft. Same stuff John Shepherd used till he went with a 9" rear. Got a little burned out but this warm weather makes me want to get started on it again.
    Tuscaloosa, Alabama
    In-ground Dynojet
    North OTP
    Any personal goals with this car or just best you can get?
    alabama
    I have a goal with it. They are personal goals. I willl be happy with 9 second pass but there is potential for an 8 second pass. It will come with seat time and cranking the boost up. Just like my first 10 second pass, it will take some time.
    I have spent a ton of time with John Shepherd on this build so that it gets done right the first time.
    Tuscaloosa, Alabama
    In-ground Dynojet
    by my nieghbor.........
    that is a beautiful set-up. hopefully your knuckles arent to swollen !! lol.
    At Home
    PARACHUTE=BEAST,,.....
    Quote Originally Posted by WhiteAccord
    **mental note... install parachute on the rear of my wagon and deploy in parking garage as I pull in work**
    This Talon reminds me one that I have seen on StreetFire (I think) doing 9's and 10's.
    I could be wrong but either way that shit is badass.
    North OTP
    Quote Originally Posted by SpeedDreamz
    That's awesome dude, the quality of the build reflects that.
    YOUR MOM GOES TO COLLEGE Curbow_USMC's Avatar
    Augusta
    lookin good.... what do you think it's gonna run?
    \/\/ Click pic for more pix of my ride
    Drifter/Kneedragger
    Buford, GA, USA
    Quote Originally Posted by AirBrcak
    this appears to be the same car.
    wicked build. i wish you the best of luck on that 8 second pass, from the looks of things you can build a car that does it.
    GSXTACY SilverJester's Avatar
    Acworth
    damn looks nice. Not a whole lot of dsm's with top mount turbo setups. Question: Why'd you go with a 2L instead of a stroker 2.3 or 2.4 since you have such a big turbo? I'm going to guess it has a lot to do with talking with Shep.
    Certified Gearhead Rican_nick's Avatar
    Apr 2003
    Augusta, GA
    thats an awesome build.
    Nick
    07 Tundra
    06 R1
    07 VW GTI***FOR SALE***
    Good shit!! I like it a lot!!
    2.3 Evo 8
    Guest
    Quote Originally Posted by SilverJester
    Alex Alex Alex! I thought you knew better then that my DSM brotheran.
    A GT42R will not work as well on a 2.3 or 2.4 litre. Yes, you can still make good power on a stroker with the 42r, but it will not be the best setup for drag racing. To build a true drag car with that large of a turbo you need to ring the bitch out to high rpms(10,000 rpms), which you know a stroker motor can't do.
    Shep actually shifts his car at 10K and crosses the line around 11K when he makes his high 7 to low 8 second passes.
    Stroker motors are safely being rung out to 8500. Some people are even going to 9K with the 2.3 or 2.4, but revving that high is just asking for failure.
    Obviously the nitrous helps tremendously.
    Nice build man and I wish you luck in your goals.
    All Motor EK N/A EK's Avatar
    On IA.com
    Nice
    alabama
    Quote Originally Posted by 2.3 Evo 8
    Bingo. I dont plan on using nitrous but I do have a direct port system waiting if needed. I intend on shifting around 10-10,200 to keep the turbo spooled. He is right about the strokers, you cant get enough rpm to keep a 42r in boost. I went with the 70mm though to keep from having to use nitrous.
    Tuscaloosa, Alabama
    In-ground Dynojet
    2.3 Evo 8
    Guest
    If you use that direct port shot to help that puppy down the track, you will have yourself an 8 second car. Be safe driving it. You definitely have a beast there.
    alabama
    The main problem is if I use the nitrous then that is considered a 2nd power adder which requires me to use a radial tire for the class I wish to race in. If I dont use it then I can use slicks. Go figure trying to get 900+whp down the track on radials.
    Tuscaloosa, Alabama
    In-ground Dynojet
    2.3 Evo 8
    Guest
    You mean 1,000+awhp??? On that setup you should be able to achieve just over 1000 with just boost alone on VP import. You'll be running 50+ psi though, lol. God I love the sound of that.
    Smackyaselfville
    Nice setup dude, keep us posted
    Project Vox has begun
    Turbobricks.com member
    GeckoSquad
    alabama
    I didnt want to start a dyno chart argument. We are not allowed to run VPi either so it will be on c16. NDRA Turbo Street class is what I built it for but I wont be able to run many races since they centered the series in the notheast.
    Tuscaloosa, Alabama
    In-ground Dynojet
    Certified Gearhead JstAneon's Avatar
    Amazing. That is all...
    EastCoastBoost
    Dunwoody, GA
    ^^ agreed
    keeps it REAL!! koffebean00's Avatar
    That shitt is weak!!
    j/k
    Looks good!:boobies:
    MYOB, Ga
    that shit looks badass. Im lovin ya setup and the manifold is sex....
    GECKOSquad
    NIKOND7000 Shooter | flickr
    i really hope i see this thing in action....maybe import showdown????
    sick ride btw....i like the choice to stay 2L...hail my neon has a 2.4L and low redline suck for big turbos...thats why i wont be going to a huge snail on my car. i really hope to see this in action next season, from the looks of it its gonna be a real beast.
    +1
    who knows.
    omg that thing is like totally the fkin hot fire.
    alabama
    Quote Originally Posted by CH@Dbee
    +1
    not sure when but I will have it ready soon. I am waiting on a new clutch alignment tool for the evo. New hubs in the disc to fit the larger tranny shaft..
    Tuscaloosa, Alabama
    In-ground Dynojet
    Certified Gearhead koi's Avatar
    Covington
    Dude! You need to post on GADSM also! That is a bad ass car! Reminds me alot of a 2g we have on the boards.
    Since it has been a couple months. Are you planning on coming to Import Showdown? It would be awesome to see that car there.
    Koi
    Proud former owner and future owner of a 1996 Mitshibishi Eclipse Spyder GSX(AWD). Ready to sell it back to me yet, Vonrok?
    Im French! Frög's Avatar
    AMERICA FUCK YEAH
    should of gone with a bigger turbo...
    lol j/k
    alabama
    Quote Originally Posted by sHpReLuDe
    lol j/k
    maybe a 45r?
    Tuscaloosa, Alabama
    In-ground Dynojet
    Barrett Parkway, GA
    that thing is fuckin sick and i'm in love with how you did the gauges...that's real nice
    alabama
    Thanks I appreciate it. I have done a few of them for people since I posted this and theirs turned out much nicer. I learned a few things doing mine.
    Tuscaloosa, Alabama
    In-ground Dynojet
