To make a long story short, I missed third gear with no rev limiter on my ecu and I fried my piston rings(or at least thats what appears to be the case).
For now, I'm accepting any ideas on what I should do. Personally, I want to take the quickest way out so that I can get it running A.S.A.P. Then again, I want to keep my setup, but just have solid internals in it this time around.
So, with that being said, does any one out there know what I should do??? My friend said I should get a compression check done before I just to any conclusion, and that's a given. But after that, what's next. Do I just replace the rings? Do I replace the pistons and the rings?? Do I replace the pistons, the rings, and the rods??? I'm working with a tight budget, but not tight enough where I wanna just ghetto rig it back together.
I hate to do this, but I'm willing to put out all my information out there, PRAYING and HOPING that IA will again come to my aid.
MY SETUP: (Brian, correcct ,me if I'm wrong)
*(keep in mind some guy in florida built all of this)
*SiR b16 (supposedly a b16b head)
*Short ram intake
*Crane cams (stage unknown)
*2 chipped ecu's neither have a rev limiter(one has a launch controller at 3.5k)
*DC Header
*Custom straight throught exhaust (no cat or resonator)
*(supposed piston upgrade)
YES.... I know this is a noob move to just blurb out my shit like this, but I don't care, I just need to know what should I DO!!!!! What kind of pistons would be good to go with it??? Also, If anyone knows of a good shop that will fix me up, holla!
+++++out of desperation, please help++++++
. Plus, this WAS my daily driver, so i need this car to run!
Worse like how??? Well, if that's the case, where do I start. i need to get this problem fixed asap. Is there a place that I could take it to get fixed for a good price. I mean, I can do the easy stuff, but some stuff, someones gunna have to help me with. FUCK!!!!
Or are you saying go with stock valves and a type r ecu instead of aftermarket valves, springs and retainers???
) and after they took off the head, it was all tears and sobs. Two of the valces had broke off and destroyed two pistons and the entire head was shot up and they were hole callore!
