Results 1 to 40 of 63
Thread: FS: Batlground Evo for sale on ebay, no link to ebay
    Default FS: Batlground Evo for sale on ebay, no link to ebay
    I cant put the link to ebay on here so if you are interested in looking at it on ebay you will have to search for it. It is under the mitsubishi lancer section on ebay.
    I am asking $50,000 but am taking offers over $40,000 right now.
    This vehicle is a 2003 Mitsubishi Lancer Evolution VIII or Evo 8 in immaculate condition. It currently makes 665 all wheel horsepower on vp motorsport 105 fuel (50% vp 116 and 50% 93 octane) and methanol injection. It was purchased new with the following options; hardtop, power windows, air conditioning, xenon headlights. I am the second owner of the vehicle and Batlground Engineering performed all the maintenance for the original owner at our shop. The car was built by Batlground Engineering for use as a street car that can be taken to the track on the weekends. It was brought to the drag strip ONE TIME and ran a 10.55 second pass in the 1/4 mile with drag radials on the stock rims on it. The car has not been drag raced again and does not have a roll cage. The car was brought to Little Talladega Gran Prix and it ran a 1 minute 10 second lap time with the 18 inch rims and the street tires on it. It has never been back to a road course since then. I SAY AGAIN, THE CAR HAS BEEN TO THE DRAG STRIP ONE TIME AND TO THE ROAD COURSE ONE TIME AND HAS NEVER BEEN ABUSED. Nitrous has never been used on the car but the intake manifold is tapped for nitrous nozzles. It is a true street car with a mild stereo system and dvd player. It has the largest turbo that you can put on a bottom mount t3 manifold and retain the air conditioning and the power steering. THE CAR HAS THE AIR CONDITIONING AND POWER STEERING AND THE FULL SIZE RADIATOR. The drivability and comfort of the car were not compromised in any way when it was built. It is a daily driver car that can be brought to the drag strip or the road course on the weekends. The motor, brake pads, rotors, transmission, transfer case, clutch, turbo kit, intake manifold, fuel system, intercooler, piping, boost gauge, bov, and stereo system have 2500 miles on them which are mostly highway miles to and from work. The aem ems, aem 5 bar map sensor, aem iat sensor, aem cdi and the msd coils have 5000 miles on them. The boost controller, methanol kit, exhaust, cusco underbraces, and tein basic coilovers have 8000 miles on them. The rest of the car has 35,500 miles on it and is in immaculate condition. The oil is changed every 1000 miles in the car and the transmission, transfer case and rear differential fluid is changed every 2000 miles. The vehicle gets inspected every 1000 miles when the oil is changed. The vehicle is a shop owned car and no expense was spared while we were building the car or maintaining the car. This car has over 100 hours of custom engine management tuning by Batlground, which is an authorized and accredited AEM EMS TUNING FACILITY. The only reason we are selling this car is because we need to make room for another new project car. The car is titled in an individuals name and is not titled in a business name. The graphics on the car are all vinyl stickers that were professionally applied. The paint is not damaged under or around the stickers. I pulled off a number of the vinyl stickers the day the auction started to verify this.
    THE FOLLOWING PARTS ARE INSTALLED ON THE CAR AND WILL BE SOLD WITH THE CAR
    Alpine IVA-D300 touch panel, in dash 7"flip out dvd player
    the computer for the touch panel is mounted under the passenger seat
    Custom molded and painted head unit surround, dark silver in color
    JL audio 4 by 75 watt amplifier mounted under the drivers seat
    Stewart warner -20 inch vacuum to 40 psi boost gauge mounted on the steering column
    Autometer gauge cup that the boost gauge is mounted in
    Black custom headliner to replace the stock light grey headliner
    Walbro 255 liter per hour in tank fuel pump, part number 341
    Aeromotive a1000 (-6) fuel pressure regulator
    Earls stainless steel fuel lines and earls aluminum fittings for the fuel rail and fuel lines
    Russel 0 to 100 psi fuel pressure gauge, mounted on the fuel pressure regulator
    Rochester 1000cc fuel injectors
    MSD fuel injector clips
    BJ’s sheet metal intake manifold and fuel rail
    NRG oil catch can with a custom k&n top mounted breather filter
    Tial 50mm Silver Blow off valve
    Tial 44mm vband clamp wastegate, silver in color
    Garrett 67 mm gt series compressor wheel with a garrett p series turbine wheel
    This is a sealed t series drop in cartridge assembled by garrett turbochargers
    The turbo is a full ball bearing turbo
    Precision turbo ported shroud to4s compressor cover
    Precision turbo .82 ford 5 bolt t3 turbine housing
    This turbo is commonly referred to as the gt37r or "Big Frame GT35r" or pt6776bb
    It is the biggest t3 garrett based turbo that you can fit and still have air conditioning
    Earls dash 3 braided oil feed line with a restrictor fitting
    Earls dash 6 braided coolant lines going to and from the turbo
    Shearer stainless steel tubular exhaust manifold
    Garrett 3 inch core front mount intercooler with custom endtanks and piping
    3 inch coldpipe and 2.5 inch hotpipe
    Custom 3” stainless mandrel bent full exhaust system with magnaflow muffler
    K&N 4 inch intake filter
    Custom 4 inch air intake
    Odyssey mini battery with Batlground install kit, mounted in the engine compartment
    Aem cdi ignition system
    Aem ems standalone engine management
    Aem 5 bar map sensor kit
    Aem intake air temperature sensor kit
    Taylor 8mm spark plug wires, red in color
    NGK 3330 spark plugs
    Msd twin tower coil packs
    2.3 Liter Stroker Motor Built by Batlground
    4g64 crankshaft
    Pauter connecting rods with arp bolts
    Ross racing pistons with rings
    Clevite main and rod bearings
    Arp main studs
    Arp head studs
    Cometic Head Gasket
    Balance Shaft eliminator kit
    new timing belt when motor was built
    new oil pump when motor was built
    new water pump when motor was built
    new transfer case when motor was built
    new gasket set when motor was built
    Ferrea 1mm oversized stainless steel valves
    Ferrea dual valve springs
    Ferrea titanium retainers
    Ferrea keepers
    Race ported and polished head and race valvejob
    Tomei high lift 11.5mm Camshafts
    Tomei red aluminum cam gears
    Hks evc 5 boost controller with the display custom mounted in a carbon fiber panel
    Custom methanol injection kit with controls in carbon fiber panel
    Exedy triple carbon clutch with high clamping pressure plate
    Valvoline syn power 20-50 motor oil
    motul brake fluid
    motul brake fluid for the clutch system
    Redline shockproof gear oil for transfer case and rear differential
    BG syncroshift manual transmission oil
    Privat Fahren 18x9 rims
    Maxxis MA-Z1 255/35/18, 95% of the tread left
    Tein Basic Coilovers
    Cusco front undercarrage brace
    Cusco lower front strut brace
    Evo 7 tail lights
    clear sidemarkers
    Goodrich brake line
    Stainless steel braided clutch line
    Ferrado Brake pads
    Stock Brake rotors
    John Shepherd built transmission
    The car currently makes 665 hp on vp motorsport 105 fuel and methanol at 38 pounds of boost. The car easily makes 575 all wheel horsepower on 93 octane pump gas and methanol at 30 pounds of boost. The engine and transmission are built to handle 1000 all wheel horsepower with nitrous at 40 pounds of boost. I am entertaining offers above $40,000. The buyer will be responsible for shipping, and any paypal fees. I will require a $1000 non refundable deposit to be paid by paypal immediatly after the auction ends. Funds to pay for the vehicle must be verified before the vehicle and title are transfered. Full payment must be made no later than 7 days after the auction closes. Please, no joy rides.
    Pictures of when our evo was almost stock can be found here
    http://batlground.com/gallery/thumbnails.php?album=49
    Pictures of when the budget kit was put on the car and we broke a connecting rod
    http://batlground.com/gallery/thumbnails.php?album=43
    Then we built everything and you can see pictures of the engine buildup here
    http://batlground.com/gallery/thumbn...lbum=37&page=1
    Here are pictures of the engine and tranny installation into car
    http://batlground.com/gallery/thumbnails.php?album=47
    Pictures when the car was completed are here
    http://batlground.com/gallery/thumbnails.php?album=48
    Here is a link to the video of the car running a 10.55 second pass at the drag strip, if you listen closely you can hear the car coasting through the last 100 feet.
    http://www.picsvids.importshowdown.c...ound-10_55.wmv
    The most recent pictures can be found in this gallery
    http://batlground.com/gallery/thumbnails.php?album=129
    please email vteckidd for the vin number. he will email me with your request and we will get it to you if you are a serious buyer.
    In the Fucking A
    This is one Badass ride, this would make the ultimate Time Attack car. If you want to go fast on track this is youre answer.
    I fucked ©hris's mom
    IA KING
    nice this car would make a great sleeper
    bye bye kitty! I will miss you.
    Val for president!
    Facebook.com/TracyATL
    Public Enemy #1
    this time you got it right
    All Motor EK N/A EK's Avatar
    On IA.com
    Bump for clean EVO, g/l with the sale.
    Woodstock
    bump...i rode in it like 2 years ago with it was only 400whp and it was still amazing....
    Val RIP
    my only rule in life
    HIV+ HalfBaked's Avatar
    Bump for a car that is cooler then IA itself.
    Quote Originally Posted by TransAxle
    Yea, I yelled at him. I told him it would be deleted. He never posts and obviously doesn't read rules...boys! I swear!
    Val for president!
    2004 Gallardo DRFTR's Avatar
    ah i love that evo...damn it tracy why are you selling it?
    -dave
    Public Enemy #1
    Quote Originally Posted by tracy
    shit you where surprised i thought it was you selling the car...and i was like WTF how the hell would she get it wrong!!!!!!
    So tracy what do you drive now?
    ***Lotus Elise***
    BlackWatchRacing
    Certified Gearhead 95stangs's Avatar
    so whats the next project??? i would think 50k could give ya some good options
    1995 Mustang V6
    Cardomain
    For Sale
    Myspace
    v2.0 IndianStig's Avatar
    Sep 2004
    Gwinnett County
    Wait, is this going to be replaced with a Z06??
    We are going to put the Supra back together and then after we save a little more money buy a C6 Z06.
    Val for president!
    MOD KILLER rupertaker's Avatar
    yay for the SUPRA
    <Matt
    Bryant left himself logged in at my house and I dont want to log out because then I cant fuck with him.
    Quote Originally Posted by rupertaker
    yay for the SUPRA
    <Matt
    LOL. Dinner tonight?
    Val for president!
    Someone call my lawyer... slyde_wayz's Avatar
    D.S.G.
    I mjust going to say wow.!!!
    So Smoooth... Itll blow your teeth off!!
    That Fucking
    Yeah Ill call you in a minute
    Still Matt
    more wood than noahs arc sirkus's Avatar
    Cartersville, Ga
    Nice design on the side... g/l
    2014 | Hyundai Veloster | Turbo R-Spec
    Yeah man. Fr33way's Avatar
    North OTP
    Was one of the pictures on the strip fake?
    Quote Originally Posted by Fr33way
    what are you talking about?
    Val for president!
    trade for civic type r plus 2k...on your end?
    awwww you are so sweet! Thanks for the offer...but no thanks. I think I'll have to pass on this one for now. I just don't have the $2k to spare just yet.
    Val for president!
    figured
    Memphis, TN
    i can't find it on ebay..
    Blah Blah Blah!
    nice car if only i had 40k
    San Antonio, TX
    It was on ebay a few days ago?
    should have closed by now..
    don't see the closed listing anywhere
    twoONEoh
    San Antonio, TX
    nvm..
    I just saw the listing..
    I could've sworn you were gonna get what you were asking for it..
    twoONEoh
    Earth
    I saw it on E-bay too. Didn't see a reserve on it, so did it sell?
    It said in the description that we were taking offers above $40k. It got up to $38k (it didn't sell) but now we are getting lots of emails about it. We're going to re-list it soon.
    Val for president!
    atlanta, GA USA
    Tracy, there are a few things to consider with the Ebay auction that may help also. The fact that your feedback rating is only a 1, may make people hesitant to bid on the car because they dont know if you are legit or not. Then on top of that, by not listing a VIN number, it still gives off that vibe. So a few things to consider that may be holding back the potential of the sell on ebay.
    Your car is amazing and can say I am glad I had the pleasure of seeing it at the shop at the BBQ's. I wish you the best of luck in your sell and can't wait to see what you do next.
    John Clopton
    2004 Yukon Denali
    2007 Volvo S40
    Quote Originally Posted by JC
    Thanks for the advise.
    I can't change the fact that we have only one sale on e-bay right now. WE WILL NOT LIST THE VIN! Makes it easier to steal. It's a $50k car...not going to happen. We're not talking about a Hundai here. I think most people would understand that
    The good thing about the ebay auction is that people are looking at it and we are getting e-mails abut it. It's good advertising for the sale of the car either way. They don't have to bid on it.
    Val for president!
    atlanta, GA USA
    And not bad advertising for the shop either.
    John Clopton
    2004 Yukon Denali
    2007 Volvo S40
    North OTP
    There are "nearly stock" photos @ the strip and of course the 10.55.
    Very sweet ride, hope it stays in Georgia.
    In the Fucking A
    I may be wrong but I dont think that car ever made a pass in nearly stock form, actually hes right Tracy its been to the track twice. Once on the stock turbo and once on the big setup
    Quote Originally Posted by Big Baller
    We are referring to the new engine setup and all of the new parts. Who cares if it made a pass on an engine that's not in the car anymore? Do we really need to be that nit picky? Or is someone just trying to call us out? I mean, give me a break.
    **edit I said one pass, but as is says in the original post made by Dan, it has been to the track once. Not one pass (my mistake). I think it made 4 passes that day? 2 in the 12's, 2 in the 10's.
    Val for president!
    Memphis, TN
    when you guys say "pass on an engine" what you guys talking about?
    Blah Blah Blah!
    North OTP
    No, you're right. It's a great car.
    North OTP
    Quote Originally Posted by latoilette
    The car has only made one 1/4 mile pass on this setup.
