Results 1 to 18 of 18
Thread: Subs not working?
    Certified Gearhead Mangrum's Avatar
    Suwanee
    Default Subs not working?
    i have the amp and everything wired and ran but for some reason the subs are not hitting at all.. i have the power ran to the amp, the ground, the remote wire, and the speakers all wired in but still will not hit. anyone that has had a similar problem what coudl this be?
    Cumming, GA
    The amp is turning on? You did not mention RCA cables...do you have them also?
    Is it possible you subs are out-of-phase? Meaning + and - are reversed from 1 sub to the other
    Just a few thoughts...
    John
    My Spoon Is Too Big! Flip's Avatar
    Quote Originally Posted by redgst97
    John
    this would not keep the subs from making noise tho...
    if theyre just not loud at all then this may be the case tho...
    if they aren't making noise at all look other places like the remote wire... if the amp is not turning on try bridging a wire from the +12 to the remote and see if the amp turns on. if so then your remote is not sending the amp the signal to turn on...
    Suwanee
    Quote Originally Posted by Flip
    i think this might be the problem because everything is wired right but the amps power light is not on. so how do i fix that?
    Quote Originally Posted by Mangrum
    You may have your remote wire connected to the incorrect wire behind your head unit. You need to get the wiring diagram for your head unit's wiring harness, find out which wire it says it is, then find a multimeter and test the wire (touch the red or positive tester to the wire, then the black or negative to a ground wire or to the chasis of the car) and switch between the car being off and on. The wire should read 0 when the car is off and close to +12 when the car is on.
    you could start by not doing shit by yourself if you dont have the slightest clue what your doing
    Suwanee
    Quote Originally Posted by b@d @pple
    haha.. yea dude your funny since its working now! its not that i didnt know what i was doing i ran into a problem so maybe you got the money to go pay someone to do it. but i dont but its good now so you can STFU.
    Hiram, GA
    The problem you ran into was that you had it hooked up wrong. Sounds to me like you dont know what your doing.
    Suwanee
    no it wasnt that it was hooked up wrong. i spliced the remote wire into the yellow wire because in most the headunits i have worked on the yellow wire has always been the antenna wire. but in this headunit it was blue so i just spliced in into the wrong wire. everythign else was fine.
    Certified Gearhead ruffriderGA's Avatar
    yeah the remote wire is usually blue, actually on most headunits i've messed with so far there's a tag on the blue wire that says "REM WIRE" right on it. good to hear you got it working though
    Hiram, GA
    I've personally never seen a head unit that the remote wasnt either blue or blue/white. Yellow is usually acc.
    oh and if splicing into the wrong wire is not called hooking it up wrong then what is?
    Quote Originally Posted by BanginJimmy
    he has to learn somehow i guess good thing nothing got fried or anything
    no accord
    alpharetta
    i see that that you have meet badapple. hahaha i love how ppl gets pissed off. get used to that dude its the internet. i promice you wont say that to his face
    glad you figured it out
    jimmy whn is yellow acc.and not battery..
    Devin 5thgcelica's Avatar
    snellville
    blue is damn near always the remot, and yellow is usually the battery.
    Senior Member | IA Veteran DJ XtRaKŠ's Avatar
    Apr 2001
    Roswell
    baaaaaaahahahhaha....oh man...that was bad ass i cant believe i just now saw this.
    thats why they have invented people like us (installers)!!!!
    IA OG
    Lilburn
    Everybody started somewhere.
    '05 300C SRT8
    Jamie (Eimaj)
