Results 1 to 1 of 1
Thread: NEC Multisync 18" LCD Flat Panels - $125 MANY AVAILABLE!!
    Everyday im HUSTLIN'
    atlanta,ga
    Default NEC Multisync 18" LCD Flat Panels - $125 MANY AVAILABLE!!
    NEC 18" BLACK Flat Panels
    Model 1830 - black
    These monitors do not come with the base. They are WALL MOUNT LCD panels.
    They also have 2 AGP slots on the back to connect more than one computer to them and you can switch from PC to PC via a button on the front of it.
    Technical Details
    -1,280 x 1024 resolution, 0.28 mm dot pitch
    -160-degree horizontal and vertical viewing angles
    -200-nit brightness, 300:1 contrast ratio
    -18.1-inch viewable image size; removable base
    $125 FIRM Will come with a 7 day warranty. These monitors have been tested and are perfect.
    The LCD1830 monitor brings clarity to your desktop graphics. The true 18.1-inch viewable image size provides a 300:1 contrast ratio and over 16 million colors through a new color algorithm, and supports the sRGB reproduction standard. With a maximum resolution of 1,280 x 1,024, your images will shine with crisp edges and vivid detail on a flicker-free screen.
    The sleek frame offers lightweight versatility—the screen is just 3 inches deep and the total depth of the detachable base is just over 8 inches. The monitor's weight is 14.3 pounds, and it supports wall or arm mounting, with an optional bracket. The anti-glare hard coat guarantees clear viewing even in bright offices, and with the wide-angle technology, you can be assured of a clear view from a variety of positions (160 degrees horizontally and vertically).
    NEC has brought plug-and-play to new heights with its automatic picture adjustment; once you connect the cables and power up, the monitor does the rest for you.
    Remember the ones I am selling are black.
    I will have pics of the monitors up as soon as I get a chance.
    Attached Thumbnails Attached Thumbnails -nec-jpg   -image_00012-jpg   -image_00013-jpg   -image_00014-jpg
