Results 1 to 21 of 21
Thread: b18c1 valve adjustment
    DC5-R
    Gwinett
    Default b18c1 valve adjustment
    Well, its time for me to go get a valve adjustment tomorrow, but what I was wondering was is there a different spec if you have upgraded valvetrain? Ok....the specs are
    Intake - 0.15-0.19 (0.006-0.007)
    Exhaust - 0.17-0.21 (0.007-0.008)
    I have skunk2 valvetrain, so basially there is no difference correct?
    no it doesnt matter, but a valve adjustment must be done when the motor is STONE COLD. doing a valve adjustment on a warm or hot motor is pointless.
    Where Am I
    ok so what do you adjust them to, or how cause I'm looking to do mine soon
    Quote Originally Posted by 97GSRb18
    Ill answer for you:
    $75/hour
    Lexus GS300
    .007 on the intake
    .008 on the exhaust is factory service limits.
    a service manual will tell you how to adjust them
    LoL, its hard to explain how to do a valve adjustment, its easier to show someone
    Quote Originally Posted by SL33P3R
    Ill answer for you:
    $75/hour
    if you want to equate a VALVE ADJUSTMENT to assembling a head, then thats your judgement LOL.
    I jut said that to give you a hard time, hahaha, i was just kiddin
    Lexus GS300
    ®anj-♠ ranj's Avatar
    very simple u can do it, just have ur correct spacer thing to the size Mr.KiDD said and its a piece of cake (cheese to be exact) and good luck.
    DC5-R
    Gwinett
    10mm valve adjustment tool
    19mm socket (for the crank pulley)
    small flat head
    these are the main items you'll be needing, but yeh, its harder to explain it than to just show someone.
    Alpharetta/Duluth
    You should have it done by an experiened professional. Overtightening will cause burnt exhaust valves and a pricey repair. I just did a burnt valve job on an 04' S2000 and it cost the guy $1500 total.
    Where Am I
    I know how to do them on chevy's but just not Honda's...
    DC5-R
    Gwinett
    Quote Originally Posted by Five*Star*
    they maybe you should be takin it to a professional, I haven't had 1 problem yet.
    yeah ive never seen anyone do a bad valve adjustment. i mean, i have had guy install their own cams, and NOT do a valve adjustment, and then the car has no compression. simple fix.
    Just make sure the car is cold, BONE COLD, and do the valve adjustment.
    why??? just curious
    why what?
    DC5-R
    Gwinett
    why what?
    he wants to know why the car has to be cold to do a valve adjustment. Help the noob out mike. Here's a hint, ask jeeves lol!
    Metal expands and contracts under heat. especially aluminum
    The service manual limits are based on a COLD MOTOR. WHen the motor heats up to operating temp, the number on the valve adjustment can grow as much as 10-15 thousandths.
    so if you do a valve adjustment on a warm motor, when you THINK you have the right number, in reality its much tighter or loose when the motor cools down.
    Where Am I
    ok so what do u tighten them to when its cold?
    Where Am I
    ^^^ or pretty much how do u do it???("That is the question")
    BUY A SERVICE MANUAL
