Thread: Pc Chips M851 Socket 462 (a) Mobo
    OL SKOOL 6IMAFREAK9's Avatar
    Thumbs up Pc Chips M851 Socket 462 (a) Mobo
    FOR SALE IS A PC CHIPS M851 SOCKET 462 (A) FOR AMD PROCESSORS (THIS BOARD WAS PULLED FROM A WORKING PC AND IS USED).
    AMD Socket-A AthlonXP, Athlon & Duron Based on VIA KM400 Chipset ATX Motherboard Supporting 333 MHz FSB, DDR 333, audio, 8X AGP, 10/100 Mbps LAN, four USB 2.0
    PROCESSOR
    462 pin Socket A supports AMD k7 processors
    Full series of Athon XP/Athlon/Duron processors up to 333MHz FSB
    Chipset
    VIA KM400 (NB) & VT8235 (SB)
    One 8x AGP slot for AGP 2.0-compliant interface-Integrated VIA UniChrome 2D/3D Graphics with motion compensation,
    64MB shared memory -VIA VT8235 USB2.0 Host Controller
    PC I/O - IT8705F
    LAN - MAC integrated in VT8235 & PHY onboard
    AC '97 Audio Codec
    Compliant with AC97 2.1 specification
    System BIOS
    AMI 2Mb Flash EEPROM
    Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI
    Support ACPI revision 1.0 specification
    Memory
    Two 184-pin DDR DIMM sockets for 2.5V DDR SDRAM (DDR266/200/333)
    Maximum: 2GB (Unbuffered Memory)
    Expansion Slots
    2 PCI slots, 1 8x AGPslot, 1 CNR slot
    Form Factor & Layers
    Flex ATX form factor (230mm*200mm), 4 Layers
    I/O Interface
    Back Panel I/O Ports
    Support Plug and play function-PS/2 keyboard and mouse connectors
    Four USB 2.0 Ports and a LAN connector
    One EPP/ECP mode parallel port-One 16550 high
    speed serial I/O por t
    One VGA connector
    Audio ports (Mic-in, Line-in, Line-out, CD-in)
    Dual PCI IDE interfaces
    support four IDE devices (PIO mode 4, DMA Mode 2, Ultra DMA 66/100/133)
    Supports 360K~2.88M Byte, 3 Mode FDDs or LS120
    ATX Power Supply Connector (4 pin 12V power connector required)
    Ports, headers and others
    IrDA header-Two Extra USB2.0 Ports
    Front Panel MIC/Line-Out Header
    HDD LED, ACPI MSG LED, Reset Switch, Power Switch headers
    CPU and Cassis Fan headers
    Internal USB Carder Header (share one USB port from back panel)
    RTC & Battery
    VT8235 includeded 256 byte of CMOS
    With CMOS hardware clear jumper
    ASKING $40.00
    Attached Thumbnails Attached Thumbnails -amd-462-mb-jpg
    Default Nice
    Board For Sale!!!
    Sweet
    AG Member
    I-20 West.
    swear yah two are the same person.
    Exclamation POP
    FO SAIL!!!!
    KRC - Kill Ricers Crew
    Macon, Georgia
    OMG you have to be shitting me? An old Mini ATX Bottom line mobo, that dont even support ddr 400!
    Its worth 20$
    You must not shop at newegg.com in the refurbished department.....
    D Blocks suck!
    Default IT'LL
    work with that RAM you selling!!!! so buy it MAN!!!!
