Results 1 to 2 of 2
Thread: f/s: 99 avenger on air!
    the lower the better
    Macon
    Default f/s: 99 avenger on air!
    1999 Dodge Avenger Es
    Engine: Stock V6 with 83,000 miles. Runs goods, no problems.
    Exterior: In pretty good shape, Front bumper has been scraped in the front and has scratches on the side, fender is bent on the bottom from me hitting a curb(not paying attention) no drivers side door handle, but i have a shaved door handle kit ill include, and some small scratches.
    Interior:Leather, In really good shape, clean, two air ride gauges in the middle compartment, 4 switches under the A/C controls.
    Suspension: Four Brislands air cylinders, 12 gallon tank, 2 Viair 380 compressors, 4 1/2" SSC up valves, 4 3/8" SMC dump valves, have an extra SMC 3/8" valve for 3-wheel, but havent hooked it up yet, 4 switches, 2 Viair dual needle gauges, front and rear camber kit
    Wheels: Stock 17" star wheels, in alright shape, one has a small bent lip, and they have some scratches. Front tires in good condition, rear tires are kind of worn beacuse I did not get an alignment when I had them on the front.
    I'm looking to get $7500 o.b.o for it. NADA value was $7,025 and Kelly Blue Book value was $8,000, so i figured $7500 isnt bad with almost $2000 in the suspension itself.
    Attached Thumbnails Attached Thumbnails -dside1-jpg   -gauges-jpg   -pside1-jpg   -trunk-jpg
    Is that Westside HS? I graduated there in '00, and we painted our spots. I wonder if mine is still there at all? It was a checkerboard (white/black) that was 80% complete. If I remember correctly, it was in a similar spot to where you took your pictures, near the road closest to the building, and about the same distance from that rear door.
