Results 1 to 13 of 13
Thread: needing CRX assistance
    just passin thru
    east ubersmoke, Germany
    Cool needing CRX assistance
    i have a 89 CRX dx that won't start,and the previous owner had a really pointless swap done to it,he kept the 1.5 block and replaced the head with a '99 dx head.any one with experience would know that there's no point in that swap beacuse its obd2 so all the components would be a bitch to match up from obdo-obd2 10 years is way too much of a time difference to fuck around with so i said why bother. any way, this ingenious mechanic with too much time on his hands might have managed to do the mpfi swap some what correctly.to the point where we got it to turn over with the '99 head on it holding the dizzy in a certain position .problem is,the only distributor ('91 si dizzy) that will hook up to the harness wont stay in bolting position on the '99 head.so far i have corrected the swap and got a complete 1.5 '91 si head back onto it with every thing finished. i just haven't fucked with the timing yet.i just wanted to know could the timing be that retarded or advanced to the point that it won't crank at all?
    the car is in marietta if any one knows someone or somewhere i can get it towed to for a timing setting it would help.i need to get this project either running or sold.thanks for you time pm me if you want more info on the purchase
    slammmed 99' C5 wagon EXE
    DAS AUTO.
    Gainesville
    Belview Insane Asylum
    What you are saying doesn't make any sense.
    1st: a 91 Si head is a 1.6L head
    Second: What intake manifold are you using, and ECU?
    Third: It is even turning over?
    ^The Bad Guy toonz's Avatar
    Lithia Springs LOL!!!!!!
    AWWW my head hurts LOL
    Still here!
    Super Dave Z U L8R's Avatar
    Roswell
    timing belt = valve timing
    distributor = ignition timing,
    regardless of whether or not it gets spark when it's supposed to the motor should still be able to turn over without a problem as long as the valve timing is correct aka the timing belt's on correctly.
    you may have flooded the motor aka hydrostatically locked it meaning the cylinder is full of fluid (coolant or gas or whatever) therefore the piston cannot travel upwards.
    i really doubt that's your problem though, need more information
    just passin thru
    the engine rotates, but will not start.the car actually started when we turned the distributor towards the firewall.what i wanted to know was if the ignition timing could be screwed up to the point that the car won't start.
    DAS AUTO.
    Quote Originally Posted by EF89
    Yes.
    just passin thru
    thank you MR.FED your time is appreciated.
    DAS AUTO.
    Roswell
    lol , you said can the timing make it not "crank at all," not ,cranks but does not start.
    If I can help anymore let me know. I know a little bit about CRXs.
    I told you to buy mine. Way worth it now huh?
    just passin thru
    Quote Originally Posted by aaronfelipe
    could've been. but to tell you the truth i've spent a bout $345.63 on the car including the cost of the car itself soooooo. you really can't beat that.plus it needs NO BODY WORK .aka. NO BONDO FOR ME
    DAS AUTO.
    just passin thru
    Quote Originally Posted by Z U L8R
    oh, okay my bad. it gets confusing i'm a noob for sure.
    DAS AUTO.
