Results 1 to 21 of 21
Thread: battery in trunk rule at the track?
    I shave my legs... dartingd's Avatar
    on the bike
    Default battery in trunk rule at the track?
    a friend told me that i need a kill switch in my car since i have the battery in the trunk...is this true? need to know for tunerfest...92 accord w/ h22 btw if that matters at all...
    PSN SN= dartingd
    you must have an external kill switch for the battery if its relocated
    ALL CAPS JITB's Avatar
    dam..didnt know this..
    Really? I've been at Commerce multiple times, and Bristol w/ my battery in the trunk. The tech guys didn't care. All they made sure of was that the battery was actually bolted down and separate from the cabin.
    Turbo '97 Maxima
    Evolution Autodesign
    Drifter/Kneedragger
    Buford, GA, USA
    Quote Originally Posted by Evolution Autodesign
    ditto
    HAY!!!! HI!!!!!
    Val for president!
    Facebook.com/TracyATL
    I went to tunerfest last year, and i spent 1 hour tryin to find a auto zone, and install a battery tie down so i could run. There was about 3 other peeps there as well doin the same thing. so u dont need the kill switch?
    Gwinnett, GA
    yep...
    on the bike
    how much are they and how hard to install? where does it need to be installed?
    PSN SN= dartingd
    A.K.A. GA Teg
    Jun 2001
    Behind the lens
    According to NHRA guidlines or rules it says this
    If you do choose to mount the battery in the trunk, it must be mounted to the frame or frame structure with a minimum of two 3/8-inch diameter bolts and a metal hold-down strap. The supplied J-hooks are not allowed. Also, the battery must be completely sealed from the driver compartment. This means a bulkhead must separate the trunk from the driver compartment. The battery can also be located in a sealed metal box, constructed of a minimum of .024-inch-thick steel or .032-inch-thick aluminum.
    Any car with a relocated battery must be equipped with a master electrical cutoff capable of stopping all electrical functions, including ignition. In other words, if somebody hits the master switch, it must shut off the engine as well as the fuel pumps and so on. The switch must be located on the rear of the vehicle, with the off position clearly marked. If the switch is a push-pull type, push must be the motion that shuts off the switch. Plastic or keyed-type switches are prohibited.
    Maybe the tech guys have their own set of rules
    www.ATLphoto.net Myspace
    on the bike
    sounds like too much work...
    PSN SN= dartingd
    not if you need the space where the battery is in the engine compartment
    Last year my Maxima ran at Tunerfest w/ the battery in the trunk and no kill switch, also at Bristol. The tech guys just tried to move the battery around to make sure it was secure. The NHRA rules do say you need one, but maybe when it's just open session the tech guys don't care.
    Turbo '97 Maxima
    Alpharetta/Duluth
    Quote Originally Posted by GA_Teg
    Couldn't have said it better myself.....
    Barnett performance in ATL has all the necessary parts to do a NHRA safe job.
    404 522-1320
    and, I can do the install for anyone that needs this kind of work done.
    404 452-7691
    Michael
    c-ya sirhatch1030's Avatar
    southside
    i was there last weekend and you do have to have a visable cut of switch on the out side r u cant run at all .i know because i dident get to run last weekend at commerce.
    on the bike
    i have the battery in the trunk due to space issues under the hood...guess it's time to buy a switch!
    PSN SN= dartingd
    Drifter/Kneedragger
    Buford, GA, USA
    depends on who's running the event... to run an NHRA sanctioned event you do have to have the kill switch. i don't believe the NHRA will be doing tunerfest, just like fast fridays. i've been to numerous fast fridays with the 240 and it's relocated with a battery try that has J hooks and wingnuts and a metal crossbar for a tiedown. it's very secure and that's all they've ever looked for.
    on the bike
    where can you buy the switch?
    PSN SN= dartingd
    A.K.A. GA Teg
    Jun 2001
    Behind the lens
    Quote Originally Posted by tehpr3chr
    http://www.racerpartswholesale.com/rebco5.htm
    southside
    tou can get the switch at barnnet.
    meh..i aint buying one unless i NEED it.. ill just buy a Box, so my trunk will stop giving off those crazy fumes...lol
