Page 1 of 3 123 LastLast
Results 1 to 40 of 96
Thread: 93 TOYOTA SUPRA, wide body
    IA Member KERR's Avatar
    Default 93 TOYOTA SUPRA, wide body
    so mods have there thongs on too tight i see... damn me for no pictures and the lack of a vin number.
    now that the picture are out of the way Im suppose to do it like this says the web page:
    HERES AN IDEA:
    Make: In title
    Model: In title too
    Year: in post
    Mileage: in post too
    Options: Nope
    Mods: In post too
    Engine: yes a nice one
    VIN#: jt2ja82j7p0000629
    Contact Info: Oh my in post too...
    1993.5 black, built motor, turbo 400, wide body
    PRICE REDUCED TO $60K FIRM
    The mileage is 93,560 on the chassis. After the motor and transmission the car has about 300 miles on it. All done proper no boost for the fist 100 miles, no boost over 20 psi after that.
    Exterior:
    Modified 1998 lights front and rear, sanded and painted body color
    Do luck front bumper,
    TRD side skirts, Modified to fit custom body kit
    Widened TRD ¼ panels, about 4 inches wider on each side than stock TRD kit.
    Widened TRD rear bumper
    Shaved radio antenna
    Shaved marker lights.
    DuPont super jet black with DuPont’s clear. All of the jams and under the hood HAVE been painted and cleared as well.
    Wheels, Tires & Brakes:
    Volk GT-N 18X9’s front and 18X13’s Rear. Sanded and painted ( originally gold),
    Volk Carbon fiber center cap’s, Volk no longer makes wide wheels.
    Michelin Pilot sports, 255-45-18 and 335-40-18 Larger tires will fit no problem.
    Kyokugen black lug nuts.
    New rotors that are cross drilled,
    New hawk pads,
    new stainless steel brake lines.
    I also had the calipers sanded and painted in viper red with the supra logo in black.
    Interior:
    Factory black interior car. The stock seats and carpet in very good shape.
    Dakota digital 53mm gauges, Boost, Trans temp, and EGT
    AEM wide band in clock location,
    TRD 10,000 rpm tack,
    Painted dash,
    RCI 5 point harnesses,
    S&W 6 point gage, with added supports
    Limo tinted windows.
    It also has all the padding to cover the bars.
    Motor:
    Block board .20,
    Crower springs and Titanium retainers,
    Crower stage III cams,
    Crower rods,
    JE pistons,
    Ferria 2mm valves,
    ARP head, rod and main studs kit,
    Motor was also balanced and blue printed,
    Virtual works intake manifold (sanded and painted black),
    Virtual works 4" intercooler pipe (sanded and painted black)
    Virtual works Power steering relocater kit.
    Greedy 3 row FMIC, ( painted black)
    Nitrous express kit, with one 10 lb bottle painted black
    AEM computer, AEM CDI, AEM Injector driver
    AEM 5 bar map sensor
    Denzo Coil packs (Honda cbr 900rr)
    Batl-Ground custom made Turbo kit, 81/88mm (painted intake and jet hot coated exhaust black) turbo with 4” down pipe and 4” cat back.
    Greedy T88H manifold also jet hot coated.
    Boost logic Harmonic balancer,
    Head has been ported and polished along with the valve job and gasket matched.
    Fuel system
    1600CC RC injectors,
    2-8 fuel lines,
    2-8 filters
    all earls lines and connectors
    3 Walbro fuel pumps
    -6 Return line
    Autobanh fuel rail anodized black
    Aero motive FPR
    WOTM 3 pump holder
    Alky control methanol injection. twin nozzle big pump upgrade, -6 feed line split into two -4 lines to cause a fogger affect on the throttle body. ( kit will flow enough methanol or alcohol to support over 1000 wheel hp on straight pump gas (91 octane). This is the real kit NOT windshield washer stuff)
    5 gallon fuel cell mounted in the hatch beside the Nitrous bottle and Gage. This is the holding cell for the Methanol or alcohol. Pump, lines, and nozzles will flow both.
    Transmission
    Gm Turbo 400 transmission.
    Fully built with all hard core parts.
    TCE 4500 stall with duel anti balloon plates. Custom made to run the Toyota stall and GM stall. That way you keep the 5 bolts the Toyota stalls have.
    The transmission also has a trans brake which requires a reverse shift pattern.
    B&M shifter cut down ( 3 inched removed ) to look like the 6 speed,
    Also has the 6 speed center console which has been sanded and painted black to match the dash.
    RCI trans blanket SFI approved.
    Car will also come with:
    Two stock hoods. One on the car other Baltic blue, I was going to cut this one and put the European hook scoop in it.
    4 Factory silver wheels. ( bad curb rash, wife cant drive, spray painted black and used as rollers)
    3 Factory 17” chrome wheels Two in grate shape. One is ok shape.
    1 Factory polished wheel. In ok shape.
    2 brand new 275-45-17 BFG ET Streets. 0 miles. Mounted the wheels and laying in the garage.
    Line lock kit new in box
    Stuff from Dakota digital to make a th400 work with the factory Speedo.. Haven’t even opened the box.
    B&M deep pan with fin cooler for the transmission. Hold an extra 3 courts.
    I have lost Interest in the car, and have not touched it in 8 months. When this project started it was just my wife and I. We now have two kids and not enough hours in the day to enjoy this car and others. Therefore Cars with out 4 seats will be put up for sale along with some that have four seats .
    Car is currently un tuned. It does have a modified start up map in it, but its not very drivable with a 4500 stall, 1600 cc injectors and 89mm turbo on a modified start up map. I have no clue when it comes to the AEM and have no desire to learn it. There for I haven’t messed with it. The closest tuning shop to me is about 450 miles away and I haven’t had time to get there for tuning do to a new child, my work schedule and them having time to give the car the attention it needs. Those of you with big single cars know its not as simple as click click click than you.
    I can tell you that on the modified start up map once on boost the top of 1st gear and all of second gear is useless on the 345’s It just paints two nice 13 wide stripes as long as you have the balls to hold into it. You might as well go ahead and figure in some coil over’s or drag launch kit.
    This is a hell of a deal on car like this. You could not buy a 90K mile supra and do the body work or motor work for what this car is priced for. Think of it as getting a built motor and transmission for free, or free wide body that is done correctly. There are NO cut lines, bleed back or body scars. It looks just like a stock metal body car with a fat ass. Why pay $70K for a new Zo6 with 505 crank hp or $85K for a new viper when for less money you can get a car that should make 1400+ crank hp? There are no stories with the car and nothing to hide. The pictures and parts list should speak for itself
    Here are some good pictures of the car. There is also a link to web shots incase you want to kill a few hours looking at the build up.
    http://www.tunerzine.com/articles.php?id=171
    http://community.webshots.com/user/kerrspictures
    I’m not looking for any trades unless you have a Hummer H1 turbo diesel Wagon in black.
    If you have any question feel free to e mail me at
    [email protected]
    Or Instant message me at
    Yahoo: Gelaendawagenguy
    AOL: KerrsBFT
    In Lostsolvtec's bed!
    I will vouch for this car..
    Val For President
    R.I.P. Our Dear Leisa..
    ASAP N.E. Chapter VP
    No more supra
    NIKON Squad member| NikonD40
    VDUB BiH1320's Avatar
    dammn. nice supra. g/l on selling it.
    Quote Originally Posted by KERR
    What was it before?
    ***Lotus Elise***
    BlackWatchRacing
    BK ALL DAY
    nice car...
    GECKO SQUAD MEMBER
    MSS RACING REPRESENTA.....
    the saga continues....
    20 side of thangs
    sad day in supra country when this gets sold. *sniffle*
    This car was voted on of the most influential on the supra community on suraforums.com
    right along ther ewith Ken henderson and Ryan woon. that should be worth 60k a lone.
    i had it at $80, then 78k if it does not sale for 60 might just have to let dan start cutting to fit coil overs and run some 8's i hope
    無限 ぽわ D.Choe's Avatar
    Athens, GA
    DAMN. Someone's gonna be real happy $60k later.
    G'luck on the sale.
    2.0TRawr ironchef's Avatar
    Best supra i've seen hands down.
    superduper LLLLLLLLL
    damn that supra is bad ass!
    <--MY BITCH 8bangin302's Avatar
    Newnan,Ga
    O M GOOOOOODDDD..THAT IS ONE CLEAN SUPRA...GL ON THE SALE MAN...
    Someone call my lawyer... slyde_wayz's Avatar
    D.S.G.
    DAMMIT MAN!!!
    So Smoooth... Itll blow your teeth off!!
    That Fucking
    RUTSPEED / Boobies ! RutRoe's Avatar
    Peachtree City Area
    I'm really sorry that you feel so burdened by the mods of a FREE website.
    Thanks for doing it somewhat correctly, although obviously being a smartass about it.
    Either way, you've got the requirements, so whatever. Good luck with the sale.
    BooB CreW What ?
    One of IA's Awesome Mod's
    NASCAR on SPEED's Fun Guy
    HOST, Top Gear USA on History Channel starting late this Nov./Dec.
    Around metro-ATLANTA & IA!!
    I dont think anybody's got 60,000 dollars thats a member of ImportATL. LOL
    Supuh Man dAT HOE! IggyBcool's Avatar
    Cleveland, Tennessee
    Good looking supra... 60k for a 93? Bit too pricey IMO. Most banks you cannot get a loan of more than 20k on a car older than a '98
    | 02 Acura RSX Type-s DSM. Stockish |
    | 08 Kawi Green ZX10r not so stockish |
    San Antonio, TX
    Quote Originally Posted by RutRoe
    there are rules that are set up for everyone and posting your car up for sale you have to follow them
    some of them are posting VINS and PICS
    and pics actually HELP YOU sell the car
    and we have a strict rule on NO LINKS for pics/etc
    twoONEoh
    roflcopter V-Spec II
    Norcross
    1) Yeah man, the dig at the mods was slightly uncalled for.
    2) Holy shit, that car is hot.
    3) You flared out some TRD fenders? That explains why I saw TRD and widebody, but no 3000GT on the car. Flawless body work.
    4) Holy shit, that car is hot.
    Supra Turbo Owner
    Quote Originally Posted by IggyBcool
    If you don't mind me asking, what does that have to do with anything? The car clearly has FAR more $$$ invested into modifications than a bone-stock 93 would be worth. In other words, the new owner will be primarily buying the modifications & upgrades, not just the car itself. I'd suggest that the value of a bone-stock '93 (possibly a poorly maintained, worn-out '93) is almost irrelevant...as is the value a bank would loan you for a bone-stock '93.
    Beautiful Supra, Kerr. Good luck with the sale.
    Phil Panas
    Displacement is no replacement for boost.
    what
    Westside LA
    pics saved for masturbatory purposes
    Barrett Parkway, GA
    ^^^copy cat^^^
    buy it for me ren
    heheh... If I was going to buy it for anyone.. it would be for ME!!! Id so give my good kidney for this car..
    Val For President
    No more supra
    ......................... con's Avatar
    75 South......
    OMG...............*faints*
    Jay G. 1439/2000's Avatar
    Location, Location...
    Everyone on this website is SO poor if a buyer gets it off this website I will give you another 100 bucks.
    LOLZACOPTERSJKGP(*@&#NPIO
    All bark, no bite.
    CapitalOne Auto Finance will finance just about anything regardless of mileage, year, etc.
    Not to mention a good credit union will loan almost any amount for a good customer.
    The car has obviously been flawlessly modded, maintained and built.
    Good luck with the sale. The car is definitely worth the money. Just have to find the person that has the money.
    I'd consider it but I'm flying up to New York in 8 days to pick up my Z06. =D
    ALL BUSINE$$ RedGTS's Avatar
    Cartersville
    nice car, I'll let my rich friends know about it
    i might actually sell my 350z and everything i own and try to buy this.
    LAWRENCEVILLE
    Quote Originally Posted by pxhoang0408
    oh you would be surprised!!! bump for a sick!!! supra do you take testacles as payment??? Ill even let you chose the right or left one!!!
    Hella stock member!
    flowery branch
    DAMN!!!
    ~speechless~
    b00sT jUnKy khan351's Avatar
    the motherland
    $60k on import atlanta? lol
    badass supra, g/l w/ the sale
    Gwinnett-Grayson
    i thought mk4's werent untill 94? eitehr way one hell of a beautiful car
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    LAWRENCEVILLE
    Quote Originally Posted by blacknightteg
    Its a 1993.5 so its a early 94
    Hella stock member!
    Gwinnett-Grayson
    oh ok, i didnt know they came out with that body style im assuming the last half of 93.
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    Canton
    Nice car G/L on sale, can anyone front me 60K ill pay you back in installments.
    Try not. Do or Do not.
    GSXTACY SilverJester's Avatar
    Acworth
    Car looks fucking amazing, but is it just me or does 60k seem really high for a 93 supra?
    Quote Originally Posted by SilverJester
    It's just you.
    Nice car btw.
    02 GSX-R Telefonica Movistar
    99 Prelude
    95 Mustang GT Vert
    98 Mustang 3.8
    BYT joesblk_teg's Avatar
    kennesaw/L-ville
    this car should be in the red light district!!! *changes pants* damn this is like watching porn i feel guilty just looking at this thing. props for doin it right and good luck with sale, wish i had money
    Thanks for the reply’s, Yea i guess it was a stab at the guy that locked the thread but not everyone wants vin numbers posted. Also don’t see why posting a link is that big a deal after all that saves your band space.
    At any rate, those of you that have no clue on supra price feel free not to post, You can not buy a 93 turbo car for under 20K in any condition. To buy that car stock with less than 100K miles you looking at $25-28K. Then you ad in the body work, body kit, and color swap your now close to another $20K. Then built motor, fuel system, aem stuff, turbo kits, everything to get it to work is close to $30K... it ads up quick and you have to pay to play. I’m not mad about the commits but some of you have no clue what your talking about. I mean the intake system alone will run you $4k before it was painted. The front bumper, Duluck, was $2500....
    By all means if you feel its priced to high go buy another supra and duplicate this build up... Oh wait you cant, it a custom one off body kit, turbo kit and wheels that volk no longer builds.
    In sammich's house
    speak for yourself, I am one of those people and there are plenty others.
    Resize sig area!
    In sammich's house
    That car is one sick supra though, hope you sell it soon.
    Resize sig area!
    just a suggestion, i would spend the $500-600 to get it tuned, or half tuned an get some numbers from it. I think it would sell faster with 500-600whp on pump gas dyno attatched to it
    bump, awesome car
