Results 1 to 11 of 11
Thread: Panasonic Lumix 6.0MP Compact Digital Camera w/ 3.6x Optical Zoom & Other *OMG CHEAP*
    NalleyToyota Manager ct9a gsr's Avatar
    Kennesaw, Ga
    Thumbs up Panasonic Lumix 6.0MP Compact Digital Camera w/ 3.6x Optical Zoom & Other *OMG CHEAP*
    I'm selling my Panasonic compact digital camera that I've barely used. I think I've snapped a total of 10 pictures with this thing and it has never even left my house. The whole camera is absolutely scratchless and in absolutely 100% mint condition. It will come with:
    - 1x Panasonic DMC-FX01 Digital Camera
    - 1x Lithium Ion Rechargable Battery (specific to this camera)
    - 1x Lumix Battery Charger
    - 1x 16mb SD Card
    If you need a manual, I can provide you to a link to a .pdf file version of the manual. I will emphasize again, this camera is in absolute pristine condition. Also, please take the time to read all the amazing features this camera has below as it is not your traditional point 'n shoot camera but it is packed with a lot of special features and new technology.
    In case potential buyers are curious, I'm selling all of my digital imaging equipment so I can afford a HDV 1080i camcorder to make more professional-grade videos.
    Pictures of my actual camera:
    Priced to move fast:
    MSRP: $283.99
    My Price: $200 FIRM
    Click here for a 3D view.
    Camera Description:
    Bright F2.8, Wide-Angle 28mm1 LEICA DC VARIO-ELMARIT Lens
    The LEICA DC VARIO-ELMARIT lens on the DMC-FX01 employs an extra high refractive index aspherical lens that makes it possible to incorporate a wide 28mm zoom into its compact body. Spanning all the way from 28mm to 102mm (35mm equivalent), this lens lets you capture everything from sweeping landscapes to shots with deep rows of skyscrapers. Compared with conventional 35mm lens, the DMC-FX01's wide 28mm zoom lens makes it easier to capture an indoor group photo or architectures and sceneries with dynamic width and rich perspective.
    28mm
    35mm
    102mm
    137mm (with Extended Optical Zoom)
    The Extended Optical Zoom function, which magnifies the image with minimal deterioration by using the center part of the high resolution CCD, boosts the zoom power to a maximum 5x2.
    Taking Hand Movement Out of the Picture
    with MEGA Optical Image Stabilization
    All of us have taken a shot that we thought was focused perfectly, only to have it turn out blurry. The most common cause of this is hand movement. Digital cameras are wonderfully light and compact -- but for the same reason they can also be hard to hold still. Even pressing the shutter button can cause the camera to move. And most people use the LCD monitor (with arms outstretched)to frame a shot -- great for getting the shot you want, but most likely adds to the likelihood of hand movement. Basically, hand movement is a real concern anytime you're taking a handheld telephoto shot, macro shot or self-portrait, or when shooting at night or in dim lighting.
    Optical Image Stabilzation OFF
    Optical Image Stabilzation ON
    The answer to the hand movement problem? An advanced optical image stabilizing system that we call MEGA Optical Image Stabilization. This system uses built-in gyrosensors to detect even tiny camera movement and then shifts a lens in the opposite direction to compensate. The system is completely optical -- it does not affect the CCD or image processing -- so you get sharp, clear images with minimal degradation. It lets you reduce the shutter speed more than 3 steps below3 the conventionally accepted hand movement limit, which is calculated as 1/focal length (1 divided by the focal length). It greatly expands what you can do with a handheld digital camera.
    High Sensitivity Mode Helps Reduce Motion Blur
    When there's not a lot of light or you're using a slow shutter speed, hand movement isn't the only potential problem. There's also "motion blur" -- the blurring that can result if your subject like children or pets move even a little in low lighting. That's why we added a High Sensitivity mode4 that allows you to shoot at up to ISO 1600 by using the pixel-mixed readout method, effectively raising the shutter speed. It not only minimizes motion blur, it also lets you take clearer, sharper shots in dim lighting without using a flash. The picture quality is good enough for printing at the ordinary 4" x 6" (10 x 15 cm) size.
    High Sensitivity Mode OFF
    High Sensitivity Mode ON
    A Large, Bright 2.5" Diagonal High-Resolution LCD with High Angle Mode
    With its 2.5" diagonal size and 207,000 pixels, this high-resolution LCD monitor makes it easy to see text and small thumbnail images. The pixelmixed readout method performed by the CCD increases the brightness level of the live image on the LCD, which greatly facilitates shooting in low lighting. If it's difficult to see the display on a sunny day, simply press the Power LCD button and the display becomes about 40% brighter. The world's first5 developed High Angle shooting function also provides easier viewing when you're holding the camera high to shoot over the heads of people in front of you.
    Quick Response and Comfortable Shooting
    The DMC-FX01 starts up in just 1.6 seconds -- about 20% shorter than the DMC-FX9, has a release time lag as low as 0.005 seconds6, and can fire off up to 8 consecutive shots at 3 frames per second in Standard mode. It also has Unlimited Consecutive Shooting7, so you can keep shooting until the SD Memory Card is full. Furthermore, the 1-point high-speed AF is as fast as the DMC-FX9 to achieve outstanding focusing with speed and precision. You can shoot quickly, easily and accurately every time.
    Up to 3208 Shots On a Single Charge
    Thanks to the energy-saving Venus Engine™ Plus and a long-lasting battery, the slim DMC-FX01 lets you take shot after shot without running out of power. It takes up to 320 shots on a single battery charge -- about 18% more than the DMC-FX9.
    www.toyotaofroswell.com
    Current: '04 S2000
    Past 700whp+ Cars: '03 Z06 | '94 Supra | '03 Evo VIII | Too Many...
    Banned VTECin5th's Avatar
    Ask your mother?
    Whoa nice
    Kennesaw, Ga
    *bump*
    Current: '04 S2000
    Kennesaw, Ga
    *bump*
    Current: '04 S2000
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    OMFG?!!??!?! SO DAMN CHEAP i just bought one for like 800$ on ebay!!! CRAZY SHIT... i'd get it if i wasnt broke then sell it on ebay
    VDUB BiH1320's Avatar
    dammn nice digi cam. goodluck on selling it man. pretty cheap too.
    Kennesaw, Ga
    *bump*
    Current: '04 S2000
    I might be interested ill think about it and get back to you
    Germany
    only lookin at cash?
    Society-ZERO-Member #7
    Kennesaw, Ga
    I prefer cash only unless you have something I really may want... feel free to throw me offers.
    Current: '04 S2000
    I AM A SOCA WARRIOR TRINI4LIFE's Avatar
    C'vton
    Check your PM
    GOOOOOOOO SOCA WARRIORS !!!!!!!!!!!!!!!!!!!
