Results 1 to 21 of 21
Thread: Oil on sparkplug
    OMG&#WTFAWKK@!!@
    stockbridge
    Default Oil on sparkplug
    I found oils on all 4 of my spark plug and there were a good amount too. Does anyone know what could be the cause? Could this lead to an idling problem? bc the car wont idle when it is cold, but the idling is fine when it is warmed. (ka24de)
    Rock the 40oz GTScoob's Avatar
    GA Tech
    I'm not sure but I'd say thats probably bad piston rings if oil is getting up into the combustion chamber.
    02 WRX Sport Wagon
    Oil on the threads or are they fouling out your plugs?
    Super Dave Z U L8R's Avatar
    Roswell
    you have some blow by, most likely piston rings but you may wanna check the pcv valve if it's clogged or if it's good it'll rattle. that releases your positive crankcase pressure and if it's clogged up it'll find a way to release crankcase pressure ie past the piston rings thus creating your scenario and/or other oil leaks....i'd be a happy camper if i could fix my blow by with a pcv valve and 4 quarts of 20w-50. check that pcv valve
    your moms house
    sounds like rings possibly....
    FUCK B&D COMMUNICATIONS!
    Banned lsxtreme's Avatar
    hmm same scenerio but it doesn't hurt me none.. i love feeding my geesR with 20w 50 haah
    Vtecing is my HOBBY!!!
    Honda dealer
    does it smoke
    yeahhh
    Senior Member PRiMAdonna's Avatar
    St. Simons Island
    yeah it will cause your car to idle funny, and it's probably not operating on all four cylinders...
    i had the same problem with one of my old cars, except for the oil leak was only in one cylinder, and i had a cracked head gasket/cover. usually if you have a bad oil leak like that, you are going to have to replace everything. spark plugs/wires/tube seals/etc
    Belview Insane Asylum
    Is this on the threaded side where the electrode is or is it on top where it is getting on the plug wire too? If it is just on top where the plug wire is it is probably just the spark plug tube seals which aren't hard to replace.
    St. Simons Island
    i should probably just stay out of the tech section, lol
    Quote Originally Posted by PRiMAdonna
    Why? Your post is a possibility also.
    OMG&#WTFAWKK@!!@
    stockbridge
    well its on the thread of all 4 the sparkplugs and none are on the plug wire. so its either the pcv pipe that is clogged or the piston ring is leaking?. i've check on others 240 sites too and a few of them said it could be the valve cover o ring seal or something. how hard is it to fix the piston ring or the valve thingy? oh and it doesnt smoke. it just idle like crap :\ only idle when its warmed.
    Roswell
    if i tell you you need your motor rebuilt that'll make you at least check some of the things mentioned, so you need a motor =]
    Gainesville
    then it's prolly the seal for them..if it's not actually in the cynlider itself..
    OMG&#WTFAWKK@!!@
    stockbridge
    is it easy to replace the seals?
    Gainesville
    i would think so...but i'm not sure, with 240's anyways
    AE86 biotch!!!
    Take a look at the name of this site.
    Yeah it's not hard at all. Everything is just right there.
    AE86 DORIFTO
    Roswell
    buy a pcv valve, 4 quarts of 20w-50, a valve cover gasket set with the spark plug tube seals, 4 ngk v-power plugs, a six pack of bud ice, and what was that stuff we used to eat back in the day? oh yeah...PUSSY =]
    Gainesville
    ^^ lol..i don't know about you, but i still eat me some good ol poon every now and then, wht are you eatin on naw days? some ass or something?
    'Round These Parts
    inner valve cover seals.
    Leisa and S. 4 Life NM?
