PFS Stage II kit minus the HG and Tec3. Asking $4500 obo. Located about 55 minutes outside of Atlanta.
Information on PFS Stage II kit:
PFS divided pulse cast-steel exhaust manifold, 45mm SS TurboSmart wastegate, Turbo Smart Blow off valve, 60-1 Hi Fi series turbocharger, 3" mandrel bent SS downpipe back to the rear axle, 3" High flow catalytic converter, Custom Cool Charge air intake systen with K&N Hi Flow filter, PFS high volume fuel pump upgrade · Custom Electromotive TEC³ engine management system. · PFS Electronics Interface Module · Silicone hoses, clamps, heat shields, and all additional components required for a successful installation.
The Stage II kit includes all of the above components as well as a 3mm metal head gasket, Turbosmart boost controller, large front mount intercooler with 2.5" stainless steel piping kit and larger fuel injectors. This lowers the static compression ratio to a boost-friendly 8.6:1 for more horsepower output on pump gas. Typical installations result in over 400 RWHP at 15 psi of boost.
