Results 1 to 40 of 40
Thread: turbo my GSR??
    its all about the B's brwloco's Avatar
    Doraville,GA
    Default turbo my GSR??
    i wanna know if i should boost my GSR i have 138K on the motor, so the question is boost or n/a??
    97' Acura Integra GSR
    180 @ 9,000 RPM
    do a few tests see what the condition of the motor is...then boost
    Gainesville
    42 PSI FTW!!!!
    do a compression test. if the numbers are good, an youj car doesnt smoke or burn oil, then boost it.
    BK ALL DAY
    boost ftw..
    GECKO SQUAD MEMBER
    MSS RACING REPRESENTA.....
    the saga continues....
    Quote Originally Posted by Mr. 2JZKIDD
    ditto. Mileage isn't necessarily bad.
    Val for president!
    Facebook.com/TracyATL
    Unknown
    if it is a strong motor and the test work out. boost it.
    Because I eat RICE RiceBoy's Avatar
    Yeah, boost it..But make sure you have a spare motor for backup or at least another beater car.
    Quote Originally Posted by §treet_§peed
    42 PSI FTW!!!!
    BOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOMMMMMMMMMMMMMMMMMMM!!!!!!!!!! !!!
    I guarantee it
    Doraville,GA
    how much for a comp. test?
    180 @ 9,000 RPM
    Gainesville
    haha but that would a pretty awesome sight...
    Quote Originally Posted by brwloco
    I believe mainstream does them for free
    dont quote me tho
    -Taylor
    Lexus GS300
    Certified Gearhead JstAneon's Avatar
    Once you go boost, you'll never go back... Boost it.
    __DailyGrind
    do a leak down test as well
    Doraville,GA
    so how much do yall think i would b pushing on safe boost? and this is a daily driver
    180 @ 9,000 RPM
    Gainesville
    on what? stock period? few bolt ons and internals? just on stock everything?
    Gainesville
    if your doing it on stock i would say like 10-12 psi...
    Doraville,GA
    all of them, i dont care
    180 @ 9,000 RPM
    140 on one wheel
    columbus, ga
    i wouldnt go over 10 personally on a stock motor.
    Gainesville
    well you could push 10-12 on a stock GSR...couple of internals and others a little tuning some where's aorund 18...fully built out the ass and you could make it hold 30 psi...it is possible because GSR are better built to withstand boost...i know it is possible because i have seen a couple of Ls with and without vtec converison hold 30 psi and make around or at 600 whp but it's a honda so torque was shitty
    Gainesville
    and for a Honda motor to hold tthat much boost and hp it has to be properly built and tuned...no ghetto shit
    Grayson.
    if its a stock DD, boost it with a tial 38mm wastegate with an 0.6 spring inside, would be at 8psi. better be safe than sorry!!
    95 ej1--------536whp at 20psi on race gas!
    96 db7-------DD.
    95 eg1-------Sold
    94 dc2-------totalled
    94 dsm------donated to charity!!!
    WE RUN THEM BABY TURBOS AND BIG MANIFOLDS!!!!
    Gainesville
    i still say 42 PSI ftw...
    Doraville,GA
    lol yea ok 42
    180 @ 9,000 RPM
    I say boost it, put like a block guard on it, and get a setup where u can put down like 300-350WHP, that would be a good amount of power for a DD car
    -Taylor
    Lexus GS300
    hustler ksniperfox's Avatar
    lawrenceville
    fuck that shit. just weld the wastegate shut. get MaD P0WaH
    Doraville,GA
    hey SL33P3R how much r u making?
    180 @ 9,000 RPM
    We will find out tomorrow
    Lexus GS300
    Doraville,GA
    ?? getting it dynoed?
    180 @ 9,000 RPM
    dynotuned
    Lexus GS300
    Doraville,GA
    cool whos doing it? how much was ur setup?
    180 @ 9,000 RPM
    ®anj-♠ ranj's Avatar
    damn how long did that motor last? lol
    boost it. you can make 300HP reliable for a DD. its not abt PSI but HP
    Gainesville
    well its been like that for a while now...Mike aka Mr.2jzkidd ir Vteckidd knows more about it
    Gainesville
    and of course you won't drive it around all the time at 30 psi more like around 14 or 16 it's just tuned to be able to hold 30 when you want it..but very short amount of time lol..only like a couple of runs at the track then turn it back down
    Doraville,GA
    ^^ thats wut i most likely will end up doing
    180 @ 9,000 RPM
    Gainesville
    and btw as far as i know it's been almost a year and it's still doing good
    I am thankful for my Son
    Tyndall
    Peter's made like 475 whp, bone stock block, like 5 dyno runs and a couple at the track and was pulled when the built block was ready. Never blew up to my knowledge either.
    Tyndall
    But don't expect it to last very long, even with a great tune and low boost, the ringlands will crush over a rather short period of time.
    IA Member Catalin's Avatar
    Do not put a POS Block Gaurd in your motor. I was warned and i put one in anyway. I was a inexperienced dumbass! It distorted the shaped of the cylinder wall and restricted the coolant flow in the head. My compression sucks and the car runs 20 degrees hotter in the head than it should. Because it runs hot i blew a head gasket. You can leave the block alone for a low power set up. You can post the block for a little more power. You can sleeve the block and never worry about it again. NO Block Gaurd!!
