Results 1 to 15 of 15
Thread: New pics of Eagle Stroker Kit
    Default New pics of Eagle Stroker Kit
    The stoke is so big, half of it has to be kept out side the block
    ANOTHER reason why OEM cranks should ALWAYS be used
    your moms house
    what did this come out of
    FUCK B&D COMMUNICATIONS!
    your moms house
    and do we not have a 30 second rule tonight
    95mm B20 motor
    your moms house
    damn...bad ass then
    In the Fucking A
    There is nothing wrong with eagle cranks, someone dropped that crank before it was put in.
    I fucked İhris's mom
    ive NEVER had a 30sec rule since ive been a super mod
    Quote Originally Posted by Big Baller
    LOL
    it had a stress fracture form the factory(eagle) they already warrantied it.
    95mm Cranks in STOCK DECK HEIGHT blocks on hondas is RETARDED.
    OEM>EAGLE
    your moms house
    lol, that had to be it...
    mike, oh cause i dont have it now either some reason not complaining though
    LAWRENCEVILLE
    shit! I have never seen a broken crank on a honda!
    Hella stock member!
    who knows.
    omg...... oem it is then lol
    everywhere & nowhere
    EAGLE makes good shit... EXCEPT for cranks.
    Jeremy @ Inline Pro stuffed SCAT crank into my new block... it's (the motor)yet to be installed but this is a quote from my ORIGINAL inquiry with him. We hassled on pricing in the end, but he simply would NOT install an Eagle crank. LOL.
    "For 85mm you have to sleeve the engine.
    $1075 to sleeve the engine
    $1250 to bore, hone w/torque plate, hot tank, balance,
    blueprint, file fit the rings, measure bearing clearance,
    and shortblock assembly.
    $799 for 95 or 98mm Scat crankshaft( I would 100% not use
    eagle crankshafts we have had a ton of problems with them.
    They are junk!)
    $339 Eagle rods $799 if you use custom length
    $650 custom CP pistons(off the shelf pistons will not work
    with a stroker motor)
    $99 ACL bearing set (you should only use the race bearings
    if it going to be a track only car)
    $99 custom MLS gasket(you do not want to use copper)
    $139 ARP Headstuds
    $139 factory oil pump(the toda gears have problems) We run
    a factory pump on our 800whp integra that rev's to
    10200rpm and we have never broken an oil pump
    $75 Factory timing belt(I have seen issues with the greddy
    one)
    $40 misc gaskets
    $250 Supertech valves
    $399 Inlinepro Springs and Titanium retainers
    $60 Hardened Keepers
    $1250 Race Port job on the cylinder head
    $699 cams
    $650 top end assembly including checking valve to valve
    contact, valve to piston, plus valve adjustment
    HardParkin'
    i saw that on h-t he said it happened right after he installed his clutch
    one reason not to use a stage 54 clutch on a NA motor LOL
    but ya Eagle cranks are shit, there is a guy in town who SAYS he has an eagle crank, but i think its a SS autochrome LOL
    wow thats sucks had mine in for good 13k not a prob
