Results 1 to 17 of 17
Thread: Trouble Shooting
    Marryetah
    Default Trouble Shooting
    Nissan Diagnostic Thread
    Post any questions in regards to problems you’re having with your Nissan (mechanical and electrical)
    HIV+ HalfBaked's Avatar
    My motor isn't in my car.
    Public Enemy #1
    LOL i now something else that could help it!!!!!! but ...........like you said....
    All Motor EK N/A EK's Avatar
    On IA.com
    Reading codes
    NOTE: ONLY FOR 02 and up QR25DE
    EDIT: Here's how to do it:
    In car ECM Diagnostics/ECM Reset procedure:
    1) Sit in the driver's seat.
    2) Turn the ignition key to the ON position and wait three seconds. (Do not start the car.)
    3) Fully depress and release the accelerator pedal five times in less than five seconds.
    4) Wait exactly seven seconds. Fully depress the accelerator pedal for ten seconds until the MIL (SES) light flashes.
    5) Release the accelerator pedal and start counting flashes to obtain the four-digit trouble code.
    Long flashes (0.6 seconds) indicate the first digit of the code; count the blinks one through nine and write down the first digit. (Ten blinks indicates a zero.)
    The next three digits follow in turn in the same fashion except with faster blinks (0.3 second) and a 1.0-second pause between digits.
    The ECM code repeats intself until you turn the ignition key to the OFF position, at which point the ECM resets itself to standard get-in-and-drive-the-car mode.
    You can look up the trouble codes in the ESM/FSM; there's a bunch of them. In the ESM, refer to page EC-639.
    Additionally, if you get four blinks of ten (0000), the ECM is indicating no malfunction.
    You can clear the code (and the annoying MIL) by holding down the accelerator pedal for more than 10 seconds while in Diagnostic Test Mode II. When you release the pedal, the ECM erases the trouble code(s).
    Idle Relearn
    mods if you wish you can make this a sticky.
    this seems to be a pretty common thing if you swap tbs or clean your tb. Here is how you do it.
    -Warm up engine.
    -Turn ignition switch ?OFF? and wait at least 10 seconds.
    -Confirm that accelerator pedal is fully released, turn ignition switch ?ON? and wait 3 seconds.
    -Repeat the following procedure quickly five times within 5 seconds.
    a. Fully depress the accelerator pedal.
    b. Fully release the accelerator pedal.
    -Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stops
    blinking and turned ON.
    -Fully release the accelerator pedal within 3 seconds after the MIL goes ON.
    -Start engine and let it idle.
    -Wait 20 seconds.
    __________________________________________________ _____________________
    There's a couple of things you need to do before doing the idle relearn.
    Oh, also, make sure your car is in neutral, there's no electrical load (no a/c, headlights off, rear window defroster off, etc.), front wheels facing straight ahead, and of course car not moving
    First make sure you're at stock idle and timing.
    Do the Accelerator Pedal Released Position Learning first.
    1. Make sure accelerator pedal is fully released.
    2. Turn Ignition switch On and wait at least 2 seconds.
    3. Turn Ignition switch Off and wait at least 10 seconds.
    4. Turn Ignition switch On and wait at least 2 seconds.
    5. Turn Ignition switch Off and wait at least 10 seconds.
    Do the Throttle Valve Closed Position Learning next.
    2. Turn Ignition switch On.
    3. Turn Ignition switch Off, wait at least 10 seconds. Make sure that throttle valve moves during above 10 seconds by confirming the operating sound.
    Then do the Stock Idle relearn.
    Also, when doing the idle relearn, when it says to wait 7 seconds I usually count to 8 seconds. It seems to work better that way.
    On IA.com
    ECU codes
    P0100 Mass or Volume Air Flow Circuit Malfunction
    P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
    P0102 Mass or Volume Air Flow Circuit Low Input
    P0103 Mass or Volume Air Flow Circuit High Input
    P0104 Mass or Volume Air Flow Circuit Intermittent
    P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
    P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
    P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
    P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
    P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
    P0109 Intake Air Temperature Circuit Malfunction
    P0111 Intake Air Temperature Circuit Range/Performance Problem
    P0112 Intake Air Temperature Circuit Low Input
    P0113 Intake Air Temperature Circuit High Input
    P0114 Intake Air Temperature Circuit Intermittent
    P0115 Engine Coolant Temperature Circuit Malfunction
    P0116 Engine Coolant Temperature Circuit Range/Performance Problem
    P0117 Engine Coolant Temperature Circuit Low Input
    P0118 Engine Coolant Temperature Circuit High Input
    P0119 Engine Coolant Temperature Circuit Intermittent
    P0120 Throttle/Petal Position Sensor/Switch A Circuit Malfunction
    P0121 Throttle/Petal Position Sensor/Switch A Circuit Range/Performance Problem
    P0122 Throttle/Petal Position Sensor/Switch A Circuit Low Input
    P0123 Throttle/Petal Position Sensor/Switch A Circuit High Input
    P0124 Throttle/Petal Position Sensor/Switch A Circuit Intermittent
    P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
    P0126 Insufficient Coolant Temperature for Stable Operation
    P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
    P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
    P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
    P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
    P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
    P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
    P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
    P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
    P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
    P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
    P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
    P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
    P0142 O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
    P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
    P0144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
    P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
    P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
    P0147 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
    P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
    P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
    P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
    P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
    P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
    P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
    P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
    P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
    P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
    P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
    P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
    P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
    P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
    P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
    P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
    P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
    P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
    P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
    P0170 Fuel Trim Malfunction (Bank 1)
    P0171 System too Lean (Bank 1)
    P0172 System too Rich (Bank 1)
    P0173 Fuel Trim Malfunction (Bank 2)
    P0174 System too Lean (Bank 2)
    P0175 System too Rich (Bank 2)
    On IA.com
    P0177 Fuel Composition Sensor Circuit Range/Performance
    P0178 Fuel Composition Sensor Circuit Low Input
    P0179 Fuel Composition Sensor Circuit High Input
    P0180 Fuel Temperature Sensor A Circuit Malfunction
    P0181 Fuel Temperature Sensor A Circuit Range/Performance
    P0182 Fuel Temperature Sensor A Circuit Low Input
    P0183 Fuel Temperature Sensor A Circuit High Input
    P0184 Fuel Temperature Sensor A Circuit Intermittent
    P0185 Fuel Temperature Sensor B Circuit Malfunction
    P0186 Fuel Temperature Sensor B Circuit Range/Performance
    P0187 Fuel Temperature Sensor B Circuit Low Input
    P0188 Fuel Temperature Sensor B Circuit High Input
    P0189 Fuel Temperature Sensor B Circuit Intermittent
    P0190 Fuel Rail Pressure Sensor Circuit Malfunction
    P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
    P0192 Fuel Rail Pressure Sensor Circuit Low Input
    P0193 Fuel Rail Pressure Sensor Circuit High Input
    P0194 Fuel Rail Pressure Sensor Circuit Intermittent
    P0195 Engine Oil Temperature Sensor Malfunction
    P0196 Engine Oil Temperature Sensor Range/Performance
    P0197 Engine Oil Temperature Sensor Low
    P0198 Engine Oil Temperature Sensor High
    P0199 Engine Oil Temperature Sensor Intermittent
    P0200 Injector Circuit Malfunction
    P0201 Injector Circuit Malfunction - Cylinder 1
    P0202 Injector Circuit Malfunction - Cylinder 2
    P0203 Injector Circuit Malfunction - Cylinder 3
    P0204 Injector Circuit Malfunction - Cylinder 4
    P0205 Injector Circuit Malfunction - Cylinder 5
    P0206 Injector Circuit Malfunction - Cylinder 6
    P0207 Injector Circuit Malfunction - Cylinder 7
    P0208 Injector Circuit Malfunction - Cylinder 8
    P0209 Injector Circuit Malfunction - Cylinder 9
    P0210 Injector Circuit Malfunction - Cylinder 10
    P0211 Injector Circuit Malfunction - Cylinder 11
    P0212 Injector Circuit Malfunction - Cylinder 12
    P0213 Cold Start Injector 1 Malfunction
    P0214 Cold Start Injector 2 Malfunction
    P0215 Engine Shutoff Solenoid Malfunction
    P0216 Injection Timing Control Circuit Malfunction
    P0217 Engine Overtemp Condition
    P0218 Transmission Over Temperature Condition
    P0219 Engine Overspeed Condition
    P0220 Throttle/Petal Position Sensor/Switch B Circuit Malfunction
    P0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
    P0222 Throttle/Petal Position Sensor/Switch B Circuit Low Input
    P0223 Throttle/Petal Position Sensor/Switch B Circuit High Input
    P0224 Throttle/Petal Position Sensor/Switch B Circuit Intermittent
    P0225 Throttle/Petal Position Sensor/Switch C Circuit Malfunction
    P0226 Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
    P0227 Throttle/Petal Position Sensor/Switch C Circuit Low Input
    P0228 Throttle/Petal Position Sensor/Switch C Circuit High Input
    P0229 Throttle/Petal Position Sensor/Switch C Circuit Intermittent
    P0230 Fuel Pump Primary Circuit Malfunction
    P0231 Fuel Pump Secondary Circuit Low
    P0232 Fuel Pump Secondary Circuit High
    P0233 Fuel Pump Secondary Circuit Intermittent
    P0234 Engine Overboost Condition
    P0235 Turbocharger Boost Sensor A Circuit Malfunction
    P0236 Turbocharger Boost Sensor A Circuit Range/Performance
    P0237 Turbocharger Boost Sensor A Circuit Low
    P0238 Turbocharger Boost Sensor A Circuit High
    P0239 Turbocharger Boost Sensor B Malfunction
    P0240 Turbocharger Boost Sensor B Circuit Range/Performance
    P0241 Turbocharger Boost Sensor B Circuit Low
    P0242 Turbocharger Boost Sensor B Circuit High
    P0243 Turbocharger Wastegate Solenoid A Malfunction
    P0244 Turbocharger Wastegate Solenoid A Range/Performance
    P0245 Turbocharger Wastegate Solenoid A Low
    P0246 Turbocharger Wastegate Solenoid A High
    P0247 Turbocharger Wastegate Solenoid B Malfunction
    P0248 Turbocharger Wastegate Solenoid B Range/Performance
    P0249 Turbocharger Wastegate Solenoid B Low
    P0250 Turbocharger Wastegate Solenoid B High
    P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
    P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
    P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
    P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
    P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
    P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
    P0257 Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
    P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
    P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
    P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
    P0261 Cylinder 1 Injector Circuit Low
    P0262 Cylinder 1 Injector Circuit High
    P0263 Cylinder 1 Contribution/Balance Fault
    P0264 Cylinder 2 Injector Circuit Low
    P0265 Cylinder 2 Injector Circuit High
    P0266 Cylinder 2 Contribution/Balance Fault
    P0267 Cylinder 3 Injector Circuit Low
    P0268 Cylinder 3 Injector Circuit High
    P0269 Cylinder 3 Contribution/Balance Fault
    P0270 Cylinder 4 Injector Circuit Low
    P0271 Cylinder 4 Injector Circuit High
    P0272 Cylinder 4 Contribution/Balance Fault
    P0273 Cylinder 5 Injector Circuit Low
    P0274 Cylinder 5 Injector Circuit High
    P0275 Cylinder 5 Contribution/Balance Fault
    P0276 Cylinder 6 Injector Circuit Low
    P0277 Cylinder 6 Injector Circuit High
    P0278 Cylinder 6 Contribution/Balance Fault
    P0279 Cylinder 7 Injector Circuit Low
    P0280 Cylinder 7 Injector Circuit High
    P0281 Cylinder 7 Contribution/Balance Fault
    P0282 Cylinder 8 Injector Circuit Low
    P0283 Cylinder 8 Injector Circuit High
    P0284 Cylinder 8 Contribution/Balance Fault
    P0285 Cylinder 9 Injector Circuit Low
    P0286 Cylinder 9 Injector Circuit High
    P0287 Cylinder 9 Contribution/Balance Fault
    P0288 Cylinder 10 Injector Circuit Low
    P0289 Cylinder 10 Injector Circuit High
    P0290 Cylinder 10 Contribution/Balance Fault
    P0291 Cylinder 11 Injector Circuit Low
    P0292 Cylinder 11 Injector Circuit High
    P0293 Cylinder 11 Contribution/Balance Fault
    P0294 Cylinder 12 Injector Circuit Low
    P0295 Cylinder 12 Injector Circuit High
    P0296 Cylinder 12 Contribution/Range Fault
    P0300 Random/Multiple Cylinder Misfire Detected
    P0301 Cylinder 1 Misfire Detected
    P0302 Cylinder 2 Misfire Detected
    P0303 Cylinder 3 Misfire Detected
    P0304 Cylinder 4 Misfire Detected
    P0305 Cylinder 5 Misfire Detected
    P0306 Cylinder 6 Misfire Detected
    P0307 Cylinder 7 Misfire Detected
    P0308 Cylinder 8 Misfire Detected
    P0309 Cylinder 9 Misfire Detected
    P0311 Cylinder 11 Misfire Detected
    P0312 Cylinder 12 Misfire Detected
    P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
    P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
    P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
    P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
    P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
    P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
    P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
    P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
    P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
    P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
    P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
    P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
    P0333 Knock Sensor 2 Circuit High Input (Bank 2)
    P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
    P0335 Crankshaft Position Sensor A Circuit Malfunction
    P0336 Crankshaft Position Sensor A Circuit Range/Performance
    P0337 Crankshaft Position Sensor A Circuit Low Input
    P0338 Crankshaft Position Sensor A Circuit High Input
    P0339 Crankshaft Position Sensor A Circuit Intermittent
    P0340 Camshaft Position Sensor Circuit Malfunction
    P0341 Camshaft Position Sensor Circuit Range/Performance
    P0342 Camshaft Position Sensor Circuit Low Input
    P0343 Camshaft Position Sensor Circuit High Input
    P0344 Camshaft Position Sensor Circuit Intermittent
    P0350 Ignition Coil Primary/Secondary Circuit Malfunction
    P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
    P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
    P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
    P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
    P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
    P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
    P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
    P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
    P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
    P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
    P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
    P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
    P0370 Timing Reference High Resolution Signal A Malfunction
    On IA.com
    P0371 Timing Reference High Resolution Signal A Too Many Pulses
    P0372 Timing Reference High Resolution Signal A Too Few Pulses
    P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
    P0374 Timing Reference High Resolution Signal A No Pulses
    P0375 Timing Reference High Resolution Signal B Malfunction
    P0376 Timing Reference High Resolution Signal B Too Many Pulses
    P0377 Timing Reference High Resolution Signal B Too Few Pulses
    P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
    P0379 Timing Reference High Resolution Signal B No Pulses
    P0380 Glow Plug/Heater Circuit "A" Malfunction
    P0381 Glow Plug/Heater Indicator Circuit Malfunction
    P0382 Exhaust Gas Recirculation Flow Malfunction
    P0385 Crankshaft Position Sensor B Circuit Malfunction
    P0386 Crankshaft Position Sensor B Circuit Range/Performance
    P0387 Crankshaft Position Sensor B Circuit Low Input
    P0388 Crankshaft Position Sensor B Circuit High Input
    P0389 Crankshaft Position Sensor B Circuit Intermittent
    P0400 Exhaust Gas Recirculation Flow Malfunction
    P0401 Exhaust Gas Recirculation Flow Insufficient Detected
    P0402 Exhaust Gas Recirculation Flow Excessive Detected
    P0403 Exhaust Gas Recirculation Circuit Malfunction
    P0404 Exhaust Gas Recirculation Circuit Range/Performance
    P0405 Exhaust Gas Recirculation Sensor A Circuit Low
    P0406 Exhaust Gas Recirculation Sensor A Circuit High
    P0407 Exhaust Gas Recirculation Sensor B Circuit Low
    P0408 Exhaust Gas Recirculation Sensor B Circuit High
    P0410 Secondary Air Injection System Malfunction
    P0411 Secondary Air Injection System Incorrect Flow Detected
    P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
    P0413 Secondary Air Injection System Switching Valve A Circuit Open
    P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
    P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
    P0416 Secondary Air Injection System Switching Valve B Circuit Open
    P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
    P0418 Secondary Air Injection System Relay "A" Circuit Malfunction
    P0419 Secondary Air Injection System Relay "B" Circuit Malfunction
    P0420 Catalyst System Efficiency Below Threshold (Bank 1)
    P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
    P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
    P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
    P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
    P0430 Catalyst System Efficiency Below Threshold (Bank 2)
    P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
    P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
    P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
    P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
    P0440 Evaporative Emission Control System Malfunction
    P0441 Evaporative Emission Control System Incorrect Purge Flow
    P0442 Evaporative Emission Control System Leak Detected (small leak)
    P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
    P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
    P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
    P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
    P0447 Evaporative Emission Control System Vent Control Circuit Open
    P0448 Evaporative Emission Control System Vent Control Circuit Shorted
    P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
    P0450 Evaporative Emission Control System Pressure Sensor Malfunction
    P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
    P0452 Evaporative Emission Control System Pressure Sensor Low Input
    P0453 Evaporative Emission Control System Pressure Sensor High Input
    P0454 Evaporative Emission Control System Pressure Sensor Intermittent
    P0455 Evaporative Emission Control System Leak Detected (gross leak)
    P0460 Fuel Level Sensor Circuit Malfunction
    P0461 Fuel Level Sensor Circuit Range/Performance
    P0462 Fuel Level Sensor Circuit Low Input
    P0463 Fuel Level Sensor Circuit High Input
    P0464 Fuel Level Sensor Circuit Intermittent
    P0465 Purge Flow Sensor Circuit Malfunction
    P0466 Purge Flow Sensor Circuit Range/Performance
    P0467 Purge Flow Sensor Circuit Low Input
    P0468 Purge Flow Sensor Circuit High Input
    P0469 Purge Flow Sensor Circuit Intermittent
    P0470 Exhaust Pressure Sensor Malfunction
    P0471 Exhaust Pressure Sensor Range/Performance
    P0472 Exhaust Pressure Sensor Low
    P0473 Exhaust Pressure Sensor High
    P0474 Exhaust Pressure Sensor Intermittent
    P0475 Exhaust Pressure Control Valve Malfunction
    P0476 Exhaust Pressure Control Valve Range/Performance
    P0477 Exhaust Pressure Control Valve Low
    P0478 Exhaust Pressure Control Valve High
    P0479 Exhaust Pressure Control Valve Intermittent
    P0480 Cooling Fan 1 Control Circuit Malfunction
    P0481 Cooling Fan 2 Control Circuit Malfunction
    P0482 Cooling Fan 3 Control Circuit Malfunction
    P0483 Cooling Fan Rationality Check Malfunction
    P0484 Cooling Fan Circuit Over Current
    P0485 Cooling Fan Power/Ground Circuit Malfunction
    P0500 Vehicle Speed Sensor Malfunction
    P0501 Vehicle Speed Sensor Range/Performance
    P0502 Vehicle Speed Sensor Low Input
    P0503 Vehicle Speed Sensor Intermittent/Erratic/High
    P0505 Idle Control System Malfunction
    P0506 Idle Control System RPM Lower Than Expected
    P0507 Idle Control System RPM Higher Than Expected
    P0510 Closed Throttle Position Switch Malfunction
    P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
    P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
    P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
    P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
    P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
    P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
    P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
    P0533 A/C Refrigerant Pressure Sensor Circuit High Input
    P0534 Air Conditioner Refrigerant Charge Loss
    P0550 Power Steering Pressure Sensor Circuit Malfunction
    P0551 Power Steering Pressure Sensor Circuit Range/Performance
    P0552 Power Steering Pressure Sensor Circuit Low Input
    P0553 Power Steering Pressure Sensor Circuit High Input
    P0554 Power Steering Pressure Sensor Circuit Intermittent
    P0560 System Voltage Malfunction
    P0561 System Voltage Unstable
    P0562 System Voltage Low
    P0563 System Voltage High
    P0565 Cruise Control On Signal Malfunction
    P0566 Cruise Control Off Signal Malfunction
    P0567 Cruise Control Resume Signal Malfunction
    P0568 Cruise Control Set Signal Malfunction
    P0569 Cruise Control Coast Signal Malfunction
    P0570 Cruise Control Accel Signal Malfunction
    P0571 Cruise Control/Brake Switch A Circuit Malfunction
    P0572 Cruise Control/Brake Switch A Circuit Low
    P0573 Cruise Control/Brake Switch A Circuit High
    P0574 Cruise Control Related Malfunction
    P0575 Cruise Control Related Malfunction
    P0576 Cruise Control Related Malfunction
    P0578 Cruise Control Related Malfunction
    P0579 Cruise Control Related Malfunction
    P0580 Cruise Control Related Malfunction
    P0600 Serial Communication Link Malfunction
    P0601 Internal Control Module Memory Check Sum Error
    P0602 Control Module Programming Error
    P0603 Internal Control Module Keep Alive Memory (KAM) Error
    P0604 Internal Control Module Random Access Memory (RAM) Error
    P0605 Internal Control Module Read Only Memory (ROM) Error
    P0606 PCM Processor Fault
    P0608 Control Module VSS Output "A" Malfunction
    P0609 Control Module VSS Output "B" Malfunction
    P0620 Generator Control Circuit Malfunction
    P0621 Generator Lamp "L" Control Circuit Malfunction
    P0622 Generator Field "F" Control Circuit Malfunction
    P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
    P0654 Engine RPM Output Circuit Malfunction
    P0655 Engine Hot Lamp Output Control Circuit Malfucntion
    P0656 Fuel Level Output Circuit Malfunction
    P0700 Transmission Control System Malfunction
    P0701 Transmission Control System Range/Performance
    P0702 Transmission Control System Electrical
    P0703 Torque Converter/Brake Switch B Circuit Malfunction
    P0704 Clutch Switch Input Circuit Malfunction
    P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
    P0706 Transmission Range Sensor Circuit Range/Performance
    P0707 Transmission Range Sensor Circuit Low Input
    P0708 Transmission Range Sensor Circuit High Input
    P0709 Transmission Range Sensor Circuit Intermittent
    P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
    P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
    P0712 Transmission Fluid Temperature Sensor Circuit Low Input
    P0713 Transmission Fluid Temperature Sensor Circuit High Input
    P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
    P0715 Input/Turbine Speed Sensor Circuit Malfunction
    P0716 Input/Turbine Speed Sensor Circuit Range/Performance
    P0717 Input/Turbine Speed Sensor Circuit No Signal
    P0718 Input/Turbine Speed Sensor Circuit Intermittent
    P0719 Torque Converter/Brake Switch B Circuit Low
    P0720 Output Speed Sensor Circuit Malfunction
    P0721 Output Speed Sensor Range/Performance
    P0722 Output Speed Sensor No Signal
    P0723 Output Speed Sensor Intermittent
    P0724 Torque Converter/Brake Switch B Circuit High
    P0725 Engine Speed input Circuit Malfunction
    P0726 Engine Speed Input Circuit Range/Performance
    P0727 Engine Speed Input Circuit No Signal
    P0728 Engine Speed Input Circuit Intermittent
    P0730 Incorrect Gear Ratio
    P0731 Gear 1 Incorrect ratio
    P0732 Gear 2 Incorrect ratio
    P0733 Gear 3 Incorrect ratio
    P0734 Gear 4 Incorrect ratio
    P0735 Gear 5 Incorrect ratio
    P0736 Reverse incorrect gear ratio
    P0740 Torque Converter Clutch Circuit Malfuction
    P0741 Torque Converter Clutch Circuit Performance or Stuck Off
    P0742 Torque Converter Clutch Circuit Stuck On
    P0743 Torque Converter Clutch Circuit Electrical
    P0744 Torque Converter Clutch Circuit Intermittent
    P0745 Pressure Control Solenoid Malfunction
    P0746 Pressure Control Solenoid Performance or Stuck Off
    P0747 Pressure Control Solenoid Stuck On
    P0748 Pressure Control Solenoid Electrical
    P0749 Pressure Control Solenoid Intermittent
    P0750 Shift Solenoid A Malfunction
    P0751 Shift Solenoid A Performance or Stuck Off
    P0752 Shift Solenoid A Stuck On
    P0753 Shift Solenoid A Electrical
    P0754 Shift Solenoid A Intermittent
    P0755 Shift Solenoid B Malfunction
    P0756 Shift Solenoid B Performance or Stuck Off
    P0757 Shift Solenoid B Stuck On
    P0758 Shift Solenoid B Electrical
    P0759 Shift Solenoid B Intermittent
    P0760 Shift Solenoid C Malfunction
    P0761 Shift Solenoid C Performance or Stuck Off
    P0762 Shift Solenoid C Stuck On
    P0763 Shift Solenoid C Electrical
    P0764 Shift Solenoid C Intermittent
    P0765 Shift Solenoid D Malfunction
    P0766 Shift Solenoid D Performance or Stuck Off
    P0767 Shift Solenoid D Stuck On
    P0768 Shift Solenoid D Electrical
    P0769 Shift Solenoid D Intermittent
    P0770 Shift Solenoid E Malfunction
    P0771 Shift Solenoid E Performance or Stuck Off
    P0772 Shift Solenoid E Stuck On
    P0773 Shift Solenoid E Electrical
    P0774 Shift Solenoid E Intermittent
    P0780 Shift Malfunction
    P0781 1-2 Shift Malfunction
    P0782 2-3 Shift Malfunction
    P0783 3-4 Shift Malfunction
    P0784 4-5 Shift Malfunction
    P0785 Shift/Timing Solenoid Malfunction
    P0786 Shift/Timing Solenoid Range/Performance
    P0787 Shift/Timing Solenoid Low
    P0788 Shift/Timing Solenoid High
    P0789 Shift/Timing Solenoid Intermittent
    P0790 Normal/Performance Switch Circuit Malfunction
    P0801 Reverse Inhibit Control Circuit Malfunction
    P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
    P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
    On IA.com
    **note: I don't know why the Nissan website took off all info for the recalls. However it's all here in this post.**
    As of now (May 21, 2004) there have been a total of 5 recalls for the 2002 Sentra, 3 recalls for the 2003 Sentra and 1 recall for the 2004 Sentra.
    All information in this post is directly off of Nissan's website (minus the sarcasm, which is directly from my dog...his name is Skunk)
    For more information on any of these recalls, or new ones visit this Nissan page...
    http://www.nissanusa.com/form/0,,act...-51054,00.html
    quick check list
    2002 Sentra/SE-R/Spec-V
    • ~crank position sensor recall
      ~ECU case holder foam recall
      ~pre-catalyst recall (most concern)
      ~floor mat replacement recall (SE-R/Spec-V)
      ~headlamp adjuster recall (non SE-R/Spec-V)
    2003 Sentra/SE-R/Spec-V
      ~ECU case holder foam recall (SE-R/Spec-V)
    2004 Sentra/SE-R/Spec-V
    • ~pre-catalyst recall (most concern)
    _________________
    Recall R3022: 2000-2003 Sentra Engine Sensors Voluntary Recall
    (aka: crank position sensor recall)
    Applications
    *2001 Sentra models in the following Vehicle Identification Number ranges:
    3N1CB51**1L004135-525647
    3N1DB51**1L020201-020705
    *2002 Sentra models in the following Vehicle Identification Number range:
    3N1CB51**2L550003-693996
    *2003 Sentra models in the following Vehicle Identification Number range:
    3N1CB51**3L556548-694400
    Number Affected
    "approximately 243,562"
    Reason
    "On some 2000-2003 Sentras, there is a possibility that the engine might stop running while being driven if the crank position sensor fails. This may also result in the "Service Engine Soon" light coming on or reduced engine power. If the engine stops running while driving, this could result in a crash without warning."
    Translation: There is a sensor for the crank position. There is a chance it could fail, which you don't want. I would suggest getting this recall performed. (If that sensor should fail, your car could automatically shut off and result in driver spontanious combustion...by default. j/k)
    More Infromation
    Nissan USA recall info (type in Model+Year under search): http://www.nissanusa.com/form/0,,action-NRecallPublicLanding_sctid-51054,00.html#30551
    _________________
    Recall P3163: 2000-2002 Sentra Engine Control Module (ECM) Case Holder
    (aka: ECU case holder foam recall)
    Applications
    *2000 Sentra models in the following Vehicle Identification Number ranges:
    3N1CB51**YL003216 - 385976
    3N1DB51**YL000201 - 020126
    3N1CB51**1L391002 - 525647
    3N1DB51**1L020201 - 020705
    3N1CB51**2L550003 - 693996
    Number Affected
    "approximately 243,152"
    Reason
    "On some 2000-2002 model year Nissan Sentra vehicles described above, there is a possibility that the engine may stop running while being driven due to contamination of the Engine Control Module (ECM) by the inner lining material. This may also result in the "Service Engine Soon" light coming on or poor driveability. If the engine stops running while driving, this could result in a crash without warning."
    (I think they just like to say the phrase, "crash without warning")
    Translation: Due to some foam, your ECU could stop working and turn your car off...somehow due to foam. Once again...FOAM! I would suggest getting this done at the same time you are getting the sensor recall done. 2 recalls one stone...or something like that.
    More Infromation
    _________________
    Recall R3016: 2002-2004 Sentra Pre-Catalyst Recall
    (the recall of most concern)
    Applications
    3N1AB51**2L700019 - 730181
    3N1AB51**3L716572 - 736783
    *2004 Sentra models in the following Vehicle Identification Number ranges:
    3N1AB51**4L727627 - 730593
    3N1AB51**4L736618 - 738436
    Number Affected
    no # stated
    "Only a limited number of GXE model vehicles equipped with the 2.5 Liter engine are affected by this campaign. If your vehicle is not equipped with the 2.5 Liter engine, it is not affected by this campaign."
    Reason
    "There is a possibility that certain engine operating conditions may cause damage to the pre-catalyst. Material from inside a damaged pre-catalyst could enter the engine and result in increased oil consumption. If the engine oil level is not checked on a periodic basis and drops below the low level, and the driver continues to operate the vehicle ignoring noticeable engine noise, engine damage may occur which could result in a fire."
    Translation: Ok, the pre-catalyst (pre-cat) is the big huge cancer looking thing on the stock header. It is covered by the stock heat shield so your wondering eyes won't be tempted to look at the forbidden fruit. Basically what can happen is that the pre-cat can overheat and start to break apart. The engine can suck in broken pieces of the pre-cat through the header...bad stuff will then happen. If you have an aftermarket header it is "highly recommended" that you replace the stock header and go in for the recall. You can then switch back headers once the recall is performed.
    More Infromation
    Thread from thevboard: http://forums.thevboard.com/viewtopic.php?p=218290#218290
    _________________
    Recall: 2002 Sentra SE-R Front Floor Mat Replacement
    Application
    *2002 Sentra (B15) SE-R ONLY (all models of SE-R), the following Vehicle Identification Number Range:
    3N1AB51**2L700019 to 708726
    3N1AB51**2L725046 to 727746
    Number Affected
    "approximately 9,700"
    Reason
    "Your vehicle may be equipped with Nissan approved accessory floor mats. If the driver side floor mat moves out of position, it may interfere with the accelerator pedal and not allow the pedal to release after it is pushed down. If this occurs unexpectedly, it could lead to a crash."
    Translation: If your drivers side floor mat fits like crap and your sentra is within the VIN numbers affected, Nissan will give you a new one.
    More Info
    Recall: 2001-2002 Sentra/Headlamp Adjuster Recall
    Application
    *2001 Sentra (B15), the following Vehicle Identification Number range:
    3N1BB51**1L003110 - 131125
    3N1CB51**1L391291 - 525647
    3N1DB51**1L020471 - 020705
    *2002 Sentra (B15), the following Vehicle Identification Number range:
    3N1CB51**2L550004 - 621169
    3N1AB51**2L700019 - 725690
    Number Affected
    "approximately 80,000"
    Reason
    "Nissan has determined that the headlamp assemblies on some 2001 - 2002 Nissan Sentra vehicles fail to comply with Federal Motor Vehicle Safety Standard 108 ? Lamps, Reflective Devices, and Associated Equipment.
    In order to meet Safety Standard 108, tamperproof caps are installed at the factory on the horizontal adjustment device of the headlamp assemblies. This is to prevent misadjustment of the headlamps. These tamperproof caps were mistakenly omitted on your vehicle."
    Translation: Things to prevent you from adjusting your headlights horizontally were not installed. This is for you who have too much time on your hands, or if you just hate your dealership and want to waste thier time.
    More Info
    Flowery Branch, GA
    Good stuff.
    Senior Member Maki's Avatar
    Alpharetta
    Those are OBD II ill post the OBD I codes for you guys.
    11 Crank angle sensor
    12 Maf
    13 Coolant temp sensor
    14 Speed sensor
    21 Ignition Signal
    22 Fuel Pump
    23 Idle switch
    24 Throttle valve switch
    25 IAC valve
    26 Boost pressure sensor
    27 Cooling Fan switch (overheat)
    31 ECM
    32 EGR function
    33 O2 #1 (front O2)
    34 Knock sensor
    35 EGT Sensor
    36 EGR BPT Valve
    37 Closed loop system
    38 LH Bank closed loop
    41 IAT Sensor
    42 Fuel temp sensor
    43 TPS
    45 Injector Leak
    47 Crank Pos Sensor
    51 Injector Circuit
    53 O2S
    54 A/T Control
    55 All Clear
    63 Cyl 6 Mis
    64-68 Cyl 5, 4, 3, 2, 1 mis
    71 Random Misfire
    72 TW Catalyst System
    76 Fuel Inj System
    77 Rear O2
    82 Crank Pos sensor
    enjoy
    Senior Member Krazykouki's Avatar
    Ball Ground
    Just PM me for RB20/25/26/30 FSM's
    unless someone wants to host the files for me....I also have the s15/14/13 Japanese FSM's.
    No Homo.
    It's just a Sentra
    Gwinnett, Georgia
    USDM 95-97 Nissan 200SX SE-R ECU PIN OUT.
    My contribution.
    Attached Thumbnails Attached Thumbnails -95-97pinout-jpg
    "If you want peace, prepare for war"
    i just changed the power antenna on my 96 maxima and now the radio is phucked up. all the lights are lit up in a weird pattern, it's a bose headunit w/ both the cd and tape if it matters. How do i reset it?
    Interwebs terrorist Friggintitsman's Avatar
    Nevermind
    I thrive on caffineand HATE
    My 2003 Nissan Sentra SpecV is running really shitty. It sputters when I accelerate up to 2000 rpm then levels out. Then around 3-3.5k RPM is sputters in a different way. Any suggestions?
    Watcha waitin fa?! Niye's Avatar
    Apr 2013
    Boondocks, GA
    As
    I
    Die
    Slowly
    Lmfao
