Thread: '99 Cadillac Deville Speaker Removal
    Family Sedan... :-D Accordingly's Avatar
    Norcross
    Default '99 Cadillac Deville Speaker Removal
    My roommate just got a '99 Cadillac Deville and we're putting in some stereo stuff. I got stuck on the removal of the rear 6 X 9's. I probably could figure it out, but I rather just read a write up if somebody knows of one. help please?
    Senior Member | IA Veteran DJ XtRaKŠ's Avatar
    Apr 2001
    Roswell
    REAR DECK SPEAKER INSTALLATION:
    NOTE: THE FACTORY PROVISIONS ARE FOR 6 X 9" SPEAKERS.
    1. PUSH IN AND PULL UP ON THE REAR SEAT BOTTOM TO RELEASE IT AND
    REMOVE.
    2. EXTRACT (2) 3/4" BOLTS HOLDING THE REAR SEATBELT BUCKLES.
    3. OPEN THE TRUNK AND REMOVE (4) PLASTIC NUTS AT BACK EDGE OF
    REAR DECK/SEAT BACK COVER.
    4. PULL REAR DECK/SEAT-BACK COVER DOWN AND REMOVE 11 MM NUTS
    FROM THE (2) STUDS COMING THROUGH THE TRUNK STEEL WALL
    (FROM INSIDE THE VEHICLE) AT THE TOP CORNERS.
    5. FROM INSIDE THE VEHICLE GRAB THE BACK SEAT UPRIGHT CUSHION,
    PULL AWAY FROM REAR WINDOW AND LIFT UPWARD TO REMOVE THE
    CUSHION.
    6. POP OUT (1) PANEL FASTENER FROM THE FRONT EDGE OF THE REAR
    DECK MATERIAL.
    7. PULL UP ON 3RD BRAKE LIGHT COVER TO REMOVE.
    8. REMOVE REAR DECK.
    9. USING A PANEL REMOVAL TOOL PRY UP ON THE EDGE OF SPEAKER TO
    RELEASE (4) SPRING CLIPS HOLDING SPEAKER IN, UNPLUG AND
    REMOVE.
    IA OG
    Norcross
    Thanks!
    Apr 2001
    Roswell
    did it work?
    IA OG
    your moms house
    xtraz, you memorized that or is that written somewhere?
    FUCK B&D COMMUNICATIONS!
    Apr 2001
    Roswell
    both
    IA OG
    Norcross
    im gunna do it tomorrow morning, ill let ya know
    Norcross
    yeah, your info worked. thanks again!
    Apr 2001
    Roswell
    DAMNNNNNNNN RIGHT!!!! i rock
    IA OG
