Results 1 to 10 of 10
Thread: HOOKIN UP BOOST CONTROLER
    OG noob whoopass's Avatar
    cleveland
    Default HOOKIN UP BOOST CONTROLER
    I have hooked up a manual boost controler , I don't think I've hooked it up RIGHT. please tell me how so I can be SURE.
    THANK YOU....
    stockbridge
    it is the vaccum line that goes to your wastegate, simply cut that hose, and hook to each end of bc. when u first start, have it turned all the way out, then as u drive it turn it down i nsmall incremeints to gain more boost.
    cleveland
    some one told me that I was to put a T FITTING ON THAT HOSE AND RUN ONLY ONE HOSE TO THE BC. SEE THE WAY I HAVE IT NOW IS LIKE U JUST SAID.
    stockbridge
    u jsut cut it and hook each end to an end on the bc..heres how it works (makes it easier to do"
    !!this is all "easy descriptions" so dotn flame me~~
    vaccum line measures vaccum/ boost
    goes from intale manny, to turbo, tells turbo when too much air is being forced in and stops turbo from boosting more..
    u put bc on there to lessen the flow of air to trick ur turbo to think tis not flowing enough and to flow more, hence more boost, the controller jsut makes it harder for the air to get through make ing the reading lower.
    Gainesville
    Casey....
    stockbridge
    easiest way to state it to make it easy to do, if u understand what u doin, it makes it easier, u have to know why ur doing it to understand.
    Gainesville
    hey bitch why ain't you on IAM???
    stockbridge
    my comp too slow, i get bombarded with ppl , and my comp shuts off.. like last night lol
    Gainesville
    DAMN foo you need to im me...but yeah emo internet ftl
    Super Dave Z U L8R's Avatar
    Roswell
    if you put the bc in like he said and it still doesn't adjust, switch the bc around as in connect the vacuum lines to it the other way
