Results 1 to 5 of 5
Thread: how to: suspension techniques rear swaybar install on a HONDA
    ATL represent
    Cool how to: suspension techniques rear swaybar install on a HONDA
    It's pretty much a bolt-on affair, so I'll let the pictures do the talking:
    Start by removing the one bolt from each rear lower control arm (I'm using itr rear lca's, so your setup may be a little different...)
    There are five bolts holding two brackets on per side - one is the side rear tow hook, and the other is the bracket which holds the swaybar.
    Comparing stock (above) vs ST (below):
    Stock is 1/2" in diameter:
    ST is 7/8" in diameter:
    The ST brackets bolt on using only three bolts. It's up to you whether to reuse the oem bolts or the ST ones... I used the longer ones:
    There's a weird plate to line up the endlinks and bolt to the rear lca's. I'm pretty disappointed in the design, but whatever works:
    Here's an installed view from the rear - you can barely see it:
    I left it on the softest setting. With 11k F and 16k R, it's pretty neutral unless you trailbrake or lift off throttle in a corner.
    Thanks to johnzm for a great deal on the bar. Best suspension mod besides coilovers so far!
    LNC FTW
    I'm up 'n Cummin'
    This brings back memories from last night...
    Slowrolla, Nick, Dominic, and myself got owned...by my Nismo 25mm sway bar on my Spec V...
    Looks good...
    Good talk through to...
    My YouTube Channel
    Make sure you "like" the videos purdy please.
    is this the b18c ef? i had a large rear swap on mine and it scared me lol, thought it was RWD for a few
    (OO=[][]=OO) Dominic49's Avatar
    Quote Originally Posted by ~The_Duke~
    Looks good...
    i was not involved!!!
    LNC FTW
    I'm up 'n Cummin'
    Quote Originally Posted by Dominic49
    Ya that was right you were to busy trying to take my muffler off...
    My YouTube Channel
