IBM Thinkpad T30 Laptop
LAPTOP IS IN MINT CONDITION!!
$400
FREE DOCKING STATION
Laptop comes with all IBM Drivers, IBM software, and Windows updates!
Completely tested IBM Thinkpad T30 laptop with wireless card.
Pre-installed Windows XP PRO SP2.
Pre-installed also is MS Office 2003 Pro - includes Word, Excel, and Outlook.
Laptop comes with a 15 Day Warranty from normal wear and tear. Invoice will state warranty information.
Crystal Clear LCD. No blemished or scratches!
WHAT'S HOT:
The T30 is IBM's first ThinkPad to include both a touchpad and IBM's standard eraserhead--a design that should win over a lot of people who have never gotten the hang of IBM's pointing stick. The touchpad's set of dedicated mouse buttons are just as comfortable as the eraserhead's, and unlike the buttons on most other notebooks, they depress deeply for solid feedback. The T30 is well-equipped for roaming.
Product overview
Tested: 100% Tested
Condition: MINT CONDITION
Model: THINKPAD T30 23??-???
CPU: INTEL PENTIUM 4 1.6GHZ
Memory: 512 MEG Memory
Hard drive: 40 GB
Wireless 802.11 A B and G PCMCIA card
CD-ROM: DVD Drive
Video ATI MOBILITY RADEON 7500
Network card: Ethernet • Fast Ethernet
Audio: Full Duplex Audio
PCMCIA: 2 SLOTS
Ports: (1) VGA (1) Parallel (2) USB (1) Serial
Battery/AC Adapter: GOOD working battery. Held over a hour.
AC Adapter included.
Operating System: Windows XP PRO PRE-INSTALLED
Warranty: 15 DAY WARRANTY(NORMAL WEAR/TEAR). DOA WARRANTY.
MORE SPECS FROM IBM's WEB-SITE
Audio
AD1881A AC97 codec
Sound Blaster Pro compatible
Speaker technology
2 speakers
1 Watt speakers
Volume up, down, and mute buttons
Three audio jacks:
One for external stereo speakers or headphone (3.5mm)
One for an external microphone (3.5mm)
One for line-in (3.5mm)
Keyboard
87 key keyboard with imbedded numeric keypad and integrated TrackPoint(TM) with enhanced features
90 DBCS key keyboard with imbedded numeric keypad and integrated TrackPoint(TM) with enhanced features for Japanese systems
Imbedded numeric keypad
The keyboard has a Fn key which is a special key and is located in the lower left corner. The Fn key allows the user to instantly activate the following operational features by pressing the Fn key and a designated function key: - Standby/Suspend/Hibernation - Switching between Display devices - Power management mode
ThinkPad button, allowing one-touch entry into Access ThinkPad
ThinkLight which illuminates the keyboard in low light conditions. (Activate via Fn+PgUp key)
Memory
64-bit Double Data Rate (DDR) non-parity SDRAM memory
PC2100 at 266MHz
Two 200 pin SO-DIMM memory slots, one slot is pre-populated with 256MB, leaving one socket available
Supports up to two 512MB SDRAM SO DIMMs
Supports maximum memory up to 1.0GB
Mouse
All systems come with TrackPoint(R) with Press-to-Select, Internet scroll, and magnifying glass features for accurate and convenient control
Selected models will have the UltraNav touch pad
Processor
Dual-mode, high-performance Mobile Intel(R) Mobile Pentium(R) 4 Processor-M at 1.6GHz or 1.8GHz or 1.9GHz or 2.0GHz or 2.2GHz or 2.4GHz
Enhanced Intel SpeedStep(TM) technology
512 KB onboard L2 cache memory
400MHz front side bus
Communications
Infared (IR)
IR transceiver for wireless file and data transfer and printing.
Speeds up to 4Mbps.
Compatible with the Infrared Data Association (IrDA) IR data link specification
located on right side of system
Modem
Selected models as either a communication daughter card (CDC) or as a Mini PCI card combo card with Intel wireless
K56Flex v.92
Note: Public network download speeds are limited to 53kbps. Upload speeds are limited to 48Kbps. Actual speeds depend on many factors and are often less than the maximum stated.
Network
10/100 Ethernet installed on the system board
Selected models will have Intel Wireless and modem Mini PCI combo cards
Selected models will have CISCO Mini PCI card
Selected models will have Bluetooth communication daughter card
Expansion
Bays
One, integrated, easy-loading modular Ultrabay(TM) 2000 Plus
One Mini PCI IIIb slot
Two communications daughter card slots
External ports
Two USB (Both ports are located in rear) version 1.1
One parallel (EPP, ECP) compatible
One DB-15 external display
One 9-pin serial
Additional connector supports the optional Port Replicator and dock
Audio line in, audio line out, and microphone in ports
S-Video out
Built-in RJ-11 and RJ-45 connectors for telephony and LAN connections
Note: There is no PS/2 port but one can be obtained by getting the optional ThinkPad Port Replicator or ThinkPad Dock.
PC Card
Conforms to the PC Card Standard 95
The Type III slot can accommodate two Type I or two Type II, or one Type III PC card
Both 16-bit and 32-bit cards are supported.
PCMCIA 2.1 standard
No zoom video support
Operating environment
Physical specificaitons
System:
Width: 304mm (12.0in)
Depth: 250mm (9.8in)
Height: 36.6mm (1.4in)
Travel weight will vary by model and the range is 2.22kg (4.9lb) to 2.33KG (5.1lb) with travel bezel
Configured system weight will vary by model and the range is 2.42kg (5.33lb) to 2.57kg (5.67lb).
Accessories:
Li-Ion battery pack: 325g (0.72lb)
FDD: 210g (0.45lb)
AC adapter (2-pin or 3-pin): 360g (0.795lb)
Power cord for ac adapter: 90g (0.19lb)
DVD drive: 345g (0.76lb)
Note: All weight and dimensions are approximate.
Agency approvals
FCC Class-B Certified to comply with FCC Rules, Part 15
VCCI Class B
UL-1950
C-UL
NOM (Mexico)
CCIB (for China)
BSMI (for Taiwan)
SMA 3548(Australia and New Zealand)
MPR-II (Sweden)
CE Mark
CB Report (EMEA)
MIC (Korea)
Power
AC Adapter
AC adapter: This ac-to-dc converter supplies the necessary power to the computer. The ac adapter also charges the battery pack when it is installed in the computer.
Universal AC adapter (72 W):
Input is 100/240V AC, 1.4/0.7A, 50/60 Hz
Output is 16V DC, 4.5A
Storage
Optical drive
10X maximum write speed of CD-RW media
24x maximum write speed of CD-R media
24X maximum read speed of CD media
8X maximum read speed of DVD media
Bootable
Video
Display
Depending on model:
358.1-mm (14.1-in) TFT display with 1024 x 768 resolution.
358.1-mm (14.1-in) TFT display with 1400 x 1050 resolution.
All displays are measured diagonally.
Graphic Controller
ATI Mobility Radeon 7500 chipset
AGP 4X
16MB DDR-SDRAM
166MHz bus
Digital Video Input (DVI) for digital displays is supported through the optional ThinkPad Dock or ThinkPad Port Replicator.
$400 FIRM This is a great price for this laptop!!
