Results 1 to 11 of 11
Thread: my setup
    M.O.B inutero93's Avatar
    valdosta ga
    Default my setup
    here is my setup
    jdm b16 head ported and polished shaved 0.20 with gsr cams
    b18c1 block-stock
    b16 tranny
    p28- chipped for now
    vafc 2
    its going into a 98 cx hatch
    is this a good setup ?
    any opinions thanks
    Gainesville
    go with the GSR head...get the work done to it...cause the GSR will serve you much better, btw just a suggestion why not go with a type-r head? in a hatch? what is all done to the hatch, as in body mods, weight reduction and such...
    stockbridge
    Quote Originally Posted by §treet_§peed
    $$$. what does body kods have anything to do with engine setup?
    valdosta ga
    i have a gsr head but it had bad vavles but for the price to fix it i got the b16 head .. body is stock .. this is my first swap just seeing what it would do for now .. going to build it later on..
    what chip should i use .. cant afford chrome or hondata right now
    valdosta ga
    the b16 head has been fully ported and polished and shaved 0.20 thats how i bought it
    SMR 4 LIfe smrlsvtec's Avatar
    u need some PRO 1's
    Senior Member 99SI's Avatar
    Jackson
    I was about to ask why you were still running a VAFC if you had a p28 that's already socketed for a chip. Most of the chips out there are shit. There' s a reason why you tune on a dyno, because different, climates(humidity, temp), elevations, and car setups respond differently. A generic chip, even if it is a "spoon" or whatever else is not going to get you what you should get out of the setup. Most of the Ebay "performance chips" even ones that are labeled spoon or mugen will not make anymore power than a standard ecu. It's not that much to get a tune from Scotty through Mainstream using crome. You won't have to buy anything if it's already socketed and setup to accept a chip. He can put it on the dyno, use a base tune that will be close and dial it in, for 200-300 you can have your car maximizing it's potential. I agree that the next step is to get a set of cams such as a pro1 or m22x but if you do that you better get it tuned with crome. Also invest in a quality header. The setup you have will be fun in a hatch if it's something new to you. Take your time and spend your money wisely on quality parts the first time instead of buying cheap and having to replace it later. good luck
    Jackson
    BTW, you are going to be at a pretty low compression with the GSR pistons and a B16 head, even with it shaved. If you could have thrown a set of PR3 B16 pistons in you'd have a much higher CR and have more potential for all motor power.
    Gainesville
    well first off i said body mods..fucking illiterate emo..hooked on phonics didn't work for you did it? i was just wondering if he had any rice or weight reduction to help suggest what mods he should do to get his car to go fast....
    valdosta ga
    i had my freind say i will be around the gsr cr ... i have not chipped my ecu yet and if the vafc2 is not going to work all that great i wont put it i got a good deal on it .
    i have type r 4 to1 headers ..
    i do plan on building it later .
    thanks for all the help
    jon
    Banned LS2ner's Avatar
    The Face
    Sounds almost like a Poor mans type-r set up. Just make sure everything put together alright and it should be fine! In the future P30 or PR3 pistons would serve u well.
