Thread: SR20DET Motor For Sale
    Toyota Tech
    Dec 2003
    Claxton, GA
    Default SR20DET Motor For Sale
    Selling a SR20DET motor/tranny/ecu. Almost complete setup minus wiring harness.
    Almost all parts have literally less than 1,500miles on them, with the rest under 5,000miles. Also including my extra sr parts (some gaskets, another head (incomplete), some factory parts, extra radiator)
    Redtop SR20DET
    All seals/rings/gaskets are new, motor was recently rebuilt.
    New Nissan Parts
    Timing Chain Cover/Oil Pump
    Water Pump
    PCV Valve
    O2 Sensor
    Timing Chain Tensioner
    Crank Angle Sensor
    Camshaft Gears
    Coolant Temp Sensor
    Knock Sensor
    Power Enterprise Super V Belt
    Starter was recently replaced
    NEW Nissan head
    Peak Performance Pro Valve Springs
    HKS Step 1 264 Intake Camshaft
    HKS Step 1 264 Exhaust Camshaft
    Greddy Rocker Arm Stoppers
    APEX'i 86 .8 Head Gasket
    Internals
    ARP Headstud Kit
    ARP Rod Bolts
    Fuel
    NISMO AFPR
    SARD 680cc Injectors
    Z32 Fuel Filter
    Misc
    NISMO Thermostat
    NISMO Engine Mounts
    NISMO Tranny Mount
    NISMO Air Filter
    NISMO Radiator Cap
    NISMO Oil Cap
    Custom Hard Intake Pipe 3"
    Z32 MAFS
    Pro-Fab Design Intake Manifold Gasket
    HKS SSQV Blow Off Valve
    Custom s13 FMIC (includes powdercoated intercooler piping)
    Chrome Valve Cover Nuts
    Powdercoated Valve Cover
    Carbon Fiber Spark Plug Cover
    Catch Can
    Single Electric Fan for radiator
    /w Turbo
    Garret GT25R .64 Turbocharger
    Taka S13 Turbo Lines
    Megan Stainless Steel Exhaust Manifold
    Megan Stainless Steel O2 Housing
    /W Transmission
    Earl's Stainless Steel Clutch Line
    ACT Street/Strip Clutch
    Fidanza Flywheel
    /w ecu
    Enthalpy Tuned ECU for this setup. 7500rpm limit, no speed limit
    I am selling all this to make room for new engine in my s13, this is a very nice build up, only thing holding back lots of power lol is the turbo. Engine pulled very hard as is, running 14psi. Ran a high 13 (13.8or13.9) 1/4 with the 18s on the car and an open diff spinning till 3rd, so with a car with a vsld and some sticky tires it should produce a looot better time.
    Only thing wrong with it, is I reused my apex'i headgasket for the new head, and the front of the valve cover leaks like a drop or two of oil. It is not bad at all, and no coolant/oil is burned anywhere. just the very front where the apexi tag comes out it seeps.
    This is best offer, so shoot me some pms if you wanna talk.
    $4500
    2010 Scion xB
    bump for bad ass motor
    EF SQUAD FTMFW!!!!
    Drifter/Kneedragger
    Buford, GA, USA
    doesn't need a whole new gasket, just RTV along the sealing surfaces of the timing cover/head.
    At Home
    Nice and Bad Ass
    Toyota Tech
    Dec 2003
    Claxton, GA
    Quote Originally Posted by HiPSI
    Thanks for that, did not even think to try it. I am going to do it and see if that fixes it, then nothing wrong with it lol.
    Thanks for the bumps/comments guys!
    2010 Scion xB
    Nissan LOVE nDrew's Avatar
    If you part it out PM me... I have a few things I would like to have.
    '89 240SX - SR20DET W/ T-28
    '07 Frontier SE CrewCab
    Newnan
    power....drools....
    You REARRY liek me! scabtastic's Avatar
    powder springs
    how about you give it to me...and i can get all my friends to give you sexual favors? lol..bump
    Epic Foxbody Thread Crew Member #07
    Fuck Bitches, Kill tyrannosauruses
    Toyota Tech
    Dec 2003
    Claxton, GA
    Bump lots of interest but its still in my garage :P
    2010 Scion xB
    Toyota Tech
    Dec 2003
    Claxton, GA
    Bizump...
    make some offers people need it gone
    2010 Scion xB
    Toyota Tech
    Dec 2003
    Claxton, GA
    Bump
    Whats still for sale
    Engine gone, but he didnt need everything.
    Garrett GT25R .64 (Couple of months old, less than 1000 miles, zero problems/shaft play)$400
    Megan Exhaust Manifold $75
    Megan O2 Housing $50
    SARD 550CC Injectors /w plugs $250
    Enthalpy Tuned ECU (680cc, z32) $250
    Want something shoot me a pm and we can talk.
    2010 Scion xB
    20 side of thangs
    i sent you a pm but no answer. if you still have your megan manifold let me know.
