Results 1 to 5 of 5
Thread: altima se-r
    Daloveshack
    Default altima se-r
    Around what is the whp for this. I know it supposed to be pretty quick.
    Public Enemy #1
    well if your talking like the newer ones, they are i think 3.5 V6 with 260hp and 250tourque so idont believe the wheel hp and such should be that low my guess be right above 200!!!! but they are pretty fast with a 6 speed manual to them!
    All Motor EK N/A EK's Avatar
    On IA.com
    PERFORMANCE: It's not much of a stretch to say that under the hood of every Altima SE-R is the heart of a 350Z. They share Nissan's fine 3.5-liter dual overhead-cam, 24-valve VQ35 V6 engine. In the SE-R, it's tuned for 260 horsepower, at 6000 rpm, with 251 lb-ft of torque at 3600 rpm. Torque is developed at low engine speeds, for good real-world acceleration. A six-speed manual transmission is standard, with a five-speed electronically-controlled automatic also offered. The automatic, with which my test car was fitted, has a manual-shift gate, and can be used easily in manual mode. But, given the amount of torque from the engine, and wide torque band, D works just fine most of the time. A lower final-drive ratio than other V6-powered Altimas further enhances performance.
    2005 Nissan Altima SE-R
    Base Price $ 29,200
    Price As Tested $ 30,680
    Engine Type aluminum alloy dual overhead cam
    24-valve V6
    Engine Size 3.5 liters / 213 cu. in.
    Horsepower 260 @ 6000 rpm
    Torque (lb-ft) 251 @ 3600 rpm
    Transmission 5-speed electronically-controlled
    automatic
    Wheelbase / Length 110.2 in. / 192.5 in.
    Curb Weight 3,316 lbs.
    Pounds Per Horsepower 12.8
    Fuel Capacity n/a gal.
    Fuel Requirement 91 octane unleaded premium gasoline
    Tires P225/45 ZR18 Bridgestone Potenza
    S-03
    Brakes, front/rear vented disc / solid disc,
    antilock standard
    Suspension, front/rear independent strut /
    independent multi-link
    Drivetrain front engine, front-wheel drive
    PERFORMANCE
    EPA Fuel Economy - miles per gallon
    city / highway / observed 20 / 30 / 22
    0 to 60 mph est 8.0 sec
    Daloveshack
    Thanks!
    da ringmasta teggy 2nr's Avatar
    G county
    test drove one, fun ass car!
