Results 1 to 23 of 23
Thread: COMPUTER QUESTION....
    Default COMPUTER QUESTION....
    Why does my clock on the computer run fast? I've reset it several times here lately. I did put more RAM in. Did that make my clock run faster, too? Lolol. Seriously. What's up? Later, QD.
    LNC FTW
    I'm up 'n Cummin'
    That is fucked up...do you have the clock set to the right time zone and everything...and is your BIOS clock doing the same thing?
    My YouTube Channel
    Make sure you "like" the videos purdy please.
    I don't know about the BIOS clock. How to check that? ANd my time isn't wrong on the zone. It just slowly creeps up ahead. When Ijust changed it, it was 10 minutes fast. Later, QD.
    DSM driver
    Buford
    what OS do you have?? if it is windows 98 or ME then it is a bug that they never worked out if it is XP then double click your time and tall it to syncronize the time with nist.gov instead of microsoft
    LNC FTW
    I'm up 'n Cummin'
    Aight to get to the BIOS or 'setup' screen it just depends on the mother board and the BIOS that you are running for the key you need to press...
    Common Keys are the DEL key and the first 4 F# buttons and also F7 & F8 then you will need to fumble around in there til you find a clock of some sort. It should be in the general area...if that is also fast you might want to try changing the CMOS battery...
    Windows relys on your BIOS clock to give you the time on the Windows clock. If changing the CMOS battery doesnt work then you motherboard is starting to go wacko on ya...
    Also be of warn, taking the CMOS battery out will reset your BIOS\CMOS settings to default so if you have any custom settings in there make sure to write them down or make sure you remember...
    My YouTube Channel
    Quote Originally Posted by 1gDSM
    It already is. Later, QD.
    Fayetteville/PTC/Carrollton
    or you can download a program called clock tray skins at
    http://___dl.phazeddl.com/606778/Clo..._Tech_Security
    just take the "___" out from before dl. This is a program that runs off of satellite time and updates itself and what not. It also looks better haha
    LNC FTW
    I'm up 'n Cummin'
    QD you running 98SE? or XP?
    My YouTube Channel
    XP. Later, QD.
    LNC FTW
    I'm up 'n Cummin'
    Did you go see if you BIOS clock was running fast also? Cas this sounds a lil deeper than just in Windows...
    My YouTube Channel
    Yes joecoolfreak's Avatar
    Austin, TX
    I would be willing to bet the problem is actually your power source...pm or im me for a more detailed description of the issue.
    LNC FTW
    I'm up 'n Cummin'
    Quote Originally Posted by joecoolfreak
    Well the BIOS clock would do that if the CMOS battary was not working correctly, I wouldnt think that the PSU would make it do that because it would just fry things if it was surging...
    My YouTube Channel
    DSM driver
    Buford
    you are right you cant "overclock" the time per say.
    QD is it a Dell? and if so are you running norton security on it?
    Yes it is Dell and no I am not running Norton. Later, QD.
    LNC FTW
    I'm up 'n Cummin'
    hhmmmmm is it still under warenty...send that shit back and tell you want a new one...lol
    My YouTube Channel
    DSM driver
    Buford
    good we are making progress
    A PC generates a 'timer interrupt' about 20 times a second, and the
    clock is maintained by counting these. Clock rates that run steadily at
    a big loss or gain are probably because the motherboard/BIOS and Windows
    have different ideas on how often the interrupt happen. Small
    variations in this are handled when you use the Internet Time sync -
    this notes the error and adjusts the assumed interval accordingly, so
    that after a few occasions the clock rate is very near right anyway.
    Sometimes (especially with Dell machines) the discrepancy is outside
    the range that the time sync will adjust - and you get a large steady
    error, like 10 minutes in an hour. If that happens Try these steps:
    1. Start->Run cmd.exe
    2. net stop w32time
    3. w32tm.exe /unregister
    4. w32tm.exe /register
    5. net start w32time
    (note spellings w32tm and w32time in different commands)
    If you get short term bad clock rates, there *may* be some rogue program
    that is preventing the interrupts being handled. This was common enough
    in Win98, but ought not to be possible in XP. If it happens note what
    you have running at the time, and see if you can identify a program
    doing it. System Utility things like Norton would be main suspects
    LNC FTW
    I'm up 'n Cummin'
    The interrupt mentioned here would that be caused by software or hardware hicup?
    That sounds like what his problem is...
    My YouTube Channel
    DSM driver
    Buford
    yes, before you do anything you should update windows and your antivirus program *if you have one* scan the pc with the antivirus and *Ad-Aware Se* and see if it keeps up the same way
    Did that Friday night. I use AVGFree and it updates damn near 3-4 times a day...lolol. Comes up with nothing. Later, QD.
    DSM driver
    Buford
    Quote Originally Posted by the link that 1gDSM gave me
    When you leave your computer on for an extended amount of time, the time may lose from two minutes to an hour per day
    I do leave my computer on for longer periods of time than I used to. Later, QD.
    DSM driver
    Buford
    i leave mine on for months at a time tho and it never does that ***and*** it is overclocked by 35% but i have XP Pro mabe that is the dif????
    what XP do you have? home or Pro
    Home, I believe. Later, QD.
