Results 1 to 28 of 28
Thread: cleaning out my garage....
    Default cleaning out my garage....
    all prices are negotiable and do not include shipping. sold as is, no warranty. all parts working when removed. i am located in evans, ga. zip is 30809.
    99 chevy 5.3 liter main and rod bearings $50.00
    91 talon lower column cover. $5.00
    91 talon rear windshield washer resivoir with motor $10.00
    4G63 6 bolt N/A oil pan $25.00
    Bosch wideband 02 sensor, new never used $60.00
    91 awd talon abs pump/module $50.00
    1g dsm ported o2 housing $20.00
    2g dsm throttle body elbow $30.00
    91 talon rear windshield wiper motor $10.00
    1g dsm power steering pump $10.00
    2 sets 1g dsm 6 bolt "big" rods $60.00/set
    1g dsm 6 bolt rear main seal housing $10.00
    1g dsm 6 bolt timing gear (crank) $12.00
    1g awd dsm power steering resivior with lines $30.00
    95 chrysler cirrus driver inside door handle $5.00
    cirrus/stratus/sebring 2.5 liter valve cover gaskets w/spark plug gaskets $30.00
    heliolite "blue" bulb #9007 used $3.00
    heliolite "blue" bulb #9006 used $3.00
    cirrus/stratus/sebring 2.5 liter throttle body gasket $3.00
    cirrus/stratus 2.5 liter idler pulley $15.00
    cirrus/stratus/sebring 2.5 liter distributor rotor button $5.00
    3157NA bulbs (pair) used $2.00
    sylvania bulbs #9007 used $2.00/each
    sylvania bulb #9006 used $2.00
    Toyota 4AGE big port 16valve FWD uncut engine harness/ecu $100.00
    91 dsm heater core (no leaks) $10.00
    Toyota 4AGE big port 16valve complete unassembled head w/intake manifold and throttle body $150.00
    Toyota 4AGE fuel rail $20.00
    Toyota 4AGE fuel injectors $20.00
    Toyota 4AGE oil dipstick w/tube $5.00
    Toyota 4AGE distributor $40.00
    Toyota 4AGE upper timing cover $10.00
    Toyota 4AGE 7 rib 8 bolt flywheel $20.00
    Toyota 4AGE FWD starter $10.00
    1g dsm bov hard pipe $10.00
    1g dsm seatbelt module $10.00
    1g dsm CAS $60.00
    1g dsm bare under dash fuse block w/fuse cover $10.00
    1g dsm a/c fan w/cut connector $10.00
    1g dsm power steering pump (not same one as above) $10.00
    1g dsm wiper motor $10.00
    1g dsm shift boot (great condition) $15.00
    1g dsm driver and passenger window motor/regulator $25.00 each
    1g dsm 6 bolt flywheel $20.00 (will blast rust for $5.00 extra)
    2g dsm 7 bolt chrome moly rings standard bore NEW $30.00
    2g dsm 7 bolt pistons NEW $60.00 (will sell rings w/pistons for $80.00)
    1g dsm driver headlight cover (pop-up) okay condition $10.00
    1g dsm misc. relays/controllers $5.00 each
    1g dsm cruise control servo $10.00
    1g dsm throttle body elbows $5.00/each
    1g dsm power mirror switch $5.00
    1g stock AWD dsm springs $25.00
    1990 dsm coil pack $20.00
    3" GM MAF off of running car $60.00
    96-00 honda civic D16 venom billet drag manifold NEW $300.00
    Assorted 16U hydraulic fittings $300.00
