Results 1 to 40 of 56
Thread: 2 JL SUBS, 2 KENWOOD AMPS, 2 INSTALL KITS, & 2 CAPS
    Dacula GA
    Default 2 JL SUBS, 2 KENWOOD AMPS, 2 INSTALL KITS, & 2 CAPS
    EVERYTHING IS SOLD!!!
    ALL PRICES ARE FOR EACH ITEM. PM ME TO BUNDLE AND SAVE!
    ALSO ALL ITEMS HAVE BEEN UPDATED AS OF 01/21/2007
    Ok I had one of these up for sale a while back and never got rid of it. My girl recently said she wanted to sell hers also instead of putting it in he car, because she is lookin gto sell it, so here are both of them, I will post pics of it ALL TOGETHER tomorrow. All items are NEW and NEVER USED. The one sub that is in the box has been placed in it just for looks, so one sub will come with a box, to whoever wants it first, and the other will not. Also one of the 4 guage install kits has been opened, but I am willing to throw in some extra wires and prove it is all there.
    I would like to sell each kit all together because the sub and amp were purchase for each other and will sould great because of the settings each has, the dual 4 ohm amp and the 550w power @ 4 ohm for the amp.
    If you have any questions please feel free to PM me. My asking price is $400 for a complete system, 1 sub, 1 amp, 1 cap, and 1 install kit.
    HERE ARE ALL THE SPECS ON EVERYTHING
    12W3V2-D4- $175 obo 1 LEFT NOT IN ENCLOSURE JUST IN JL BOX AS FROM FACTORY
    Specifications:
    Nominal Diameter 12" (300 mm)
    Continuous Power Handling 300 Watts
    Voice Coil 2.25" diameter, 4-layer, Kapton former
    Available Configurations Dual 2 ohm, Dual 4 ohm or Dual 6 ohm
    Xmax (one-way, linear): 0.46"-0.51" (11.7-13.0 mm) depending on specific model
    Sealed Enclosure Range 1.00-1.50 cu.ft. (28.3-42.0 liters)
    Ported Enclosure Range 2.00-3.00 cu.ft. (57.0-85.0 liters)
    VCR Technology Yes
    Elevated Frame Technology Yes
    KENWOOD KAC-8152D- $175 obo 1 LEFT
    Features
    * Ultra Efficient Class D Circuitry
    * MOSFET Power Supply
    * Torroidal Noise Suppression Filter
    * Copper EE Core Power Transformer
    * Dual Secondary Capacitors
    * Ground Isolation Input Circuit
    * Detachable Aluminum Dress Plate & Top Panel Control
    * Die-Cast Aluminum Heat Sink
    * Variable (50 - 200 Hz) 18 dB / Octave Low-Pass Crossover
    * Switchable (Off / 15 / 25 Hz) 18 dB / Octave Subsonic Filter
    * Gold-Plated Preamp Inputs and Outputs
    * High and Low Level Inputs
    * 2 Ohms Mono Stable
    * Red Triangle Power Indicator
    * Gold-Plated Screw-Type Power and Speaker Terminals
    * Variable (0 - 18 dB) Bass Boost at 90 Hz
    * Single-Side Terminal Placement for Cleaner Installation and Improved Wire Management
    Subwoofer Mono Amp Specifications
    * Amplifier Type: Mono
    * RMS Power @ 4 Ohms: 300W x 1 @ 4 ohms
    * THD at 4-Ohm RMS Power: 0.08%
    * Bridged RMS Power @ 4 Ohms: 550W x 1 @ 2 ohms
    * Speaker Level Inputs: yes
    * Preamp Outputs : yes
    * Built-In Crossovers: LP
    * Bass Boost: 0 - 18 dB
    * Frequency Response: 5-200 Hz
    * Signal to Noise Ratio: 100 dB
    * Dimensions: n/a
    Whip Audio 1.5 Farad Cap- $50 obo each
    24DCV surge with digital read out screen
    DB Link Hi-Lo Converter- $10 obo 1 LEFT
    connects to your car speaker wires and allows you to hook the system up to a car with no rca ports on the radio, great for stock radio cars.
    Dacula GA
    ASAP's Medic w/ a 1J Firefightin_tC's Avatar
    If no one wants the complete system, I will gladly take those subs off your hands.
    IA's Sexiest Black Man 2009!
    From a Boosted Scion tC to a 1JZ-GTE SC300 to 2JZ-GTE SC300
    www.asapcarclub.com
    www.clublexus.com
    So you get So how much for a JL Sub only?!
    Turbo Coupe...... eS_05's Avatar
    Lost.....
    Dacula GA
    starting to part out.
    1 cap might be sold wen
    2 subs may be sold.
    Will update when things are sold.
    THANKS for the bumps and looks
    Dacula GA
    Dacula GA
    Bump, everything still for sale
    TrUe RiDer Atlboi_alway's Avatar
    Decatur ga
    i want the cap and amp if still there check pm
    Check Last post on Thread For Updates!
    Dacula GA
    Dacula GA
    Hey buddy whats the lowest you will do for a sub with box.. im trying to spend 150... Or if you can do 265 and add the amp ill get that...let me know i can pick it up this weekend... I have cash... located in buckhead area of atlanta..
    email me [email protected]
    Just let me know thank you
    Dacula GA
    all prices are pretty firm...maybe budge 5 or $10 but everything is NEW and never used
    Dacula GA
    hey, ill give you $120 for the amp because i could get it brand new with warrenty from onlinecarstereo for $170 shipped brand new
    Dacula GA
    bump, go get it then. I am selling everything below what I got it for already. I cannot afford to loose any more money.
    Dacula GA
    BUMP
    Dacula GA
    OMG IS THAT Mr.Wong? justwongit's Avatar
    you still got the cap and the kenwood amp?? LMK
    Dacula GA
    still got it all. LET ME KNOW
    BUMP
    Quote Originally Posted by dtmcnamara
    BUMP
    how much??
    Dacula GA
    Dacula GA
    morning bump. NEED GONE ASAP!!!
    Dacula GA
    Dacula GA
    bump. GREAT CHRISTMAS PRESENT!!!!!
    Dacula GA
    keep D series alive SLPR's Avatar
    with ya gurl
    would u do 150 for a sub w/o box? if so, i can pick it up this weekend... where u located?
    Dacula GA
    if you can do it THIS weekend I can do it. call me when you want to meet up. I an near gwinnett mall
    404-725-4979
    David
    Dacula GA
    bump. 1 wire kit gone and 1 sub may be gone
    Dacula GA
    Dacula GA
    bumpity
    Dacula GA
    Dacula GA
    ttt
    Dacula GA
    3.5" 98 jeep
    ill give u 300 cash for the 2 subs 2 amps ill pick up
    always better on top!!! 3.5 inches on top
    Dacula GA
    pm'd you
    Dacula GA
    Dacula GA
    Dacula GA
    Dacula GA
    BUMP. NEED GONE ASAP
