Thread: IBM Thinkpad T30 - P4 1.8ghz 512meg 20gb WIFI XP MINT! - $390
    Everyday im HUSTLIN'
    atlanta,ga
    Default IBM Thinkpad T30 - P4 1.8ghz 512meg 20gb WIFI XP MINT! - $390
    IBM Thinkpad T30 Laptop
    LAPTOP IS IN MINT CONDITION!!
    $390
    Laptop comes with all IBM Drivers, IBM software, and Windows updates!
    Completely tested IBM Thinkpad T30 laptop with wireless card.
    Pre-installed Windows XP PRO SP2.
    Pre-installed also is MS Office 2003 Pro - includes Word, Excel, and Outlook.
    Laptop comes with a 15 Day Warranty from normal wear and tear. Invoice will state warranty information.
    Crystal Clear LCD. No blemished or scratches!
    WHAT'S HOT:
    The T30 is IBM's first ThinkPad to include both a touchpad and IBM's standard eraserhead--a design that should win over a lot of people who have never gotten the hang of IBM's pointing stick. The touchpad's set of dedicated mouse buttons are just as comfortable as the eraserhead's, and unlike the buttons on most other notebooks, they depress deeply for solid feedback. The T30 is well-equipped for roaming.
    Product overview
    Tested: 100% Tested
    Condition: MINT CONDITION
    Model: THINKPAD T30 2366-81U
    CPU: INTEL PENTIUM 4 1.8GHZ
    Memory: 512 MEG Memory
    Hard drive: 20 GB
    Wireless 802.11 A B and G PCMCIA card
    CD-ROM: DVD Drive
    Video ATI MOBILITY RADEON 7500
    Network card: Ethernet • Fast Ethernet
    Audio: Full Duplex Audio
    PCMCIA: 2 SLOTS
    Ports: (1) VGA (1) Parallel (2) USB (1) Serial
    Battery/AC Adapter: GOOD working battery. Held over a hour.
    AC Adapter included.
    Operating System: Windows XP PRO PRE-INSTALLED
    Warranty: 15 DAY WARRANTY(NORMAL WEAR/TEAR). DOA WARRANTY.
    MORE SPECS FROM IBM's WEB-SITE
    Audio
    AD1881A AC97 codec
    Sound Blaster Pro compatible
    Speaker technology
    2 speakers
    1 Watt speakers
    Volume up, down, and mute buttons
    Three audio jacks:
    One for external stereo speakers or headphone (3.5mm)
    One for an external microphone (3.5mm)
    One for line-in (3.5mm)
    Keyboard
    87 key keyboard with imbedded numeric keypad and integrated TrackPoint(TM) with enhanced features
    90 DBCS key keyboard with imbedded numeric keypad and integrated TrackPoint(TM) with enhanced features for Japanese systems
    Imbedded numeric keypad
    The keyboard has a Fn key which is a special key and is located in the lower left corner. The Fn key allows the user to instantly activate the following operational features by pressing the Fn key and a designated function key: - Standby/Suspend/Hibernation - Switching between Display devices - Power management mode
    ThinkPad button, allowing one-touch entry into Access ThinkPad
    ThinkLight which illuminates the keyboard in low light conditions. (Activate via Fn+PgUp key)
    Memory
    64-bit Double Data Rate (DDR) non-parity SDRAM memory
    PC2100 at 266MHz
    Two 200 pin SO-DIMM memory slots, one slot is pre-populated with 256MB, leaving one socket available
    Supports up to two 512MB SDRAM SO DIMMs
    Supports maximum memory up to 1.0GB
    Mouse
    All systems come with TrackPoint(R) with Press-to-Select, Internet scroll, and magnifying glass features for accurate and convenient control
    Selected models will have the UltraNav touch pad
    Processor
    Dual-mode, high-performance Mobile Intel(R) Mobile Pentium(R) 4 Processor-M at 1.6GHz or 1.8GHz or 1.9GHz or 2.0GHz or 2.2GHz or 2.4GHz
    Enhanced Intel SpeedStep(TM) technology
    512 KB onboard L2 cache memory
    400MHz front side bus
    Communications
    Infared (IR)
    IR transceiver for wireless file and data transfer and printing.
    Speeds up to 4Mbps.
    Compatible with the Infrared Data Association (IrDA) IR data link specification
    located on right side of system
    Modem
    Selected models as either a communication daughter card (CDC) or as a Mini PCI card combo card with Intel wireless
    K56Flex v.92
    Note: Public network download speeds are limited to 53kbps. Upload speeds are limited to 48Kbps. Actual speeds depend on many factors and are often less than the maximum stated.
    Network
    10/100 Ethernet installed on the system board
    Selected models will have Intel Wireless and modem Mini PCI combo cards
    Selected models will have CISCO Mini PCI card
    Selected models will have Bluetooth communication daughter card
    Expansion
    Bays
    One, integrated, easy-loading modular Ultrabay(TM) 2000 Plus
    One Mini PCI IIIb slot
    Two communications daughter card slots
    External ports
    Two USB (Both ports are located in rear) version 1.1
    One parallel (EPP, ECP) compatible
    One DB-15 external display
    One 9-pin serial
    Additional connector supports the optional Port Replicator and dock
    Audio line in, audio line out, and microphone in ports
    S-Video out
    Built-in RJ-11 and RJ-45 connectors for telephony and LAN connections
    Note: There is no PS/2 port but one can be obtained by getting the optional ThinkPad Port Replicator or ThinkPad Dock.
    PC Card
    Conforms to the PC Card Standard 95
    The Type III slot can accommodate two Type I or two Type II, or one Type III PC card
    Both 16-bit and 32-bit cards are supported.
    PCMCIA 2.1 standard
    No zoom video support
    Operating environment
    Physical specificaitons
    System:
    Width: 304mm (12.0in)
    Depth: 250mm (9.8in)
    Height: 36.6mm (1.4in)
    Travel weight will vary by model and the range is 2.22kg (4.9lb) to 2.33KG (5.1lb) with travel bezel
    Configured system weight will vary by model and the range is 2.42kg (5.33lb) to 2.57kg (5.67lb).
    Accessories:
    Li-Ion battery pack: 325g (0.72lb)
    FDD: 210g (0.45lb)
    AC adapter (2-pin or 3-pin): 360g (0.795lb)
    Power cord for ac adapter: 90g (0.19lb)
    DVD drive: 345g (0.76lb)
    Note: All weight and dimensions are approximate.
    Agency approvals
    FCC Class-B Certified to comply with FCC Rules, Part 15
    VCCI Class B
    UL-1950
    C-UL
    NOM (Mexico)
    CCIB (for China)
    BSMI (for Taiwan)
    SMA 3548(Australia and New Zealand)
    MPR-II (Sweden)
    CE Mark
    CB Report (EMEA)
    MIC (Korea)
    Power
    AC Adapter
    AC adapter: This ac-to-dc converter supplies the necessary power to the computer. The ac adapter also charges the battery pack when it is installed in the computer.
    Universal AC adapter (72 W):
    Input is 100/240V AC, 1.4/0.7A, 50/60 Hz
    Output is 16V DC, 4.5A
    Storage
    Optical drive
    10X maximum write speed of CD-RW media
    24x maximum write speed of CD-R media
    24X maximum read speed of CD media
    8X maximum read speed of DVD media
    Bootable
    Video
    Display
    Depending on model:
    358.1-mm (14.1-in) TFT display with 1024 x 768 resolution.
    358.1-mm (14.1-in) TFT display with 1400 x 1050 resolution.
    All displays are measured diagonally.
    Graphic Controller
    ATI Mobility Radeon 7500 chipset
    AGP 4X
    16MB DDR-SDRAM
    166MHz bus
    Digital Video Input (DVI) for digital displays is supported through the optional ThinkPad Dock or ThinkPad Port Replicator.
    $390 FIRM This is a great price for this laptop!!
    Attached Thumbnails Attached Thumbnails -t301-jpg   -t302-jpg
    H22 kyx's Avatar
    Is it still for sale? Im ready to buy.
    atlanta,ga
    I actually have something better for you. PM me and I'll let you know the specs and so forth.
    Do you still have any of these left?
    atlanta,ga
    check pm.
    ... ŁG2♣'s Avatar
    2o9
    still available?
    atlanta,ga
    yes still available. Sent pm.
