Results 1 to 22 of 22
Thread: Try again: 18' Toyo Proxes
    Lightbulb Try again: 18' Toyo Proxes
    Here it is again. I went out and took some better for everyone inquiring about the condition.Hope it helps.
    Enjoy,
    225/40/18 Z rated slightly used.$500 ( $125 per tire )
    Will consider trades depending on what it is. Don't post if you have something negative to say.
    To get the best from your car and to enjoy your driving to the full you need a tyre designed and manufactured to exacting standards - namely the Toyo Proxes T1-S. With its silica-enriched rubber compound, the Proxes T1-S gives outstanding roadholding and control in the dry or the wet. This tyre also has low noise levels, gives good ride comfort and is long lasting as well as looking aggressively stylish on all cars.
    - "Generation S" Toyo's New, Silica-Reinforced, High-Grip Tread Compound: A new smart tread compound with silica-reinforcement increases the friction coefficient between the contact patch and the road surface.
    - Silica-reinforced smart tread compound combined with an all-new unidirectional tread design with slanted main grooves for superior water drainage results in excellent wet and dry grip and resistance to aquaplaning.
    - Hard bead filler compound: The Proxes T1-S features a special hard rubber compound in the lower sidewall that provides stability during hard cornering for improved steering response and excellent grip.
    - Two full-width steel belts stabilize the tread to reduce squirm and enhance handling during hard cornering.
    - The unique tread design incorporates a rigid center rib for directional stability.
    - High Modulus Casing: Toyo uses rayon for the Proxes T1-S because of its excellent thermal stability. The performance characteristics of rayon are flat over a wide range of temperatures. This means the casing is minimally affected by extreme heat or cold assuring that steering response and high-speed stability are optimized. (A strong polyester casing is used in selected sizes).
    Spiral Wound, Jointless Edge and Cap Plies: A continuous length of nylon cord tape wound around the circumference of the tire over the steel belts creates two full cap plies or one full cap ply (depending on tire size) This assures improved uniformity for comfort and high-speed endurance.
    - CASPAN™ Noise Analysis Technology helps Toyo optimize the T1-S tread design to reduce pattern noise.
    The bead wire package is designed to eliminate joints and splices to provide precise uniformity for a smooth, comfortable ride. The configuration of the wire assures strength for stable performance at high speeds.
    - Rim Protector in the lower sidewall, guards expensive wheels from scratches and abrasions
    Aaron
    Bump for you faggots.
    IA Member dkmesa350z's Avatar
    damn I need 245/40 and 255/40
    Buy these and you can have backup.
    Bump
    Bump for saturday people.
    Bump for sunday people.
    LAWRENCEVILLE
    Man why cant these be 16s
    Sorry man! If they were 16's I would be using them!
    Bump
    gbvf
    The Dark Lude dakilla4ever's Avatar
    In the Darkness
    DO YOU HAVE ANY 17S FOR SALE? PM IF YES. NEED EM ASAP.
    LOL what kind of a question is that ???? I am trying to sell tires....
    In need of money, will consider reasonable offers. CREDIT CARDS ACCEPTED!
    Bump
    Slow... mp5o's Avatar
    Saw these tires in person the other night... They are DAMN NEAR NEW!
    Thanks Mike, considering all reasonable offers...
    NEED TO SELL
    SOLD SOLD SOLD
