Results 1 to 5 of 5
Thread: Fan issues.
    Gainesville
    Default Fan issues.
    Is there a simple solution for fixing my fans, which don't seem to be coming on. Is there a good diagnostic way to locate the problem?
    <--MY BITCH 8bangin302's Avatar
    Newnan,Ga
    u talking about a house fan of some sort..
    blank
    nowhere
    hard wire them to a switch
    too many projects
    Greensboro, NC
    Theres a switch on the block take a small piece of wire and jump the connections in the connector to one another if the fan comes on, you have two options.
    1. leave the two connected so that your fan comes on all the time with your key. ( bad for dyno runs with big caged fan, takes longer for the car to reach operating temp in which in turn keeps the car in limp mode or start up mode, so you cant a get a proper tune)
    2. By know youll know that you just need to replace the switch
    hope this helps
    11 camry se
    99 cbr 900rr on n2o
    97 accord h22 on 25psi
    06 scion xb
    01 expedition
    Gainesville
    or you could wire it up to a toggle switch which you can control when the fan turns on and off...that is what imma do later on when i do my swap...
