Results 1 to 4 of 4
Thread: turbo spiking pretty bad stock SR t25
    Default turbo spiking pretty bad stock SR t25
    anytime i take it past 4k it wants to hit 18-19 psi on a stock SRt-25 now i have heard that the diaphram goes out on the interal wastegate, but i am checking all the vacum lines tommorrw
    Tech Fanatic
    warner robins
    Does this happen when you floor it at a very low rpm and climb up to 4000?
    Formerly Spyder Man
    Buford, Ga
    What is your boost controller set at?It may be bad... If you dont have one its either the wastegate actuator or a leaking line between the boost source and the wastegate.
    :boobies:
    i am running greddy profec 2b ebc, it was set at 8 for low and 14 for high or .52 and 1.00 bar
