LS VTEC running real rich at idle u can smell the gas, STOCK injectors and pressure reg even bought a safc to turn the fuel down still dont work just dies?????????????????? HeLP
Probably a bad o2 sensor. Get a datalogger and check to see if its cycling normally.
it is dumping way to much gas like an injector is broke or something in 30 seconds my whole garage is full of smoke that smells jus like gas
Pull them out and test them then.Originally Posted by ryan34
maybe one of your injectors is stuck open, change em out, you can get stock honda injectors for cheap....whenever you first start your car it will run the richest, due to the temp of the engine, pcm reads ect, as well as other things to determine fuel needs...
i put them in another car and it ran good was running obd1 injectors for a while when it was running last time its a obd0 car will that cause anything to fault
