Thread: 19" NEC LCD monitor- like new
    Athens
    Default 19" NEC LCD monitor- sold please delete
    SOLD mods please delete!
    '92 DA-GS
    '91 240sx - Project
    S3 Magazine
    What are the specs?
    Look it up. It's easier
    Athens
    Specifications
    Active Display Area (Full Scan): Horizontal: 14.8 inches / 376 mm
    Vertical: 11.9 inches / 301 mm
    (Dependent upon signal timing used
    Contents of Packaging User's manual, Power cord, Setup Sheet
    Current Rating: 0.9 A @ 100 - 120 V / 0.5 A @ 220 - 240 V
    Dimensions: Net (with stand):
    16.5 in. (W) x 16.4-21.1 in. (H) x 9.1 in. (D)
    418 mm (W) x 417-537 mm (H) x 230.5 mm (D)
    Net (without stand):
    16.5 in. (W) x 14.4 in. (H) x 2.6 in. (D)
    418 mm (W) x 367 mm (H) x 67 mm (D)
    Gross:
    20.2 in. (W) x 20.9 in. (H) x 11.2 in. (D)
    512 mm (W) x 530 mm (H) x 285 mm (D)
    Display Colors: 16.7 Million Colors
    (Dependent upon display card used)
    Input Video Signal: ANALOG: 0.7 Vp-p/75 Ohms Positives
    LCD Module: 19-inch (19" viewable image size),
    active matrix, thin film transistor (TFT),
    liquid crystal display (LCD), 0.294 mm dot
    pitch, 250 cd/m² white luminance - typical,
    500:1 contrast ratio - typical, 25ms response
    time - typical
    Operating: Temperature: 5°C to 35°C / 41°F to 95°F
    Humidity: 30% to 80%
    Altitude: 3,000 m / 10,000 Feet
    Power Consumption: On: 46W
    Power Savings Mode: < 3W
    Power Management: VESA DPMS
    Power Supply: AC 100-120/220-240 V @ 50/60 Hz
    Recommended Resolution: 1280 x 1024 @ 60 Hz
    Resolutions Supported: 720 x 400* at 70 Hz
    640 x 480* at 60 Hz to 75 Hz
    800 x 600* at 56 Hz to 75 Hz
    832 x 624* at 75 Hz
    1024 x 768* at 60 Hz to 75 Hz
    1280 x 1024 at 60 Hz to 70 Hz
    Signal Cable: D-sub to D-sub cable
    Storage: Temperature: -10°C to +60°C / 14°F to 140°F
    Humidity: 10% to 85%
    Altitude: 9,144 m / 30,000 Feet
    Sync: Seperate sync: TTL Level
    Horizontal sync: Positve/Negative
    Vertical sync: Positive/Negative
    Synchronization Range (Automatic): Horizontal: 31.5 kHz to 81.0 kHz
    Vertical: 56.0 Hz to 75.0 Hz
    VESA Hole Configuration Spec. 100mm x 100mm
    Viewing Angle: Vertical: 170° (Left/Right: 85°)
    Horizontal: 170° (Up: 85° Down: 85°)
    (10:1 measurement condition)
    Weight: Net: 16.1 lbs. / 7.3 kg
    Shipping: 20.9 lbs. / 9.5 kg
    here are the specs..
    I REALLY NEED TO SELL THIS.. BILLS NEED TO BE PAYED.. MAKE ME AN OFFER.. ALL OFFERS WILL BE CONSIDERED!!!
    '92 DA-GS
    '91 240sx - Project
    S3 Magazine
    Athens
    bump....MAKE ME AN OFFER.. I NEED THIS STUFF GONE!!!!!
    '92 DA-GS
    '91 240sx - Project
    S3 Magazine
    Cool
    $150.00 Cash
    G35 6MT - Vortech'ed SOLD
    Defected to the Dark Side - 996 C4S!
    PM Sent
