Results 1 to 40 of 50
Thread: OzSportz HONDA UNLTIMATE FOR SALE THREAD
    Oct 2003
    Exclamation OzSportz HONDA UNLTIMATE FOR SALE THREAD
    Damn Gotta pay some bills help me out
    Lots of stuff ....come on ppl dont low ball me ..u dont know how many requests i get in my PMs
    MORE ITEMS WILL BE ADDED FREQUENTLY---
    LAST UPDATED: 11/10/2006
    PORT AND POLISHED B16 Head
    Dual ITR Valve Springs
    Retainers
    Fresh Valve Job
    New valve stem Seals
    Complete valvetrain
    At machine shop being polished right now
    Pic below of the port work. will get some more pics tomorrow Night
    Also will get pics of the bowl and how they have the lip of the valve seat smooth with the chamber for better flow
    (2nd pic of head shows difference between ported and original ports)
    $750 alone or $900 i'll include the COMPCAMS!!!!!!!!! or $600(includes head and cams) + ur stock head
    **** B-Series VTEC Cams...CompCam, ITR, SKUNK2 ****
    ITR CAMS
    $375
    CompCams Stage 2
    Condition Great
    CompCam Part# 57200
    Operating RPM Range: 2,400-8,600 RPM
    Product info : http://store.summitracing.com/partde...5&autoview=sku
    $450
    SKunk2 Stage2
    $500...$550 with cam gears
    (info from CivicClub.com)
    Following Cams Measured at 1mm of lift:
    Integra Type-R(Through 1999 Spec)
    Int-240 dur. / 11.5mm lift
    Exh-235 dur. / 10.5mm lift
    Valve Springs to be used: Stock B16A/GSR if using stock 8200 re-limit. Integra Type-R if using rev limit over 8200rpms. Mugen Valve Springs can also be used.
    Description: These are great, reliable cams for the money. They will give good gains from midrange all the way until 8400rpms. These cams have stock idle characteristics.
    Skunk2 Stage 2
    Int-266 dur. / 12.3mm lift
    Exh-262 dur. / 11.8mm lift
    Valve Springs to be used: Skunk2 preferred but Port Flow will work as well. These cams are wild enough that you should not be using the low 8200rpms rev limit.
    Description: The new top dog of the cam world. This will become the most common aftermarket (non OEM) cam in the US when they start getting distributed more. These have a very similar power band as the JUN Type 3, with less cost and better reliability (I said the “r” word). Not huge midrange but very good gains from 7000rpms all the way to 9000rpms(peak is usually around 8200rpms). These cams have stock idle characteristics, thus making them the ultimate street/strip cam. I recommend using Skunk2 cam gears with these cams
    JDM LSD H22 TRANSMISSION LSD
    LSD
    NO GRINDS
    BLOCK Code 1018862
    $800
    GSR Tranny
    No grinds
    125k
    $500
    B-series b16 CABLE TRANNY
    no grinds
    $350
    JDM B16a Short Block Complete
    P30 pistons
    Only 40k kilometers..
    You can still see the cross hatches on the cylinder walls
    code: 5703622
    $500
    JDM B16a LONG BLOCK
    JDM B16a Head Complete
    Intake manifold with sensors
    Throttle Body
    Dual Valve Springs
    Slight port work
    No Dizzy
    code: 5703622
    $900
    USDM B18c1 Block with JE Pistons
    JE 10.5:1
    (similar to TypeR)
    Bearings were replaced
    7k since build
    Code: 7301622
    w/ Ported & POlished B16 head $1700 Assembled LONGBLOCK(new gasket and timing belt)
    or
    w/ P&P B16 head,
    Retainers
    dual valve springs( intake and Exhaust)
    skunk2 stage 1 cams
    Ported & POlished
    B16 Intake manifold
    $2000 Assembled (new timing belt and gasket)
    or w/ SKUNK2 STAGE 2 Camshafts and Skunk2 Adjustable Cam Gears $2500 LONGBLOCK
    B-Series Turbo Manifold
    South Florida Performance (SFP)
    T3 turbo flange
    38mm Waste Gate flange
    $200
    **ALL 4 GunMetal with polish Lip**
    Wheels off Prelude
    17" Alloy
    5x114.3 Wheels with Tires
    Front two tires are BAD
    Rear 2 tires are GOOD
    has slight minor curbage
    $400
    P72 A/c Bracket $20
    P30 A/c Bracket $25
    B Series into CIVIC A/c Bracket $50 SOLD SOLD SOLD
    B series starters $30 each
    H22 Obd1 AC compressor $30
    Attached Thumbnails Attached Thumbnails -dsc00563-jpg   -dsc00565-jpg   -35f9d785ebdb-jpg
    Out in the Boonies
    dibs on the b16 tranny and axles
    Oct 2003
    H22 LSD TRANNY PIC
    Attached Thumbnails Attached Thumbnails -bd976df0841f-jpg   -cams-jpg   -importatlanta-025-jpg   -5c7f6c584f36-jpg
    college park
    got just a b16 head already prepped for ls vtec?
    now with LSD
    Oct 2003
    Unhappy
    Sorry already sold it
    college park
    damn i been looking for you to post another one i sent you a pm a while back asking if you had one well pm me if you build another one im looking to go ls vtec pretty soon
    now with LSD
    Oct 2003
    The wheels shown on the REAR I got a full set of 4
    Attached Thumbnails Attached Thumbnails -blacktl-jpg   -silveralloytl-jpg
    At Home
    GL with sale
    k20SiHatch
    i might get the Hondata chip after i get my paycheck this wednesday =)
    Banned VTECin5th's Avatar
    Ask your mother?
    Good dealz!
    Oct 2003
    Damn that first pic of the block looks gay
    Here a better pic
    Attached Thumbnails Attached Thumbnails -importatlanta-045-jpg   -importatlanta-046-jpg
    hey i pretty new to the whole importatl thing but i am interested in the hondata. i guess just reply to this i have a few questions about the hondata. thanks
    Oct 2003
    Quote Originally Posted by eg6BT
    check your private messages
    Still Here LQQKITZME's Avatar
    Roswell
    B Series into CIVIC A/c Bracket $50 ?? whats that the p54 delsol bracket??
    View the world through a dogs eyes, if you can't screw it or eat it, pi$$ on it and walk away.
    V8KILLR
    will the hondata work on obd1 i seen it said something about obd0
    Oct 2003
    Quote Originally Posted by just a honda
    yup will werk on obd1
    Quote Originally Posted by LQQKITZME
    Yup delsol braket
    West Staines
    Quote Originally Posted by Annihilation
    Yup delsol braket
    so... wahts the difference with that bracket and the p30 bracket?
    Oct 2003
    Talking
    Just added: Type R head setup
    ALSO I JUST WENT THROUGH THE b18b1 Block and replaced the bearings and checked everything out myself ...ready to go Zero Miles now honed and all
    Attached Thumbnails Attached Thumbnails -26f5d6edce1b-jpg
    h series
    norcross
    hey man i need an iacv for an h22 since my idle is still jumpy just let me know if u still got one
    another yt in a honda xliv2racex's Avatar
    G'nett
    Hondata pending, check pm;s cash in hand
    99 LS teg/
    Oct 2003
    UPDATE Oct, 7:
    LS block w/CTr pistons SOLD
    B16a Head SOLD
    HONDATA SOLD
    Oct 2003
    B-series Cable clutch set SOLD
    college park
    damn oz your selling this motor shit like your on da block
    now with LSD
    co-lame-bus
    im interested in the p72 head. why is it for sale ?
    ... £G2♣'s Avatar
    2o9
    Quote Originally Posted by b18cguy
    Ummm....cuz he sells stuff to make $$$.....lol
    Oct 2003
    D-Series Venom Intake Manifold SOLD SOLD
    Oct 2003
    Lots of blocks and head and supercharger and shit being added today
    West Staines
    Oz.... i called you this morning. you dont return calls?
    or pm's?
    Oct 2003
    Check ur Pm Now
    hey you dont got any prelude wheels do you?
    Oct 2003
    Quote Originally Posted by WannabeeCTR
    not stock one...only those pictured i have
    atl
    hi oz...
    atl
    Default bump bump
    bump the boost
    Certified Gearhead 2.0lturbo4's Avatar
    Do you still have the H22 transmission. LMK
    oz, its joel
    Oct 2003
    b16 head added
    The Dark Lude dakilla4ever's Avatar
    In the Darkness
    can i have the car? pm me if your willing to sell it.
    Fast+Cheap= Not Reliable
    Cheap+Reliable=Not Fast
    Fast+Reliable=Not Cheap
    THE DARK LUDE SPEAKS
    Oct 2003
    Quote Originally Posted by dakilla4ever
    wat car?
    Oct 2003
    Port & POlish B16 Head with vtec solinoid and valve train + COMPCAMs $900 <----DEAL!
