Thread: exhaust leak on 94 gsr
    Default exhaust leak on 94 gsr
    I had noticed ever since i bouth the car that there was a header bolt missing and that i needed to replace it but i never came around to it and i was just about to go pick up a new bolt and a new gstket when a freind told me that there was a possibility that the previous bolt might have broken inside so i looked inside and sure enough therre it was what should i do any cheap or easy ways out of this?
    91 sedan b16 turb 89 lude's Avatar
    war town
    ebay
    war town
    just remember you pay for what you get when buy parts for your car
    Default what do you mean
    i dont need parts i need to get the bolt out of the head
    Gainesville
    hey Ebay rocks yo!! i bought my header fo my D16Y7 and had it over a year and it works fine...just gotta put it together and put in right and careful
    Tech Fanatic
    warner robins
    Quote Originally Posted by blackgsr89
    You need to get yourself a drill gun with a small drill bit and drill into the broken stud. Buy yourself an easy-out bolt extractor kit. It looks like a t-handle with a screw that twists the wrong way. You insert this into the hole of the bolt and twist it out. Very easy fix.
    Default thanks
    thanks but does anybody know what i need to do to get in there. Drop the engine the radiator or any other easy wasys out.
    Tech Fanatic
    warner robins
    This is something you should figure out yourself. Just look down in there. Can you fit a drill gun? If not, what about when you remove the radiator?
    Gainesville
    just get new headers from ebay..just assemble then put on
